1. Re: AE CS5 not using all memory and cpu
Todd_Kopriva Aug 17, 2010 5:43 AM (in response to eVatrik)Not all rendering operations will max out all RAM and all CPUs (processor cores). Some rendering operations are I/O intensive; some are memory-intensive; some are CPU-intensive. If, for example, I/O is the bottleneck, then you won't see either CPU or RAM usage maxed.
Also, the goal isn't to see that 100% of the CPU and 100% of of RAM is being used. The goal is faster rendering (and other operations). Sometimes greatest performance is achieved when there's "headroom" left over for other activity. See this page.
Are you using Render Multiple Frames Simultaneously multiprocessing? That is one feature that really benefits from having a lot of RAM. The 6GB of RAM that you have in your system is not enough to make effective use of that feature. See this page.
Here's a page that collects information about how to optimize for performance.
2. Re: AE CS5 not using all memory and cpu
eVatrik Aug 18, 2010 3:34 AM (in response to Todd_Kopriva)Thanks for reply
Can I get a little bit faster rendering using After Effects Render Engine alone. I know it`s the same as in after effects, but maybe if it`s running alone without other after effects panels it`s better.
And I also tried to render using openGL with gtx 285 graphic card, but the rendered video is not as good quality as when I render with CPU.
Why is like that?
3. Re: AE CS5 not using all memory and cpu
Todd_Kopriva Aug 18, 2010 8:01 AM (in response to eVatrik)>And I also tried to render using openGL with gtx 285 graphic card, but the rendered video is not as good quality as when I render with CPU.
Why is like that?
In After Effects, the OpenGL renderer is just a preview renderer; it's not intended for high-quality final renders. Writing rendering code for a GPU is different than writing rendering code for a CPU, and we don't waste our time rewriting every part of the rendering pipeline on the GPU to match that on the CPU.
To reiterate: OpenGL rendering is just intended for fast previews when doing things like placing 3D layers.
I only use the OpenGL - Interactive mode.
4. Re: AE CS5 not using all memory and cpu
artmanphil11 Dec 15, 2010 8:21 AM (in response to Todd_Kopriva)Also, the goal isn't to see that 100% of the CPU and 100% of of RAM is being used. The goal is faster rendering (and other operations). Sometimes greatest performance is achieved when there's "headroom" left over for other activity.
I disagree. How should unused ressources make anything faster? If I want to render, I don't want to do anything besides rendering!
100% ram used (afx using installed memory minus os-required-memory) would make my rendering extremely fast, if I am doing a ram-intensive job, same with cpu for cpu-intensive frames.
20% ram used and 20% cpu used is slower, than 100%. Every 3D-application and even some render-manager-add-ons for after effects handle that and make the renderings way much faster.
So why doest afterFX have to be the bottleneck because of some sort of "maybe you need some free memory to do something else besides rendering"-agreement? Instead, I would prefer to say "hey afterFX, use all free ressources" - if I would like to do something else, I use the switch "use only xy amount of ram".
5. Re: AE CS5 not using all memory and cpu
Dave LaRonde Dec 17, 2010 2:54 PM (in response to artmanphil11)artmanphil11 wrote:
Because there are spots in an AE comp that WILL make use of more RAM and WILL be more processor-intensive. That's just the way some of the effects and features in AE work. If you max it out, you're shooting yourself in the foot, plain 'n simple.
