2 Replies Latest reply on Aug 16, 2010 4:50 AM by Olivier.Mahieu
    Problem while building
    Olivier.Mahieu
      I receive this message while building : "An internal build error has occurred. Right-click for more information."
      When I check the log file, here is what's in it :
      !ENTRY com.adobe.flexbuilder.project 4 43 2010-08-16 11:32:59.060
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.NullPointerException
           at flex2.compiler.util.QName.hashCode(QName.java:131)
           at java.util.HashMap.get(Unknown Source)
           at flex2.compiler.util.QNameMap.get(QNameMap.java:46)
           at flex2.compiler.as3.reflect.Class.getVariable(Class.java:194)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.findEvents(DataBindingFirstPassEvaluator.java:702)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.findEvents(DataBindingFirstPassEvaluator.java:662)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.watchExpression(DataBindingFirstPassEvaluator.java:959)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:635)
           at flash.swf.tools.as3.EvaluatorAdapter.evaluate(EvaluatorAdapter.java:85)
           at macromedia.asc.parser.QualifiedExpressionNode.evaluate(QualifiedExpressionNode.java:43)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:436)
           at macromedia.asc.parser.GetExpressionNode.evaluate(GetExpressionNode.java:55)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:613)
           at macromedia.asc.parser.MemberExpressionNode.evaluate(MemberExpressionNode.java:57)
           at flash.swf.tools.as3.EvaluatorAdapter.evaluate(EvaluatorAdapter.java:316)
           at macromedia.asc.parser.ListNode.evaluate(ListNode.java:44)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:224)
           at macromedia.asc.parser.ArgumentListNode.evaluate(ArgumentListNode.java:45)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:651)
           at macromedia.asc.parser.SetExpressionNode.evaluate(SetExpressionNode.java:58)
           at flash.swf.tools.as3.EvaluatorAdapter.evaluate(EvaluatorAdapter.java:359)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:405)
           at macromedia.asc.parser.FunctionCommonNode.evaluate(FunctionCommonNode.java:104)
           at flex2.compiler.as3.binding.DataBindingFirstPassEvaluator.evaluate(DataBindingFirstPassEvaluator.java:325)
           at macromedia.asc.parser.ClassDefinitionNode.evaluate(ClassDefinitionNode.java:106)
           at flash.swf.tools.as3.EvaluatorAdapter.evaluate(EvaluatorAdapter.java:338)
           at macromedia.asc.parser.StatementListNode.evaluate(StatementListNode.java:60)
           at flash.swf.tools.as3.EvaluatorAdapter.evaluate(EvaluatorAdapter.java:923)
           at macromedia.asc.parser.ProgramNode.evaluate(ProgramNode.java:80)
           at flex2.compiler.as3.binding.DataBindingExtension.generate(DataBindingExtension.java:87)
           at flex2.compiler.as3.Compiler.generate(Compiler.java:808)
           at flex2.compiler.mxml.ImplementationCompiler.generate(ImplementationCompiler.java:308)
           at flex2.compiler.mxml.Compiler.generate(Compiler.java:159)
           at flex2.compiler.API.generate(API.java:3558)
           at flex2.compiler.API.generate(API.java:3521)
           at flex2.compiler.API.batch2(API.java:420)
           at flex2.compiler.API.batch(API.java:1121)
           at flex2.compiler.API.compile(API.java:1308)
           at flex2.tools.oem.Application.compile(Application.java:1086)
           at flex2.tools.oem.Application.recompile(Application.java:1038)
           at flex2.tools.oem.Application.compile(Application.java:790)
           at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication.java:354)
           at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder$MyBuilder.mybuild(ASApplicationBuilder.java:271)
           at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.build(ASApplicationBuilder.java:122)
           at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBuilder.java:139)
           at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.build(ASItemBuilder.java:73)
           at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(Unknown Source)
           at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(Unknown Source)
           at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(Unknown Source)
           at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:624)
           at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
           at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:166)
           at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:197)
           at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:246)
           at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:249)
           at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:302)
           at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:334)
           at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:137)
           at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
           at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
      Can someone help me solve this problem ?
      I only modified some minor things since last build ...
      Thanks in advance !
