This content has been marked as final.
Show 4 replies
1. Re: Sounds, Timelines, Controls, Oh My!
Newsgroup_User Aug 15, 2006 7:05 AM (in response to THEwagner)THEwagner,
> I have created buttons in the main SWF that pauses and
> plays the external SWFs, but I don?t know how to pause
> and play the audio track embedded within the same timeline.
Ah, that simply depends on how you embedded the audio.
> (example: User hits pause: Animation and associated
> narration stop. User hits play: Animation and associated
> narration continue.)
That will happen automatically if the audio is set to Stream in the Sync
setting of the Property inspector. I'm guessing you have a number of small
sounds set to Event. If that's the case, audio loads into memory as soon as
the frame is entered, which means the audio is not played in-step with the
timeline. If you set all those sounds (or one big long one) to Stream, you
can actually "scrub" the audio by dragging the playhead back and forth while
you edit.
David Stiller
Adobe Community Expert
Dev blog, http://www.quip.net/blog/
"Luck is the residue of good design."
2. Re: Sounds, Timelines, Controls, Oh My!
kglad Aug 15, 2006 7:12 AM (in response to THEwagner)you need to use the sound object in your external swfs and not use sounds attached to frames. you can then use the position property of the sound object along with its start() and stop() methods to allow pause and play of your sounds. -
3. Re: Sounds, Timelines, Controls, Oh My!
THEwagner Aug 15, 2006 8:02 AM (in response to THEwagner)When I deleted the audio layer, opened the property inspector and set it to "Stream" BEFORE I dragged the MP3 to the timeline, all of my simple actions worked. I guess I must of dragged the MP3 to the timeline as "Event" and couldn't change it to "Stream" after the fact.
In regards to kglad's suggestion, wouldn't it be more difficult to synchronize animation with narration if the audio track was out side of the SWF? -
4. Re: Sounds, Timelines, Controls, Oh My!
Newsgroup_User Aug 15, 2006 8:31 AM (in response to THEwagner)THEwagner,
> after the fact.
It's not the layer that gets this setting, but the frame into which you
drag your audio. Click into that frame and keep an eye on the Property
inspector. You can change the Synch mode as often as you please once the
audio is in place.
David Stiller
