0 Replies Latest reply on Aug 15, 2010 3:48 PM by Allen Gambrell
    Cannot add more the 3 pubcollections at a time
    Allen Gambrell
      I am trying to programly add publish collections and then add images to them.
      If I try to add more the 3 inside one withWriteAccessDo block then on the 4th one I get a nil value. It will work except where it trys to create more than 3 collections!
      This is just a example of the code, not the full verion
      LrTasks.startAsyncTask( function ()
           catalog:withWriteAccessDo( "Add Collections", function ()
                local parentset = mainset
                for i,photo in ipairs(photos) do
                     parentset = publishService:createPublishedCollectionSet(word, parentset, true)
                     photocollection = publishService:createPublishedCollection(word, parentset, true)
                     photocollection:addPhotos({photo})
                end
           end)
      end)
      But if I use a withWriteAccessDo block for each image then it works correctly, except that it is much slower and I have lots of undo points vs one undo point in the first.
      example
                end)
           end
      end)
      I also tried using withProlongedWriteAccessDo with the same problem.
      I have been trying to figure this out for a while with no luck. Is it a bug?
