9 Replies Latest reply on Aug 18, 2010 7:07 AM by kglad
    On Rollover Action
    scalhoun11
      I'm creating a quiz where a user picks up some text and drops it into a box (simple drag n drop scenario). The problem is when a user rolls over the answer box with the text I need some actions to execute but they won't. The usual on(rollover) commands don't work because the mouse is pressed down since the user is dragging text. Any way around this?
      I tried a my_mc.onEnterFrame command with a hitTest which works but then it loops repeatedly. I then deleted onEnterframe, which works the first time but then is deleted, so when I need to drop a second answer into that same answer box doesn't do anything. This didn't seem like the most elegant solution anyway. (Actually, just so I would know, is there a way to reinstate or restore a deleted onEnterFrame command?)
      commands for answer text:
      on (press) {
          this.startDrag();
      on (release, releaseOutside) {
          if (this._droptarget == "/answer1")
          {// answer is right
              trace("right answer")
          else
          {// answer is wrong
            trace("wrong")
          this.stopDrag();
      commands for answer box:
      on(rollOver) {
           trace("answer box")
        • 1. Re: On Rollover Action
          you can use a loop and hitTest to see if the mouse is over a hotspot when dragging an object that interferes with mouse events.
          • 2. Re: On Rollover Action
            scalhoun11 Level 1
            Do you mean using a while loop? Or for? Could you post a little sample code? Thanks.
            • 3. Re: On Rollover Action
              no, you could use an enterframe loop or setinterval loop or mousemove loop.  i see you used an enterframe loop but had some trouble.  show the enterframe loop you were using.
              • 4. Re: On Rollover Action
                scalhoun11 Level 1
                my_mc.onEnterFrame = function()
                    if (my_mc.hitTest(_xmouse, _ymouse, true))
                        trace("test");
                        delete this.onEnterFrame;
                This works the first time and the word "test" is traced. The problem then is I need to it to work additional times but it's been deleted. And if I removed the delete it just traces test repeatedly which I don't want either.
                • 5. Re: On Rollover Action
                  when do you want that trace("test") to execute?  when you rollover my_mc while something's being dragged?  if yes, does it matter what's being dragged?
                  • 6. Re: On Rollover Action
                    scalhoun11 Level 1
                    Yea, so the full code would be:
                    This is correct answer text:
                    on (press) {
                        this.startDrag();
                    on (release) {
                        if (this._droptarget == "/answer1_mc")
                        {// answer is right
                        else
                        {// answer is wrong
                          trace("wrong")
                        this.stopDrag();
                    This is the correct answer box:
                    answer1_mc.onEnterFrame = function()
                        if (answer1.hitTest(_xmouse, _ymouse, true))
                            trace("test");
                    So when a user picks up the first answer box and rolls over answer1_mc then a trace or something should happen. Currently nothing happens until the answer is released.
                    • 7. Re: On Rollover Action
                      use:
                      answer1_box.onPress=function(){
                      this.startDrag();
                      this.onMouseMove=function(){
                      if(answer1.hitTest(_xmouse,_ymouse)){
                      trace('test");
                      delete this.onMouseMove;
                      answer1_box.onRelease=function() {
                          {// answer is right
                          else
                          {// answer is wrong
                            trace("wrong")
                          this.stopDrag();
                      • 8. Re: On Rollover Action
                        scalhoun11 Level 1
                        Wonderful. Thanks. Sorry for the confusing naming. I wasn't as concerned about names and such just trying to find the right bit of code. Thanks kglad.
                        • 9. Re: On Rollover Action
                          you're welcome.
