24 Replies Latest reply on Jul 7, 2015 1:00 AM by Ali Abu Ras
    Strobe Media Playback with AIR ?
    drumaddict71 Level 1
      Does anybody know how to  use the Strobe Media Playback Player in an AIR application?
      I need to skip all the configuration that comes from flashvars,I tried to modify the source code but it's a headache.
        • 1. Re: Strobe Media Playback with AIR ?
          Andrian Cucu Adobe Employee
          Here is a snippet which would load the player in an AIR app:
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
             xmlns:mx="library://ns.adobe.com/flex/mx"
             creationComplete ="init(event)">
          <fx:Script>
          <![CDATA[
          import mx.core.UIComponent;
          protected function init(event:Event):void
          var playerInstance:StrobeMediaPlayback = new StrobeMediaPlayback();
          var parameters:Object =
          src:"http://mediapm.edgesuite.net/strobe/content/test/AFaerysTale_sylviaApostol_640_500_short.f lv"
          playerInstance.initialize(parameters, systemManager.stage);
          var ui:UIComponent = new UIComponent();
          ui.addChild(playerInstance as DisplayObject);
          addElement(ui);
          </fx:Script>
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          </s:WindowedApplication>
          Unfortunately the control bar will not display since it tries to access the stage property directly. We didn't test AIR integration at all, since this was out of scope for our 1.0 version.
          You can try and fix this in the source code. A patch for this would be more then welcome!
          • 2. Re: Strobe Media Playback with AIR ?
            Actually, the control bar is displayed, but it is drawn under the status bar.
            Use these settings to see the control bar.
            , controlBarMode:"floating"
            , controlBarAutoHide:"false"
            Do you know if there is a way to remove the status bar of the air app?
            I hope that the snipets above are enough to get you started.
            Cheers,
            Andrian
            • 3. Re: Strobe Media Playback with AIR ?
              Hey Andrian,thanks for the quick reply.
              The player is added on the stage (why full screen??) but I get  a compile error:
              Error: Error #2067: The ExternalInterface is not available in this container. ExternalInterface requires Internet Explorer ActiveX, Firefox, Mozilla 1.7.5 and greater, or other browsers that support NPRuntime.
              Obviously it's trying  to communicate with the browser to get the flashvars.
              I tried to comment out some configuration code in StrobeMediaPlayback.as,but no luck.
              This beautiful player seems like was not meant to live on the Desktop,such a shame!
              • 4. Re: Strobe Media Playback with AIR ?
                You need to turn the CONFIG::LOGGING compile option to false for both your AIR app and the OSMF lib, and you'll get rid of the compile error.
                -define CONFIG::LOGGING false -define CONFIG::FLASH_10_1 true
                -Andrian
                • 5. Re: Strobe Media Playback with AIR ?
                  Slip of the tongue:It was not a compile error,it was a RUNTIME error,otherwise I would'nt be able to run the application at all,right?
                  I have already taken care of the compile options and experimented with all possibilities.
                  Did  you  actually get this to work?In  StrobeMediaPlayer.as  there's  initializing code that configures the player to read flashvars from the browser and the config .xml file,I can't see how  this will  work in AIR without modifying this configuration code.
                  In the meantime I found in the OSMF blog this post about a Desktop player built with OSMF-source provided and all  ,but it is very basic and with limited functionality.I tried it and it works.
                  • 6. Re: Strobe Media Playback with AIR ?
                    Yes, the snippet above works for me even though there is small layout issue (which I think that you can fix easily in under one hour once you get it compile and run).
                    • 7. Re: Strobe Media Playback with AIR ?
                      Hi drumaddict71,
                      Did you manage to get StrobeMediaPlayer player run in an AIR application?
                      If you still encounter issues with it, please report them here: http://bugs.adobe.com/jira/browse/ST
                      We'll try to address them as soon as possible. You can also request a sample air application, as an improvement request.
                      Thank You,
                      -Andrian
                      • 8. Re: Strobe Media Playback with AIR ?
