Starting with Premier CS3 I when I installed QT player I would loose the links or association with the media my projects were linked to. The first time I figured out it was QT but did not understand why. At first I thought it was that update. Since I have tried two times and the same thing. Once I restored the system to a prior date Premier CS3 or CS4 worked fine and the linkage to the media was restored.
We recently tried it again with a new and improved QT after making some updates to Adobe Production premium and it did the same thing.
I then tried restoring the system as usually but now for the first time it is giving me the following error.
This application has failed to start becasue QTCF.dll was not found. Reinstalling applciaiton may fix this problem.
I get it when I start up Photoshop CS4 Extended also.
Is this referring to the QT player plug-in?
Any suggestions. If I have to update QT fine but how do I combat loosing the media linkage?
INVT
