7 Replies Latest reply on Aug 13, 2010 9:44 PM by the_wine_snob
    webcam recording delay of video ... out of sync with sound
    hou5ton Level 1
      When using Elements 8 to record video from my webcam, (Logitech QuickCam Pro 9000) there is a delay in the video ... and the video and sound are not in sync.  For some reason the delay/sync issue doesn't appear to be there with Roxio. However, if I use the Logitech software that came with the webcam, all is fine unless I set it for a higher resolution ... then the delay issue comes back.
      I'm using a HP laptop ... Windows 7 .. Intel(R) Core(TM)2 Duo CPU    T6500 @ 2.10 GHz   .... 4 GB RAM .... 64 bit OS
        • 1. Re: webcam recording delay of video ... out of sync with sound
          the_wine_snob Level 9
          PrE is designed to Capture from miniDV tape, and not for Capture from a Webcam.
          I would use the software included, and then Save/Export to a file format/CODEC, that PrE can easily edit. What is the resolution of your Webcam footage?
          • 2. Re: webcam recording delay of video ... out of sync with sound
            hou5ton Level 1
            Medium: 640x480
            It has a setting for Large: 960x720 but there seems to be a slight delay in response time.
            It also has a setting for Max: 2MP, but then the video is seriously delayed from realtime.
            I'm trying to get quality video recorded for courses I teach.
            • 3. Re: webcam recording delay of video ... out of sync with sound
              This could be either a latency in the equipment, or with the system in the recording process.
              Can you furnish the details of your system, especially the I/O sub-system, i.e. your HDD's, their size, speed, free space, controller type and how you have them allocated? Could well be something there.
              • 4. Re: webcam recording delay of video ... out of sync with sound
                hou5ton Level 1
                Is this what you are looking for?
                OS Name    Microsoft Windows 7 Home Premium
                Version    6.1.7600 Build 7600
                Other OS Description     Not Available
                OS Manufacturer    Microsoft Corporation
                System Name    HOU5TON-PC
                System Manufacturer    Hewlett-Packard
                System Model    HP Pavilion dv3 Notebook PC
                System Type    x64-based PC
                Processor    Intel(R) Core(TM)2 Duo CPU     T6500  @ 2.10GHz, 2100 Mhz, 2 Core(s), 2 Logical Processor(s)
                BIOS Version/Date    Hewlett-Packard F.11, 9/4/2009
                SMBIOS Version    2.4
                Windows Directory    C:\Windows
                System Directory    C:\Windows\system32
                Boot Device    \Device\HarddiskVolume1
                Locale    United States
                Hardware Abstraction Layer    Version = "6.1.7600.16385"
                User Name    hou5ton-PC\hou5ton
                Time Zone    Central Daylight Time
                Installed Physical Memory (RAM)    4.00 GB
                Total Physical Memory    3.90 GB
                Available Physical Memory    2.33 GB
                Total Virtual Memory    7.81 GB
                Available Virtual Memory    6.15 GB
                Page File Space    3.90 GB
                Page File    C:\pagefile.sys
                • 5. Re: webcam recording delay of video ... out of sync with sound
                  That is part of it. The I/O sub-system is the HDD's. How many do you have? How large are they? What is their speed? How much free space do you have? How do you have them allocated?
                  An example would be:
                  All 7200 RPM SATA II internals,
                  C:\ OS, programs and Page File - 500GB w/ 300GB free
                  D:\ Project files and Scratch Disks - 500GB w/ 250GB free
                  E:\ Media files - 500GB w/ 125GB free
                  Hope that helps,
                  • 6. Re: webcam recording delay of video ... out of sync with sound
                    hou5ton Level 1
                    More details  about my computer
                    ComponentDetailsSubscoreBase  score
                    ProcessorIntel(R) Core(TM)2 Duo CPU T6500 @  2.10GHz5.6
                    3.4
                      Determined by lowest  subscore
                    Memory (RAM)4.00 GB5.6
                    GraphicsMobile Intel(R) 4 Series Express Chipset  Family3.9
                    Gaming graphics1695 MB Total available graphics  memory3.4
                    Primary hard disk254GB Free (410GB Total)5.6
                    System
                    ManufacturerHewlett-Packard
                    ModelHP Pavilion dv3 Notebook PC
                    Total amount of system  memory4.00 GB RAM
                    System type64-bit operating system
                    Number of processor  cores2
                    Storage
                    Total size of hard  disk(s)689 GB
                    Disk partition (C:)254 GB Free (410 GB Total)
                    Media drive (D:)CD/DVD
                    Disk partition (E:)77 GB Free (146 GB Total)
                    Disk partition (G:)45 GB Free (133 GB  Total)
                    Graphics
                    Display adapter typeMobile Intel(R) 4 Series Express  Chipset Family
                    Total available graphics  memory1695 MB
                          Dedicated graphics  memory64 MB
                          Dedicated system  memory0 MB
                          Shared system  memory1631 MB
                    Display adapter driver  version8.15.10.1872
                    Primary monitor  resolution1366x768
                    Secondary monitor  resolution1024x768
                    DirectX versionDirectX  10
                    Network
                    Network AdapterRealtek RTL8102E/RTL8103E Family  PCI-E Fast Ethernet NIC (NDIS 6.20)
                    Network AdapterAtheros AR9285 802.11b/g/n WiFi  Adapter
                    Network AdapterMicrosoft Virtual WiFi Miniport  Adapter
                    Notes
                    The gaming graphics score is based on  the primary graphics adapter. If this system has linked or multiple graphics  adapters, some software applications may see additional performance  benefits.
                    • 7. Re: webcam recording delay of video ... out of sync with sound
                      OK, it looks like you have one physical HDD and it is partitioned. This ARTICLE will give you some background on partitions, especially when doing video editing.
