2 Replies Latest reply on Aug 12, 2010 11:32 PM by welcomecan
    label display issue?
    welcomecan Level 1
      hai friends,
              i am doing a flexcoldfusion project. i used text area and label .first i give data to txtarea then save data. that stored in db.then i reterive that data. display in label.
      my issue i gave more data in txtarea like this
                    hello             //type hello give  enter
                    welcome
                    Test
      now i reterive that data. it shows only hello    .what is the problem give solution?
        • 1. Re: label display issue?
          flex4 Level 2
          Hi Welcomecan
                           The Lable property dose not allow multiple lines in disply.. if u want to disply more data on screen you can apporch mx:Text  that will allow multiple lines and it will show u entire text.. i
                             what is the issue here with the lable is lable only show u the text upto the width mentioned to the text.. if u increase the text length it will  show u just like " .........."
                             use mx:Text to improve the display of the text or it will allow u to display the entire text... Lable will show u the large amount of text
                      I think u catch my point
          • 2. Re: label display issue?
            welcomecan Level 1
            sorry friend,
                  ur answer is wrong. The Lable property dose not allow multiple lines in display.. if u want to disply more data on screen you can apporch S:Text  that will allow multiple lines and it will show u entire text.. i
