4 Replies Latest reply on Aug 13, 2010 12:49 PM by Ned Murphy
    scroll buttons
    Ron Colmen Level 2
      I'm trying to replce A with B. But I can't figure it out why A is not functioning when I do so.
      A (works fine)
      scrollUp_btn.onRelease = function() {
          newszlatest.scroll--;
          scroll_txt.text = newszlatest.scroll+" of "+newszlatest.maxscroll;
      scrollDown_btn.onRelease = function() {
          newszlatest.scroll++;
      B (doesn't work when replaced)
      var dir = 1;
      scrollUp_btn.onPress = function() {
            dir = -1;
            this.onEnterFrame = scrollText;
      scrollDown_btn.onPress = function() {
            dir = 1;
      scrollUp_btn.onRelease = scrollDown_btn.onRelease = function(){
            delete this.onEnterFrame;
      function scrollText(){
      newszlatest.scroll += dir;
      This code goes just under this (I'm not sure if this is helpful)
      receiveLoad.onData = function(src) {
        • 1. Re: scroll buttons
          you're over-writing the first (A) onRelease methods with the ones that delete this.onEnterFrame.
          • 2. Re: scroll buttons
            Here's a link to a working version of the modified help document example.  Maybe you can compare to see how your design differs...
            http://www.nedwebs.com/Flash/AS2_Continuous_Scroll.fla
            • 3. Re: scroll buttons
              Ron Colmen Level 2
              Thank you Ned. I can not figure it out....
              THis is my full code
              newszlatest.text="";
              var senderLoad:LoadVars = new LoadVars();
              var receiveLoad:LoadVars = new LoadVars();
              var format1:TextFormat = new TextFormat();
              format1.color = 0xC0C0C0;
              this.createTextField("scroll_txt", this.getNextHighestDepth(), 100, 170, 650, 230);
              this.createTextField("newszlatest", this.getNextHighestDepth(), 100, 170, 650, 230);
              newszlatest.multiline = true;
              newszlatest.wordWrap = true;
              senderLoad.sendAndLoad("http://www.web.com/my.php",receiveLoad,"POST");
                   var messageA:Array = src.split(",,,");
                   messageA.pop();
              var charCount = 0;
                   var formatIndices = new Array();
              newszlatest.html=true;
                   for(var i:Number=0; i<messageA.length; i++){
                         var msgA:Array = messageA[i].split(",,");
                         newszlatest.htmlText += msgA[0]+"  | "+msgA[1].split(" ")[0]+"<br>"+msgA[2]+"<br><a href='"+msgA[3]+"'>"+msgA[3]+"<\a><br><br>";
                         formatIndices[i] = {startAt: charCount, endAt: charCount+msgA[0].length};
                         charCount = newszlatest.text.length;
                   for(var j:Number=0; j<formatIndices.length; j++){
                         newszlatest.setTextFormat(formatIndices[j].startAt, formatIndices[j].endAt, format1);
              var dir = 1;
                  dir = -1;
                  dir = 1;
              trace("here");
              • 4. Re: scroll buttons
                If I substitute a variable in place of loading your data file (and assign it some parse-able values)  and adjust the related code, I can get it working as you have it, so I can't say what might be wrong in your setup...
                this.createTextField("scroll_txt", this.getNextHighestDepth(), 100, 150, 250, 20);
                var src = "some,,stuff,,to start,,to start,,,other,,stuff,,to add,,to start,,,even more,,stuff,,to boot,,to start,,,some,,stuff,,to start,,to start,,,other,,stuff,,to add,,to start,,,even more,,stuff,,to boot,,to start";
                messageA.pop();
                var charCount = 0;
                var dir = 1;
                    dir = -1;
                    dir = 1;
                trace("here");
