10 Replies Latest reply on Aug 15, 2010 11:06 AM by kglad
    Urgent! Help needed!
    Animation Cowboy Level 1
      My workspace is 1000X1200 and I have a background image in Flash 1920 width.
      I want the SWF to aligned to center in the HTML with a regular browser scroller.
      I'm trying to publish 100% X 100% with no scale but the scroll bar doesn't show from bottom to top and the SWF parts are missing!
      How can I make it to show the background (what outside stage) with regular browsers scrollers and align to center?
      Many thanks for the solution,
      Best,
      AC
        • 1. Re: Urgent! Help needed!
          copy and paste the html you are using and copy and paste your noScale actionscript.
          • 2. Re: Urgent! Help needed!
            Thanks Kglad,
            There isn't much to paste really because I don't use any special Actionscript for this, only picking "noScale" from the combo-box in the Publish-Settings>Html tab.
            Here's the pasted HTML content (again, no actionscript inside Flash itself):
            <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
            <head>
            <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-8" />
            <title>HomeSite</title>
            <script language="JavaScript" type="text/javascript">
            //v1.7
            // Flash Player Version Detection
            // Detect Client Browser type
            // Copyright 2005-2008 Adobe Systems Incorporated.  All rights reserved.
            var isIE  = (navigator.appVersion.indexOf("MSIE") != -1) ? true : false;
            var isWin = (navigator.appVersion.toLowerCase().indexOf("win") != -1) ? true : false;
            var isOpera = (navigator.userAgent.indexOf("Opera") != -1) ? true : false;
            function ControlVersion()
            var version;
            var axo;
            var e;
            // NOTE : new ActiveXObject(strFoo) throws an exception if strFoo isn't in the registry
            try {
            // version will be set for 7.X or greater players
            axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
            version = axo.GetVariable("$version");
            } catch (e) {
            if (!version)
            try {
            // version will be set for 6.X players only
            axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
            // installed player is some revision of 6.0
            // GetVariable("$version") crashes for versions 6.0.22 through 6.0.29,
            // so we have to be careful.
            // default to the first public version
            version = "WIN 6,0,21,0";
            // throws if AllowScripAccess does not exist (introduced in 6.0r47)
            axo.AllowScriptAccess = "always";
            // safe to call for 6.0r47 or greater
            } catch (e) {
            if (!version)
            try {
            // version will be set for 4.X or 5.X player
            axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.3");
            } catch (e) {
            if (!version)
            try {
            // version will be set for 3.X player
            version = "WIN 3,0,18,0";
            } catch (e) {
            if (!version)
            try {
            // version will be set for 2.X player
            axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
            version = "WIN 2,0,0,11";
            } catch (e) {
            version = -1;
            return version;
            // JavaScript helper required to detect Flash Player PlugIn version information
            function GetSwfVer(){
            // NS/Opera version >= 3 check for Flash plugin in plugin array
            var flashVer = -1;
            if (navigator.plugins != null && navigator.plugins.length > 0) {
            if (navigator.plugins["Shockwave Flash 2.0"] || navigator.plugins["Shockwave Flash"]) {
            var swVer2 = navigator.plugins["Shockwave Flash 2.0"] ? " 2.0" : "";
            var flashDescription = navigator.plugins["Shockwave Flash" + swVer2].description;
            var descArray = flashDescription.split(" ");
            var tempArrayMajor = descArray[2].split(".");
            var versionMajor = tempArrayMajor[0];
            var versionMinor = tempArrayMajor[1];
            var versionRevision = descArray[3];
            if (versionRevision == "") {
            versionRevision = descArray[4];
            if (versionRevision[0] == "d") {
            versionRevision = versionRevision.substring(1);
            } else if (versionRevision[0] == "r") {
            if (versionRevision.indexOf("d") > 0) {
            versionRevision = versionRevision.substring(0, versionRevision.indexOf("d"));
            var flashVer = versionMajor + "." + versionMinor + "." + versionRevision;
            // MSN/WebTV 2.6 supports Flash 4
            else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.6") != -1) flashVer = 4;
            // WebTV 2.5 supports Flash 3
            else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.5") != -1) flashVer = 3;
            // older WebTV supports Flash 2
            else if (navigator.userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 2;
            else if ( isIE && isWin && !isOpera ) {
            flashVer = ControlVersion();
            return flashVer;
            // When called with reqMajorVer, reqMinorVer, reqRevision returns true if that version or greater is available
            function DetectFlashVer(reqMajorVer, reqMinorVer, reqRevision)
            versionStr = GetSwfVer();
            if (versionStr == -1 ) {
            return false;
            } else if (versionStr != 0) {
            if(isIE && isWin && !isOpera) {
            // Given "WIN 2,0,0,11"
            tempArray         = versionStr.split(" "); // ["WIN", "2,0,0,11"]
            tempString        = tempArray[1]; // "2,0,0,11"
            versionArray      = tempString.split(","); // ['2', '0', '0', '11']
            } else {
            versionArray      = versionStr.split(".");
            var versionMajor      = versionArray[0];
            var versionMinor      = versionArray[1];
            var versionRevision   = versionArray[2];
                    // is the major.revision >= requested major.revision AND the minor version >= requested minor
            if (versionMajor > parseFloat(reqMajorVer)) {
            return true;
            } else if (versionMajor == parseFloat(reqMajorVer)) {
            if (versionMinor > parseFloat(reqMinorVer))
            return true;
            else if (versionMinor == parseFloat(reqMinorVer)) {
            if (versionRevision >= parseFloat(reqRevision))
            return true;
            return false;
            function AC_AddExtension(src, ext)
              if (src.indexOf('?') != -1)
                return src.replace(/\?/, ext+'?');
              else
                return src + ext;
            function AC_Generateobj(objAttrs, params, embedAttrs)
              var str = '';
              if (isIE && isWin && !isOpera)
                str += '<object ';
                for (var i in objAttrs)
                  str += i + '="' + objAttrs[i] + '" ';
                str += '>';
                for (var i in params)
                  str += '<param name="' + i + '" value="' + params[i] + '" /> ';
                str += '</object>';
              else
                str += '<embed ';
                for (var i in embedAttrs)
                  str += i + '="' + embedAttrs[i] + '" ';
                str += '> </embed>';
              document.write(str);
            function AC_FL_RunContent(){
              var ret =
                AC_GetArgs
                (  arguments, ".swf", "movie", "clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
                 , "application/x-shockwave-flash"
              AC_Generateobj(ret.objAttrs, ret.params, ret.embedAttrs);
            function AC_SW_RunContent(){
              var ret =
                AC_GetArgs
                (  arguments, ".dcr", "src", "clsid:166B1BCA-3F9C-11CF-8075-444553540000"
                 , null
            function AC_GetArgs(args, ext, srcParamName, classid, mimeType){
              var ret = new Object();
              ret.embedAttrs = new Object();
              ret.params = new Object();
              ret.objAttrs = new Object();
              for (var i=0; i < args.length; i=i+2){
                var currArg = args[i].toLowerCase();
                switch (currArg){
                  case "classid":
                    break;
                  case "pluginspage":
                    ret.embedAttrs[args[i]] = args[i+1];
                    break;
                  case "src":
                  case "movie":
                    args[i+1] = AC_AddExtension(args[i+1], ext);
                    ret.embedAttrs["src"] = args[i+1];
                    ret.params[srcParamName] = args[i+1];
                    break;
                  case "onafterupdate":
                  case "onbeforeupdate":
                  case "onblur":
                  case "oncellchange":
                  case "onclick":
                  case "ondblclick":
                  case "ondrag":
