3 Replies Latest reply on Aug 17, 2010 2:57 PM by laxmidi
    Is It Possible to Use a Function When Creating an Array?
    laxmidi Level 1
      Is it possible to use a function when building an array?
      I'd like to iterate my data returned from the db and call a function. The part where I call the function "myFunction[i]" doesn't seem to work. How do I solve this problem? I need to put the results of the function call into the array.
      var i:uint;
      for (i=0; i<myDataArray.length; i++)
      dgArray = [{Name: myDataArray[i].name, Type: myFunction[i]}];
      Thank you!
      -Laxmidi
        • 1. Re: Is It Possible to Use a Function When Creating an Array?
          BhaskerChari Level 4
          Hi laxmi,
          Yes ofcourse it is very much possible to use a Function when creating an array...In your code you have made some mistakes..
          You have used square bracket for calling the function myFunction[i]....where you are supposed to use parantheses.....myFunction(i)...and other this is you need to push the object into the dgArray but yous hould not not assign it...
          dgArray = [{Name: myDataArray[i].name, Type: myFunction[i]}]; // this will result in only the last iterated Array to be in dgArray..
          So you should write  dgArray.push({Name: myDataArray[i].name, Type: myFunction(i)});
          Check out the code below....
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
          <mx:Script>
            <![CDATA[
             private var dgArray:Array = new Array();
             private var myDataArray:Array = [{data:"1", name:"Ramu"},{data:"2", name:"Sharath"},{data:"3", name:"Bharath"}]
             private function init():void
              for (var i:int=0; i<myDataArray.length; i++)
             private function myFunction(i:int):String
              return "Type" + i;
          </mx:Script>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Is It Possible to Use a Function When Creating an Array?
            Subeesh Arakkan Level 4
            Message was removed by: Subeesh Arakkan
            • 3. Re: Is It Possible to Use a Function When Creating an Array?
              laxmidi Level 1
              Hi Bhasker Chari,
              Thank you very much for your detailed reply! I really appreciate your help.
              -Laxmidi
