I have assessment questions that I used Presenter to create. After I click "Publish", all the possible answers are wiped out, as well as the mandatory/optional, and shuffle/don't shuffle settings. has anyoen else come across this with a fix?
Thanks so much in advance for any help!
I will be out of the office starting 13/08/2010 and will not return until
31/08/2010.
If your matter is urgent, then please contact Emma Dawson on ext. 15832.
I am having the same problem pease help
Never mind I found the answer to my case I had imported slides from another Power Point presentation which had each a quiz but PP only imports the text not the quiz itself so I deleted the slides pertaining to the quiz and through the import quiz function I imported the actual quzzes from those PP aps and all works fine now
I eventually found my fix as well: my issue was I was changing the master page, when I did that, it did something to the
quiz settings. Once i figured that out, my answers stopped wiping out.