                        Hey Andrian,thanks for your intesrest.
                        The player compiled with no errors,I got the player on the stage.however I get the runtime error about External Interface.
                        Does it make sense to report a bug?The StrobePlayer was not built for the Desktop.The Desktop player I linked to in my previous post,built with OSMF,
                        works but has limited functionality.
                        I don't  have time to insist on this subject,maybe I am missing something, so I switched to Flex 4's Video Player-which by the way works  only with the old  osmf swc that comes with Flash Builder and NOT with the new 1.0 swc.(now THAT's a bug.You get a weird Dimension Event compile error with unknown source-wasted one day to solve the problem).
                        Again,thank you so much for your interest.
                        • 9. Re: Strobe Media Playback with AIR ?
                          I published a sample AIR application:
                          http://smpfmp.appspot.com/SMPAir.air
                          Here is the zip with the source code of the project: http://smpfmp.appspot.com/SMPAir.zip
                          Here is the mxml file: http://smpfmp.appspot.com/SMPAir.mxml
                          The sample loads dynamically the StrobeMediaPlayback.swf.
                          I commented out the sample code that uses a statically linked StrobeMediaPlayback (the snippet that I used in the posts above). You can use it if you manage to get all the compile options/settings right.
                          As I wrote previously, the player will use the whole stage size for it's display. Please, log this bug, as well as any other issues and improvement requests.
                          Let me know if the sample unblocks you.
                          -Andrian
                          P. S. If you have ExternalInterface calls it's very likely that you have -define CONFIG::LOGGING true, instead of -define CONFIG::LOGGING false in your compiler options.
                          • 10. Re: Strobe Media Playback with AIR ?
                            Adrian,you are the man!
                            The dynamic version worked,however I didnt get the static version to work.Here's the modified code,got rid of the unecessary loader stuff
                              showStatusBar = "false"
                            <fx:Script>
                            <![CDATA[
                            [Embed(source='/StrobeMediaPlayback.swf')]        ????(it was not in the source!)
                               private var StrobeMediaPlayback:Class;
                            _stage = systemManager.stage;
                            _stage.align = StageAlign.TOP_LEFT;
                            _parameters  =
                            // For statically linked StrobeMediaPlayback you can use this snippet
                            var playerClass:Class = getDefinitionByName("StrobeMediaPlayback") as Class;
                            var playerInstance:Object = new playerClass();
                            playerInstance.initialize(_parameters, _stage);
                            addElement(ui);
                            private var _stage:Stage;
                            private var _parameters:Object;
                            /* static */
                            private static const ALLOW_LOAD_BYTES_CODE_EXECUTION:String = "allowLoadBytesCodeExecution";
                            </fx:Script>
                            <fx:Declarations>
                            </fx:Declarations>
                            The problem is I did'nt find any  StrobeMediaPlayback.swf   in the source of your project to embed,so I just grabbed the StrobeMediaPlayback.swf  from the StrobeMediaPlayback download,and also tried the swf in the bin folder of the StrobeMediaPlayback Flex Project.
                            I got a runtime error
                            ReferenceError: Error #1065: Variable StrobeMediaPlayback is not defined.
                            I will appreciate your help,(again)!
                            • 11. Re: Strobe Media Playback with AIR ?
                              Hi drumaddict71,
                              Here are the steps to make the player use the staticaly linked StrobeMediaPlayer:
                              1. Reference the OSMF library
                              2. Add the source code of the StrobeMediaPlayback to your source path
                              3. Add the assets.swc (from StrobeMediaPlayback/assets/) to the compile path
                              4. Set the compile settings to -define CONFIG::LOGGING false -define CONFIG::FLASH_10_1 true for both OSMF and your AIR project.
                              The embed should not be there. I simply did an experiment and forgot to remove that instruction.
                              hth,
                              Andrian
                              • 12. Re: Strobe Media Playback with AIR ?
