I am trying to connect to my remote in-house development coldfusion 9 standard installation with the latest version of CFB 1 Build 274293. I have all the default settings and ports and it seems to recognize the server but it shows the status as "stopped". The CF9 service is actually running. If I try to right-click and tell the server to start, I get this message:
-Cannot perform the operation. Admin server for the remote server Local CF9 is not running.
I cannot preview my website, when I click the "IE" tab, it shows a dialog message of:
-Unable to resolve file on the remote machine. Ensure that you have entered the correct mapping information.
Nothing shows up in the console as an error, except when I try to start the service. My Services Browser, when I click on the "Show CFCs on RDS Servers", I just get the message when I extract my Local CF9 server of: "Unable to get meta data for cfc".
I have come across blogs that have mentioned to run the adminstart.bat. When I run that I get nothing but a blank command prompt that disappears. I don't see any port number or any other screen.
When I run this line in the command prompt (being in the directory): "jrun -config admin_jvm.config -start admin", I get this error: "Error loading: C:\Java\jdk1.6.0_21\jre\bin\client\jvm.dll"
I will also mention that I put an * on the jrun.subnet.restriction and jrun.trusted.hosts in the security.properties file.
One of the links I read: http://help.adobe.com/en_US/ColdFusionBuilder/Installing/WS0ef8c004658c108926f4c3db1249e52277c-7ff4....
Please give some guidance or things to look for, I have attempted to use CFB many times and each time I went back to Homesite because I could never get it to connect. This time I am going to give it a double effort to get connected, but I need assistance.
Well, still unable to find an answer and nothing seems to get it working. CFB seems to crash often and the whole thing just seems very unacceptable. I am returning to using Homesite 5.5 until this becomes more stable.
I am having the same problem.
When I got that "Unable to get meta data from cfc" message, it was because I hadn't provided a username and password for the RDS connection....after I did so, it worked fine....
I have the same problem!!!! can someone help for urgent! I can't using the cf builder in this situation.
