11 Replies Latest reply on Aug 19, 2010 10:19 PM by kiran7881
    Flex 3 Passing Data using Custom Componets
    kiran7881 Level 1
      Hi , i am trying to  communicate using Custom Events .
      Means when the user Logins on to a Form .
      I am creating a Obkect of my User VO of ActionScript class and
      var user:User  = new User();
      user.name = UITI.text;
      user.pass = PWDTI.text;
      this.dispatchEvent(new LoginEvent(User));
      Now another component is actually listening to this data . Please let me know how can i recive this Logged In data in this component .
      Here in thisComponent i am listeing to this data :
      <mx:DsiplayComponnet creationComplete = "recivedata()">
      public function recivedata():void
      this.addEventListener(LoginEvent , datahandling);
      public function datahandling():void
      // Need logic here as how to recive data
      </mx:DsiplayComponnet
      Please help me .
      Thanks in advnace .
        • 1. Re: Flex 3 Passing Data using Custom Componets
          BhaskerChari Level 4
          Hi Kiran,
          The way you dispatching the events and listening is wrong...
          Can you please post your LoginEvent class file...???
          Bhasker
          • 2. Re: Flex 3 Passing Data using Custom Componets
            ShardulSingh Level 3
            First create the Login event as below :-
            package
                import flash.events.Event;
                public class LoginEvent extends Event
                    public static const LOGIN_EVENT:String = "LoginEvent";
                    public var userData : Object;
                    public function LoginEvent(type:String,userData : Object,bubbles:Boolean = false, cancelable:Boolean = false)
                        super(type,bubbles,cancelable)
                        this.userData = userData;
                    override public function clone():Event
                        return new LoginEvent(type,userData, bubbles, cancelable);
            Now dispatch the event from where you are dispatching. and dont send User instead send
            user.Like this :-
            dispatchEvent(new LoginEvent(LoginEvent.LOGIN_EVENT,user);
            And where you are listining write function as:-
            public function datahandling(event : LoginEvent):void
                  var user : User= event.userData as  User
                 //You will reach here do any thing here .
            Hope this will help you.
            with Regards,
            Shardul Singh Bartwal
            • 3. Re: Flex 3 Passing Data using Custom Componets
              kiran7881 Level 1
              Thank you very much Shardul ,
              But i didn't undersdtand this "event.userData " in the above line . can you please elobrate this .
              Thanks in advnace .
              • 4. Re: Flex 3 Passing Data using Custom Componets
                kiran7881 Level 1
                Ya , i understood that userData is a Property of the Event .
                Thanks sir .
                • 5. Re: Flex 3 Passing Data using Custom Componets
                  kiran7881 Level 1
                  Hi , Sorry to reopen this question , as i was unable to pass Data When working CustomObjects . Please see my Entire code and let me know where i am actually doing  wrong .
                  This is my Event :
                  LoginEvent.as
                  Here in this case , i am trying to pass the DTO Object with the help of the Event class
                  package events
                      import vo.User;
                          public var user : User;
                          public function LoginEvent(type:String,user:User,bubbles:Boolean = false, cancelable:Boolean = false)
                              this.user = user;
                              return new LoginEvent(type,user, bubbles, cancelable);
                  This is my VO :
                  package vo
                      public class User
                          public var uname:String;
                          public var pass:String;
                          public function User()
                  This is my MXML FIle where i am actually dispatching the Event and passing the Data in it to another Module which is actually listening to it .
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                  <mx:Script>
                      <![CDATA[
                          import mx.modules.ModuleLoader;
                          import vo.User;
                          import events.LoginEvent;
                          public function CallMe():void
                              user.uname = UITI.text;
                              this.dispatchEvent(new LoginEvent(LoginEvent.LOGIN_EVENT,user));
                              var ml:ModuleLoader = new ModuleLoader();
                              ml.url = "/Test.swf";
                  </mx:Script>
                      <mx:Form x="183" y="179">
                          <mx:FormItem label="Label">
                              <mx:TextInput  id="UITI" />
                          </mx:FormItem>
                              <mx:TextInput id="PWDTI"/>
                              <mx:Button label="Button" click="CallMe()"/>
                          </mx:FormItem>
                      </mx:Form>
                  </mx:Application>
                  This is my Module Component , which is actually listening to the LoginEvent .