                                OK,so I included  StrobeMediaPlayback.as and all the imports it needed.I used the the OSMF swc from your project and did not bother to complile the library,the compile settings were exactly as you suggested and ...It worked TOO well.The Player appeared :  NOT in full screen mode!!??
                                I made a copy of your original mxml file and modified it for the static version,and then set it as the  default application in your  SMPAir project.I did a clean build just to make sure I was not running the previous dynamically loaded version,I even removed your original mxml file and did  a clean build ,and the player ran perfectly NOT in full screen.
                                (the full screen button worked of course...).Weird....
                                Anyway thank you SO much for your help!
                                • 13. Re: Strobe Media Playback with AIR ?
                                  OK,forget my previous ranting,the player will  fill all the Window  Area,I just got confused because I did'nt set any dimensions for the Windowed Application.Again,thank you so much!
                                  • 14. Re: Strobe Media Playback with AIR ?
                                    335098 Level 1
                                    Hi Andrian,
                                    I tried it your way and it just won't work. The StrobeMediaPlayer class cannot be found by Flash Builder. I keep getting the error "1046: Type was not found or was not a compile-time constant" Could you explicit the #2 step (thought it was explicit enough but apparently it is not)..? Thanks a lot
                                    • 15. Re: Strobe Media Playback with AIR ?
                                      AJConsulting Level 1
                                      Hi Andrian,
                                      Working on an app for iOS with Flex 4.5.1 and utilizing some of you SMPAir code, i am able to play FLV on an iPad but not any mp4 video (using the OSMF sample videos). Any reasons you know of?
                                      • 16. Re: Strobe Media Playback with AIR ?
                                        smarcus99 Level 1
                                        Bump!
                                        The comments in the SMP code around fullscreen and StageVideo state that things are not yet finalised --
                                        and I forgot to ask about AIR/iOS support for SMP during the most recent webinar.
                                        As of Flex 4.5.1 VideoDisplay and VideoPlayer are still marked as "not mobile optimised" -- although dropping in the latest osmf.swc (and removing the SDK's osmf.swc) does let you play H.264 progressive video in the iPad emulator at least.
                                        Can anyone clarify the best approach for a "full-featured" video player for H.264 in a Flex 4.5.1/4.6 app targeting AIR/iOS?
                                        Thank in advance!
                                        S
                                        • 17. Re: Strobe Media Playback with AIR ?
                                          obirocks Level 1
                                          Hi Andrian, tried to use your source and got the dynamic version to play, which worked fine exept that the stage video is not working (The VideoInfoOverlay tells me so). Whats the benefit of using the static version anyways?
                                          i'm using a sdk mix from 4.5.1 and air 3.0 as seen from http://blogs.cynergysystems.com/2011/09/20/creating-a-custom-flex-4-5-sdk-to-target-flash- 11-and-air-3/ and the latest osmf 1.6 version..
                                          i am using an rtmfp stream, which works fine and as it should when i test it in the setup.html, where it shows that hardware video rendering is active and stagevideo is available
                                          also set the
                                          OSMFSettings.enableStageVideo = true;
                                          and tried it for the player with
                                          playerInstance.configuration.enableStageVideo = true;
                                          which didn't seem to work.
                                          what am i missing? help would be very appreciated
                                          my flash player version is 11.0.1
                                          • 18. Re: Strobe Media Playback with AIR ?
                                            smarcus99 Level 1
                                            Trying to keep this thread alive..
                                            Here's a link to a blog post that says that setting the swf-version and renderMode is required to achieve H.264 playback via AIR3 on iOS:
                                            http://www.randytroppmann.com/2011/10/07/air-3-enables-hardware-decoding-of-h-264-video-in -ios-apps/
                                            I've tried this using AIR3 on iOS5 using osmf-1.6.1 and Flex 4.5.1's spark:VideoDisplay.
                                            It works in the emulator but it doesn't work on the device.
                                            I will report back after testing with a custom build of osmf-trunk and using SMP instead of VideoDisplay.
