I have a page has the cffileuload tag.
The process page simply moves the file to a new location and returns the JSON stuct.
<cfset str.STATUS = 200>
<cfset str.MESSAGE = "passed">
<cfoutput>#serializeJSON(str)#</cfoutput>
When I run the page I get a red bar error (no number) on the first file and the uploading stops. However the actual file does move so it is being processed.
When I comment out the str.STATUS = 200 everything seems to work fine.
I don't have much understanding of AJAX but I was under the assumption that the STATUS 200 was feedback to the uploader that the page has successfully run.
According to the documentation I need to output the JSON as above.
Any help would be appreciated.
Running: CF9.0.1
I'm having the same problem. All the examples I've found say that the upload handler should return the following JSON (using your own appropriate values):
<cfset str.MESSAGE = "This is a message.">
<cfoutput>#serializeJSON (str)#</cfoutput>
but I get an error... the progress bar turns red and when I output the results of the onComplete js function, I get
Status: [500], message: [Error], file: [temp.txt]
output comes from the onComplete function (onComplete="uploadFilesComplete"):
function uploadFilesComplete (file) {
var msg = '<p>Status: [' + file.STATUS + '], message: [' + file.MESSAGE + '], file: [' + file.FILENAME + ']</p>';
var obj = document.getElementById ('upload-results');
if (obj)
obj.innerHTML = obj.innerHTML + msg;
But if I don't return any output, I get:
Status: [200], message: [Success], file: [temp.txt]
I wonder if this worked in CF 9.0, but was recently broken in CF 9.0.1. I just ran into another problem after updating to CF 9.0.1 (AJAX cflayoutarea broken) here:
