0 Replies Latest reply on Aug 15, 2010 5:41 PM by arisco97
    Flex 4 asdoc not working on the empty project
    arisco97
      This is under purchased Flash Builder software:
      Create a Flex project, and setup asdoc under external tools with the following configuration:
      -lenient
      -source-path src
      -doc-sources src
      -main-title "Flex API Documentation"
      -window-title "Sample Project API Documentation"
      -external-library-path=libs
      The asdoc fails with the following error:
      Loading configuration file C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.1.0\frameworks\flex-config.xml
      Error at xsl:copy-of on line 109 of class-files.xslt:
        java.net.URISyntaxException: Illegal character in path at index 20: file:///C:/Documents
        and Settings/mdeliw/Adobe Flash Builder 4/sampleProject/asdoc-output/main.html
      Transformation failed: Run-time errors were reported
      Has anyone encountered this, and if yes, have they found a resolution?
