7 Replies Latest reply on Nov 3, 2011 10:32 AM by Omke Oudeman
    contact sheets in Bridge CS5
    tog27 Newcomer
      I can't find how to make a contact sheet from Bridge 5. I did find something that creates a pdf but it's no where near as good and fast as the way to do it in Bridge 3. I used to be able to select 'make contact sheet' through the Tools menu - photoshop
        • 1. Re: contact sheets in Bridge CS5
          Champion
          tog27 wrote:
          I can't find how to make a contact sheet from Bridge 5.…
          "Bridge 5"?  The Bridge that comes with CS5 (Photoshop 12.x) is Bridge 4.  "Bridge 5" does not exist yet.
          tog27 wrote:
          … I did find something that creates a pdf but it's no where near as good and fast as the way to do it in Bridge 3.
          You are confused.
          Bridge 3 came with Photoshop CS4 (11.x), and that function had been moved to the Bridge Output panel in CS4 already.
          Maybe you meant Bridge 2, which was the one that came with Photoshop CS3 (10.x).
          In any event, you can download an optional plug-ins set for CS5 that will restore the Contact Sheet.  See:
          http://blogs.adobe.com/jnack/2010/05/optional_plug_ins_available_for_photoshop.html
          Wo Tai Lao Le
          我太老了
          • 2. Re: contact sheets in Bridge CS5
            Omke Oudeman Rockstar
            That something is called the Output Module and gives you a lot options to
            create a contact sheet with custom settings (and you can create templates
            that can be saved so easy to get that for the next time).
            An I disagree hat it is slower then the former contact sheet in PS,
            especially with multiple pages the Output Module is much faster
            The only downside for Output Module is that you can't export as a jpeg or
            tiff, this is a long standing wish and you may add this also as a feature
            request. The more that want this, the greater chance it will get realized.
            However you still be able to use this old contact sheet (see the link Tai
            Lao just provided you to download it) but there is a but...
            After installing the script according to the read me file you will see this
            in the Tools menu for Bridge but it only works in 32 bit mode (this old
            script has official been discontinued and won't get updated to 64 bit). By
            default PS is running in 64 bit and therefore won't recognize the script.
            To use it you have to first quit PS, in finder select the application icon
            for PS, press 'get info' (cmd+i) and in the provided info window check start
            PS in 32 bit mode.
            Now you can use it as before.
            • 3. Re: contact sheets in Bridge CS5
              mustafaturgut Newcomer
              I use Win 7 64 BIT
              I make pdf output in Bridge CS5 but not work.
              I downloaded optional filters and I tried in to read me files path but it doesn't work.
              Now I find a new path and put in the "bridge Startup Scripts" file there. They working perfectly.
              The path is the bottom:
              ... /Program Files(x86)/Common Files/Adobe/Bridge CS5 Exkensions/Adobe Output Module/Resources/Scripts
              Copy all files and folders "PSCS5OptionalPlugins_Win_en_US/Bridge Sturtup Scripts" paste in to this folder at the path
              enjoy ....
              • 4. Re: contact sheets in Bridge CS5
                Champion
                mustafaturgut wrote:
                I use Win 7 64 BIT…
                But this is the Bridge Macintosh forum.
                It's good of you to share this, Mustafa, but it has absolutely nothing to do with Bridge on a Macintosh.  The paths and files you name do no apply to the Mac at all.
                ____________
                Wo Tai Lao Le
                我太老了
                • 5. Re: contact sheets in Bridge CS5
                  You right. I'm sorry..
                  • 6. Re: contact sheets in Bridge CS5
                    k8slotover Newcomer
                    Probably unbelievably obvious, but just in case anyone is scratching their head because they can't seem to see the 'output' options, they're in a panel that may be minimized – it lives on the right of the window. Once I expanded the margin I found it hidden away, and there are all the options I was looking for.
                    • 7. Re: contact sheets in Bridge CS5
                      By default choosing the workspace 'Output' the panel would be good visible, if you don't have this behavior you might want to reset the workspace output and you should be OK.