                  case "ondragend":
                  case "ondragenter":
                  case "ondragleave":
                  case "ondragover":
                  case "ondrop":
                  case "onfinish":
                  case "onfocus":
                  case "onhelp":
                  case "onmousedown":
                  case "onmouseup":
                  case "onmouseover":
                  case "onmousemove":
                  case "onmouseout":
                  case "onkeypress":
                  case "onkeydown":
                  case "onkeyup":
                  case "onload":
                  case "onlosecapture":
                  case "onpropertychange":
                  case "onreadystatechange":
                  case "onrowsdelete":
                  case "onrowenter":
                  case "onrowexit":
                  case "onrowsinserted":
                  case "onstart":
                  case "onscroll":
                  case "onbeforeeditfocus":
                  case "onactivate":
                  case "onbeforedeactivate":
                  case "ondeactivate":
                  case "type":
                  case "codebase":
                  case "id":
                    ret.objAttrs[args[i]] = args[i+1];
                    break;
                  case "width":
                  case "height":
                  case "align":
                  case "vspace":
                  case "hspace":
                  case "class":
                  case "title":
                  case "accesskey":
                  case "name":
                  case "tabindex":
                    ret.embedAttrs[args[i]] = ret.objAttrs[args[i]] = args[i+1];
                    break;
                  default:
                    ret.embedAttrs[args[i]] = ret.params[args[i]] = args[i+1];
              ret.objAttrs["classid"] = classid;
              if (mimeType) ret.embedAttrs["type"] = mimeType;
              return ret;
            </script>
            </head>
            <body bgcolor="#ffffff">
            <!--url's used in the movie-->
            <!--text used in the movie-->
            <p align="center"><font face="Rockwell" size="14" color="#000000" letterSpacing="0.000000" kerning="1">Hold still...</font></p>
            <p align="left"><font face="Arial" size="12" color="#000000" letterSpacing="0.000000" kerning="1">Music: Silent Shout by The Knife </font></p>
            <p align="left"><font face="Rockwell" size="22" color="#ffffff" letterSpacing="0.000000" kerning="1"><b>Award winner -</b></font></p><p align="left"><font face="Arial" size="18" color="#ffffff" letterSpacing="0.000000" kerning="1">Aniboom / History Channel&apos;s &quot;The people speak&quot; Competition.<font face="Rockwell" size="22"><b> </b></font></font></p>
            <p align="left"><font face="Rockwell" size="22" color="#ffffff" letterSpacing="0.000000" kerning="1"><b>Storyboarding &amp; Directing </b></font></p><p align="left"><font face="Arial" size="18" color="#ffffff" letterSpacing="0.000000" kerning="1">8 episodes web-series for the History Channel.</font></p>
            <p align="left"><font face="Arial" size="18" color="#ffffff" letterSpacing="0.000000" kerning="1">Music by Metropol.</font></p>
            <p align="left"><font face="Arial" size="12" color="#000000" letterSpacing="0.000000" kerning="1">Modeling by AnimationLab.</font></p>
            <p align="left"><font face="Arial" size="16" color="#ffffff" letterSpacing="0.000000" kerning="1">Song by Dani Sanderson.</font></p>
            <p align="left"><font face="Arial" size="16" color="#ffffff" letterSpacing="0.000000" kerning="1">Client: <font face="Arial"><b>Bezeq International</b></font></font></p>
            <p align="left"><font face="Arial" size="14" color="#ffffff" letterSpacing="0.000000" kerning="1">+ Click to enlarge</font></p>
            <p align="left"><font face="Arial" size="16" color="#ffffff" letterSpacing="0.000000" kerning="1">Client:<font face="Arial"><b> Israeli news</b></font></font></p>
            <p align="left"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">Avi Graiver</font></p><p align="left"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">Avigra@gmail.com</font></p><p align="left"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">+972-52-4897242</font></p>
            <p align="center"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">Avi Graiver</font></p><p align="center"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">Avigra@gmail.com</font></p><p align="center"><font face="Rockwell" size="18" color="#000000" letterSpacing="0.000000" kerning="1">+972-52-4897242</font></p>