                  <mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400" height="300"  creationComplete="listen()">
                      <mx:Script>
                      <![CDATA[
                          import mx.controls.Alert;
                          import vo.User;
                              public function listen():void
                                  Alert("Hai");
                                  this.addEventListener(LoginEvent.LOGIN_EVENT , datahandling);
                              public function datahandling(event:LoginEvent):void
                  var user : User= event.user as  User
                  Alert.show(user.pass);
                  Alert.show(user.uname);
                  </mx:Script>
                  </mx:Module>
                  Please help me in solving this thing .
                  Thanks in advance .
                  • 6. Re: Flex 3 Passing Data using Custom Componets
                    Hi Kiran,
                    Replace your Application and Module files with the below code and check whether your LoginEvent is being listened now...in Module..
                    Please try this once and let me know....
                    <mx:Script>
                        <![CDATA[
                            import vo.User;
                                ml.addEventListener("ready", onReady);
                            public function onReady(event:Event):void
                       systemManager.dispatchEvent(new LoginEvent(LoginEvent.LOGIN_EVENT,user));
                    </mx:Script>
                            </mx:FormItem>
                            </mx:FormItem>
                        </mx:Form>
                    </mx:Application>
                    .........Module File.......
                    <mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400" height="300"  preinitialize="listen()">
                        <mx:Script>
                        <![CDATA[
                            import vo.User;
                                    Alert("Hai");
                                    systemManager.addEventListener(LoginEvent.LOGIN_EVENT , datahandling);
                                 systemManager.removeEventListener(LoginEvent.LOGIN_EVENT , datahandling);
                    </mx:Script>
                    </mx:Module>
                    Bhasker Chari
                    • 7. Re: Flex 3 Passing Data using Custom Componets
                      kiran7881 Level 1
                      Thanks Bhaskar for the reply ,
                      I am new to Flex , so i am asking this question , correct me if i am wrong .
                      Is the below line necessary here ??
                      Can't i directly use this line
                      systemManager.dispatchEvent(new LoginEvent(LoginEvent.LOGIN_EVENT,user));    and remove the above line ??
                      Please let me know this . thanks
                      • 8. Re: Flex 3 Passing Data using Custom Componets
                        Hi Kiran,
                        Actually the above line is very necessary as you are trying to dispatch the LoginEvent before the eventListener is registered....I mean you are first
                        dispatching the event and then after you are loading the Module.....How do you think the component will listen for that event when your Module component
                        is not yet loaded...
                        So first you need to wait for the Module to be loaded and eventLisner to be registered first before you dispatch the event....Also try to register the
                        eventListener in the preInitialize of your Module as I posted the same in my last post...
                        Hope you got my point and what is the mistake you had done...
                        Bhasker
                        • 9. Re: Flex 3 Passing Data using Custom Componets
                          kiran7881 Level 1
                          Thanks Bhaskar , the above were lines were very useful .
                          Thanks once again
                          • 10. Re: Flex 3 Passing Data using Custom Componets
                            Hi Kiran,
                            Is it working for you now...?? Have you tested it whether the event is being listened in your Module Component..
                            Bhasker
                            • 11. Re: Flex 3 Passing Data using Custom Componets
                              kiran7881 Level 1
                              Hi Bhaskar ,
                              Sorry for the late reply as i don't have Flex Builder at my work place .
                              It still didn't worked , i made some changes as required
                              Defined user variable as global (Outside the function of  CallMe()) , added ml.loadModule(); for the above code .
                              I am only pasting the Modified code .
                                          user.uname = "fdsa"; // Hradcoded currently
                                          user.pass = "cxcds"; //
                                          ml.loadModule();
                              Used creationComplete inside the ModuleComponnet instead of preinitialize as it is giving me some error .
                                  <mx:Script>
                                  <![CDATA[
                                      import vo.User;
                                        var user : User= event.user as  User ;
                                  Alert.show(user.pass.toString());
                                  Alert.show(user.uname.toString());
                              While debugging and using Dtrp Over (F6) its going to some unrelated classes ,  such as FocusManager and functions by name  deactivateHandler
                              For example this thing .
                                   *  @private  Useful for debugging
                                  private function deactivateHandler(event:Event):void
                                      var target:InteractiveObject = InteractiveObject(event.target);
                                      // trace("FM " + this + " deactivateHandler ", lastFocus);
                              Any help ??
