4 Replies Latest reply on Aug 14, 2010 10:42 AM by CrimsonBruin
    Making changes to an object after its effect has finished
    CrimsonBruin
      Hello,
      Looking for help on the effectFinished call.  There was a similar post recently, " Flex 4 Fade effect reverse filter suspend ?"  There doesn't appear to be any documentation on how this should be run.
      I am running a Rotate3D function on a FilledElement shape.  It rotates fine.  However, there are things I would like to do to the shape after it's rotated.  Even though I placed the code to change the fill on the shape after the play function, the shape is changed before the rotation has finished.  It seems as though I shoul dbe able to use the effectFinished call, but I don't see how, or how I would populate the parameter it needs.
      Any help would be greatly appreciated.
      Thanks!
