1 Reply Latest reply on Aug 13, 2010 11:35 AM by Joe ... Ward
    How to enable the "debug" flag in Linux (ubuntu)
    matteosistisette
      I want the error message dialogs to pop up when I run an installed AIR application, running it normally, not with the ADL.
      In Windows and Mac, I can accomplish this by creating an empty file or folder called "debug" inside the
      (application install folder)/META-INF/AIR
      However, this doesn't work in Linux.
      On linux, I read somewhere (cannot find it now) that you can do the same by typing:
      export AIRDEBUG=1
      in a terminal.
      This works only if I launch the applications from the same terminal; that is, I have to open a terminal and write:
      export AIRDEBUG=1
      /opt/myapplication/bin/myapplication
      In the same article that suggested this, it also suggested that you could add the "export AIRDEBUG=1" line to the .bashrc file so it would be automatically executed at startup.
      However, it still only works if I launch the applications from a terminal. That is, I don't have to write "export AIRDEBUG=1" every time, but I still have to open a terminal and launch the application from the command line.
      I want it to work also when I launch the application normally from the panel menu shortcut that was automatically created when installing the app.
      Any idea?
      thanks
      m.