            <p align="left"><font face="Rockwell" size="24" color="#000000" letterSpacing="0.000000" kerning="1"><b>Cooming soon...</b></font></p>
            <p align="left"><font face="Rockwell" size="22" color="#ffffff" letterSpacing="0.000000" kerning="1"><b>Award winner</b></font></p><p align="left"><font face="Arial" size="18" color="#ffffff" letterSpacing="0.000000" kerning="1">Golden Cactus Competition</font></p>
            <p align="left"><font face="Arial" size="16" color="#ffffff" letterSpacing="0.000000" kerning="1">Client: <font face="Arial"><b>Pelephone Communications</b></font></font></p>
            <p align="left"><font face="Arial" size="14" color="#ffffff" letterSpacing="0.000000" kerning="1">+ <font face="Arial"><b>Click to Play</b></font></font></p>
            <p align="left"><font face="Rockwell" size="24" color="#ffffff" letterSpacing="0.000000" kerning="1"><b>Cooming soon...</b></font></p>
            <!-- saved from url=(0013)about:internet -->
            AC_FL_RunContent(
            'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0',
            'width', '100%',
            'height', '100%',
            'src', 'HomeSite',
            'quality', 'high',
            'pluginspage', 'http://www.adobe.com/go/getflashplayer',
            'align', 'top',
            'play', 'true',
            'loop', 'true',
            'scale', 'noscale',
            'wmode', 'transparent',
            'devicefont', 'false',
            'id', 'HomeSite',
            'bgcolor', '#ffffff',
            'name', 'HomeSite',
            'menu', 'true',
            'allowFullScreen', 'false',
            'allowScriptAccess','sameDomain',
            'movie', 'HomeSite',
            'salign', 't'
            ); //end AC code
            </script>
            <noscript>
            <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0" width="100%" height="100%" id="HomeSite" align="top">
            <param name="allowScriptAccess" value="sameDomain" />
            <param name="allowFullScreen" value="false" />
            <param name="movie" value="HomeSite.swf" /><param name="quality" value="high" /><param name="scale" value="noscale" /><param name="salign" value="t" /><param name="wmode" value="transparent" /><param name="bgcolor" value="#ffffff" /> <embed src="HomeSite.swf" quality="high" scale="noscale" salign="t" wmode="transparent" bgcolor="#ffffff" width="100%" height="100%" name="HomeSite" align="top" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/go/getflashplayer" />
            </object>
            </noscript>
            </body>
            </html>
            • 3. Re: Urgent! Help needed!
              that embedding code is faulty.
              have flash publish your html file for you and use that.
              • 4. Re: Urgent! Help needed!
                This is what Flash published for me....
                Isn't there a simple way to show what is outside the stage without using the percent dimensions?
                AC
                • 5. Re: Urgent! Help needed!
                  outside the stage??  that doesn't make sense.
                  if that code was published by flash, then you can see all the stage.  because you're publishing for 100% x 100% you expect to see no scrollbars and the browser window to be filled (either in height or width or both) with the flash stage.
                  • 6. Re: Urgent! Help needed!
                    Thanks Kglad.
                    Right, I CAN see now outside stage but the scrollers doesn't stretch enough to show everything in smaller screens.
                    Hell, why won't you just take a look:
                    http://www.avigraiver.com/animationcowboy.html
                    Shrink your browser and see the problem.
                    AC
                    • 7. Re: Urgent! Help needed!
                      you have your height set at 120%.  fix that and retest.
                      • 8. Re: Urgent! Help needed!
                        Already tested it with 100%. Still the same.
                        Any ideas?
                        • 9. Re: Urgent! Help needed!
                          Hey man, that's OK, I did it in the traditional way and it's fine now (background="filename.jpg").
                          Many thanks!
                          AC
                          • 10. Re: Urgent! Help needed!
                            you're welcome.
                            p.s.  please mark this thread as answered, if you can.
