3 Replies Latest reply on Aug 16, 2010 6:42 AM by bindu84
    summary field operation
    bindu84
      I am using the summary field for operation (Max/Min) for date type data but it is showing NAN beacuse summary field opration take only numeric value.
      So how to use that for date type value
        • 1. Re: summary field operation
          rootsounds Level 4
          What is "data type value"?
          • 2. Re: summary field operation
            bindu84 Level 1
            data is of date Type.
            16/02/1984
            16/01/1986
            16/03/2005
            • 3. Re: summary field operation
              bindu84 Level 1
              <?xml version="1.0" encoding="utf-8" ?>
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              layout="
              vertical" initialize="init()">
              <mx:Script>
              <![CDATA[
              import mx.utils.ObjectUtil;
              import mx.formatters.DateFormatter;
              import mx.collections.ArrayCollection;
              import mx.events.AdvancedDataGridEvent;
              import mx.events.DataGridEvent;
              import mx.events.ListEvent;
              import mx.controls.List;
              import mx.events.ItemClickEvent;
              import mx.collections.IViewCursor;
              import mx.controls.Alert;
              import mx.controls.TextInput;
              Bindable]public var num1:Number;
              Bindable]public var num2:Number;
              Bindable]public var num3:Number = 1;
              Bindable]public var num4:Number = 2;
              Bindable]public var num5:Number = 3;
              Bindable]public var num6:Number = 4;
              public var newVal:String;
              Bindable]
              public var myArrayCollection:ArrayCollection;
              private function func(itr:IViewCursor,field:String,
              str:String=
              null):Object
              myArrayCollection.refresh();
              var sum:Number=0
              var max:Number;
              var dateA:Date;
              var dateB:Date;
              var res:Number;
              while(!itr.afterLast)
              //trace(itr.current)
              var value = itr.current.Date;
              dateB =
              new Date(String(value));
              res = ObjectUtil.dateCompare(dateA, dateB);
              if(dateA == null)dateA = dateB ;
              else if(res == 1) dateA = dateB ;
              else if(res == -1)dateA = dateA;
              itr.moveNext()
              var dateFormatterStr:DateFormatter = new DateFormatter();
              dateFormatterStr.formatString =
              "MM-DD-YYYY";
              var ty = dateFormatterStr.format(dateA);
              return ty;
              public function init():void {
              myArrayCollection =
              new ArrayCollection(arr);
              private function getCellInfo(event:AdvancedDataGridEvent):void {
              summaryField.summaryFunction=func;
              </mx:Script>
              <mx:Array id="arr">
              <mx:Object From="a1" Subject="a" Date="12/08/06" Profit="1"/>
              <mx:Object From="b1" Subject="b" Date="12/08/06" Profit="2"/>
              <mx:Object From="c1" Subject="c" Date="12/08/06" Profit="3"/>
              <mx:Object From="d1" Subject="d" Date="12/08/06" Profit="4"/>
              </mx:Array>
              <mx:AdvancedDataGrid id="adg" displayItemsExpanded="true"
              creationComplete="gc.refresh();"
              height="
              300" editable="true" itemEditEnd="getCellInfo(event);">
              <mx:dataProvider>
              <mx:GroupingCollection id="gc" source="{myArrayCollection}">
              <mx:Grouping>
              <mx:GroupingField name="From">
              <mx:SummaryRow summaryPlacement="last">
              <mx:fields>
              <mx:SummaryField dataField="Profit" label="summary"
              summaryFunction="
              func" id="summaryField"/>
              </mx:fields>
              </mx:SummaryRow>
              </mx:GroupingField>
              </mx:Grouping>
              </mx:GroupingCollection>
              </mx:dataProvider>
              <mx:columns>
              <mx:AdvancedDataGridColumn id="col1" dataField="From"/>
              <mx:AdvancedDataGridColumn dataField="Subject" />
              <mx:AdvancedDataGridColumn dataField="Date" />
              <mx:AdvancedDataGridColumn dataField="CC" />
              <mx:AdvancedDataGridColumn dataField="Profit"/>
              </mx:columns>
              </mx:AdvancedDataGrid>
              </mx:Application>
              n that i want to apply minimum operation on date , How to implement it ,
