• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Fatal Error: Unexpected error from Microsoft HTML Compiler
Enthusiast ,
Jul 30, 2007 Jul 30, 2007
I'm using RH 6 with Vista (yes I know Vista is not supported, but I'm one of the few that has to have it, so I'm using the tweaked unsupported version)
Sometimes when generating a CHM output (Compiled HTML Help) right after the "Compacting file system..." step I get an error that says "Fatal Error: Unexpected error from Microsoft HTML Compiler".
I'm not sure what causes it. I don't get it all the time, but I seem to get it more often than not. However, it doesn't seem to do anything adverse to the compiled help file. Well, not that I can see anyway.
Any information on what causes this and how I can fix it?
Views
796
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Hi JaredHess
Personally I'll be pretty surprised if you are able to obtain a definitive answer here. I've just installed Vista last week in a new dual boot configuration. Unfortunately, I've not been able to play with it since, as I have paying work with RoboHelp and Captivate classes. Hence, I've been back in the world of Windows XP. I'm not claiming I'm *the* source for RoboHelp information here, only that I like to think I'm a reasonably "techie" sort of guy and I'm just now getting around to installing Vista. So I'm guessing that odds are, not many have.
Anyhoo, I do wish you the very best of luck in getting it sorted. I'll definitely be watching for any responses offered here so I may learn something new!
Cheers... Rick
Votes
Translate
Translate
Report
Report
Contributor ,
I've experienced the same message on a XP system several times, without being able to nail the problem down. In most cases it seems to be connected to illegal entries in the HHP generated by RH.
If you see, e.g., absolute paths in the HHP, you should - after the obligatory backup - delete the project's CPD, open the project again, have some coffee, and try again.
Hope this helps.
---Dirk Bock
Votes
Translate
Translate
Report
Report
Enthusiast ,
Jul 31, 2007 Jul 31, 2007
Thanks RoboWizard, I don't think this is a Vista-specific problem.
Dirk, I tried your solution, but I still get the error. I just noticed on some .htm files that my images aren't appearing in the compiled html help file. I don't know if this problem is due to this error or something else. The .htm files when viewed in a web browser show the missing images.
Votes
Translate
Translate
Report
Report
Contributor ,
If deletion of the CPD doesn't work, there seems to be more amiss in the HHP.
Have you had a look at the new version of the HHP-file?
Your missing images are due to another problem: I guess you have images linked to from imported topics. During import RH copies all necessary files to the appropriate relative locations, but it does not 'recognize' new folders created during this step. For the compilation RH copies all the stuff it thinks belong to the project to a temp folder, but 'unrecognized' files are ignored, thus missing in the compiled help.
Use Windows explorer to note where linked images are situated and 'create' these folders within RH via the context menu of the Project Explorer's folders 'HTML Files' section. This way RH suddenly recognizes the folders and is able to handle the images therein.
Perhaps some unrecognized folders are responsible for compiler crash, too?
Regards
---Dirk Bock
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 03, 2007 Aug 03, 2007
Fixed my images...
(I don't know what happened but a lot of stuff went bezerk with my project and I had to do a lot of topic reimporting since several of them went MIA...)
Anyway, things are back to where they were before I posted. Still getting this "Unexpected error"-- Actually, I'm starting to expect it more and more. You asked if I had a look at the new version of the .hhp file. What exactly should I be looking for?
Votes
Translate
Translate
Report
Report
Contributor ,
Aug 05, 2007 Aug 05, 2007
If this error turns up after the message "... compacting the file system", this means that the FILES section of the hhp has been processed correctly. Look after the FILEs section, and pay special attention to the BAGGAGE section of the HHP file; in our case some non-existing file showed up in this place.
---Dirk Bock
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 07, 2007 Aug 07, 2007
I don't see a BAGGAGE section in my hhp file... I don't think that's a valid section for the hhp file is it?
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
BAGGAGE is a valid, albeit not a necessary one.
My remote debugging skills are at an end now. You could send me a PM for other options.
---Dirk Bock
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
