7 Replies Latest reply on Aug 17, 2010 3:42 AM by dhishok
    Problem while converting the word doc to pdf
    sriks23
      Hi
          I am trying to convert the word document to pdf using the script but the problem is once converted i am able to view only 1 page which is converted to pdf.
      var myDocument = app.documents.add();
      var myPage = myDocument.pages.item(0);
      var myTextFrame = myPage.textFrames.add();
      //myTextFrame.contents = "Bowne and co!!";
      myTextFrame.place(File("/c/Jboss Esb WS Producer.doc"));
      //Get page width and page height using the function "myGetBounds".
      myBounds = myGetBounds(myDocument, myPage);
      //Resize the text frame to match the publication margins.
      myTextFrame.geometricBounds = myBounds;
      var myParagraph = myTextFrame.paragraphs.item(0);
      //Change the font, size, and alignment.
      //Enter the name of a font on your system, if necessary.
      try {
          var myFont = app.fonts.item("Arial");
          myParagraph.appliedFont = myFont;
      catch (e){}
      //Change the size of the text.
      myParagraph.pointSize = 20;
      //Set the justification of the paragraph to center align.
      myParagraph.justification = Justification.centerAlign
      //Set the first baseline offset of the text frame to ascent.
      myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.ascentOffset;
      //Set the vertical justification of the text frame to center.
      myTextFrame.textFramePreferences.verticalJustification = VerticalJustification.centerAlign;
      //Export the document as PDF (fill in a valid file path).
      myDocument.exportFile(ExportFormat.pdfType, new File("/c/Final.pdf"));
      //Close the document.
      app.documents.item(0).close();
      function myGetBounds(myDocument, myPage){
          var myPageHeight = myDocument.documentPreferences.pageHeight;
          var myPageWidth = myDocument.documentPreferences.pageWidth;
          var myTop = myPage.marginPreferences.top;
          var myLeft = myPage.marginPreferences.left;
          var myRight = myPage.marginPreferences.right;
          var myBottom = myPage.marginPreferences.bottom;
          myRight = myPageWidth - myRight;
          myBottom = myPageHeight - myBottom;
          return [myTop, myLeft, myBottom, myRight];
      Please suggest me the changes to be done..