                                            Would be great to get a definitive statement from Adobe about all this...
                                            TIA
                                            S
                                            • 19. Re: Strobe Media Playback with AIR ?
                                              obirocks Level 1
                                              Hi smarcus,
                                              i am very interested in wether/how you got an AIR3 Project with OSMF to work in the emulator, with hardware video rendering active.. as i fail to even achieve that.. could you by any chance post an example code and describe your project setup? I'd really appreciate the effort!
                                              regards
                                              • 20. Re: Strobe Media Playback with AIR ?
                                                smarcus99 Level 1
                                                Here's what I did:
                                                + overlay AIR 3 SDK on Flex SDK 4.5.1 to create a custom SDK
                                                + update the custom SDK with playerglobal.swc for Flash Player 11
                                                + create a new mobile application using custom SDK
                                                + remove osmf.swc from the default libraries in the Flash Builder project
                                                + set -swf-version=13 in compiler options
                                                + add a src folder to the project: osmf-trunk/framework/OSMF
                                                + set the additional compiler options for OSMF
                                                + set renderMode in the app descriptor to gpu (or direct?)
                                                At this stage, building a really simple AIR app using the spark VideoDisplay class _should_ work.
                                                I used the AIR sample code linked to above as a starting point and got something that worked in the emulator -- and was excited!
                                                Unfortunately, on the device (iPad2/iOS5), an H.264 clip either crashes the app or just doesn't play.
                                                A VP6 clip plays audio without video.
                                                I also tried using the SMP player from osmf-trunk/player/.
                                                Things look good in the emulator -- but either crash or no playback on device.
                                                I don't know whether the issue is that Flex isn't getting along with MediaSurface support in osmf, or that AIR3 on iOS just doesn't work for video yet. Or perhaps both?
                                                I'm now working on other parts of the app while waiting for Flex SDK 4.6 and AIR 3.1.
                                                Or perhaps someone here can shed some light...
                                                Good luck!
                                                Steven
                                                • 21. Re: Strobe Media Playback with AIR ?
                                                  smarcus99 Level 1
                                                  I re-read your question and realised that I didn't answer it! Sorry!
                                                  No I never got StageVideo to enable with a standard/non-mobile AIR app either.
                                                  I tried pretty much the setup described in the previous post.
                                                  S
                                                  • 22. Re: Strobe Media Playback with AIR ?
                                                    smarcus99 Level 1
                                                    AIR 3.1 was just released so here's an update!
                                                    The SMP info overlay now reports that both hardware decode and stage video are active when running on the iPad!
                                                    Unfortunately video is still not actually visible in a Flex application -- but the audio does play and the app doesn't crash anymore.
                                                    I suspect that a non-Flex app might actually work. Hopefully this will be sorted out in Flex 4.6?
                                                    Curiously, SMP on (mac) desktop AIR has regressed.
                                                    In AIR3, hardware decode was enabled but stage video was disabled.
                                                    Now in AIR3.1, neither hardware decode not stage video show as enabled.
                                                    But video and audio do play.
                                                    Can anyone shed more light on this?
                                                    S
                                                    • 23. Re: Strobe Media Playback with AIR ?
                                                      vmm2012 Level 1
                                                      I am using Flex4.9. My Air app (SMP) loads on android. I need help as follows:
                                                      1. Screen Size - Even if I click full size video does not change size
                                                      2. Even though i specifically set
                                                      <uses-permission android:name="android.permission.DISABLE_KEYGUARD"/>
                                                      <uses-permission android:name="android.permission.WAKE_LOCK"/>
                                                      Keygurd shuts down video. How do I disable keyguard ?
                                                      V
                                                      • 24. Re: Strobe Media Playback with AIR ?
                                                        Ali Abu Ras Level 1
                                                        I am using Apache flex 4.14.0, and kutu HLS plugin, but after adding my player to MXML file only white screen with sound of the video, I did the implementation in this page but nothing happens, how could I make the video visible on screen?
