9 Replies Latest reply on Aug 19, 2010 2:45 PM by Muppet Mark-QAl63s
    Long Shot Scripting for Server Organization - Help?
    KS_Coastal Level 1
      I have plenty of scripts to identify the res of an image, but now I am looking to put one together which will look at my server, identify amongst thousands of files at a time, the PS, .jpg and .tiff files only, checking the res and copying those that are 300 dpi or greater only to a local folder. From there I have a whole other workflow to reres to low res for FPO files and rename into their own folder. Making sense enough for a reply?
        • 1. Re: Long Shot Scripting for Server Organization - Help?
          look at this thread it may be of some help or give you an idea. http://forums.adobe.com/thread/693986?tstart=0
          • 2. Re: Long Shot Scripting for Server Organization - Help?
            Paul Riggott Level 6
            This should do PSD, JPG and TIF files..
                Run the script from ESTK
            Make sure you select :-
            View -  Show Items from Subfolders
            if you want sub folders
            #target bridge
            main();
            function main(){
            var count = 0;
            var copyFolder =  Folder.selectDialog( "Please select folder to copy files to.");
            app.document.selectAll();
            if(copyFolder == null) return;
            var thumbs = app.document.getSelection("psd, jpg, tif");
            for(var a in thumbs){
            var t= new Thumbnail(thumbs[a]);
            if(t.core.quickMetadata.xResolution >=300){
            thumbs[a].spec.copy(File(copyFolder + "/"+ decodeURI(thumbs[a].name)));
            count++;
            alert("Total number of files copied = " + count);
            NB if any files have the same name they will be overwritten in the copy folder! It might be best doing a folder at a time.
            • 3. Re: Long Shot Scripting for Server Organization - Help?
              KS_Coastal Level 1
              Works great for the first 100 or so images, but I have 1500 or so. I'm going to break it down a bit and should be fine. Thanks!!!
              • 4. Re: Long Shot Scripting for Server Organization - Help?
                KS_Coastal Level 1
                Hi Paul,
                Any idea why the script all of the sudden will only copt the tif files?
                • 5. Re: Long Shot Scripting for Server Organization - Help?
                  Sorry, no. I have done some ckecks and it seems to selecting the correct files, I thought it might have been because the extensions were not lower case, but it still picks them out even if mixed case.
                  I have put some counts in, allthough they will only tell you what has been selected. Can you find a file that you know it should select but doesn't? If so it might be a problem with the metadata and I could write something that would tell us what the script is seeing for that file.
                  #target bridge
                  main();
                  function main(){
                  var count = 0;
                  var psdCount = 0;
                  var jpgCount = 0;
                  var tifCount =0;
                  alert("Processing "+thumbs.length + " Files");
                  count++;
                  if(thumbs[a].name.match(/jpg$/i)) jpgCount++;
                  if(thumbs[a].name.match(/psd$/i)) psdCount++;
                  if(thumbs[a].name.match(/tif$/i)) tifCount++;
                  alert("Total number of files copied = " + count + "\rJPGs = "+ jpgCount+"\rPSDs = "+ psdCount + "\rTIFs = "+ tifCount);
                  • 6. Re: Long Shot Scripting for Server Organization - Help?
                    KS_Coastal Level 1
                    I see the edit you made and am going to check but can't get back until tomorrow. I can see many many psd and jpg files it should be selecting but isn't. There is a ton of metadata in these files, so it'd be a miracle if we could find out if that (or a part of that metadata) is an issue. I'll poke a bit more and give you an update in the AM. Thanks so much for getting back to me!
                    • 7. Re: Long Shot Scripting for Server Organization - Help?
                      KS_Coastal Level 1
                      Is it tomorrow yet??? I ran the script, and it tells me it is processing 2 (for example) files, but has the error/yield symbol on it and does not copy. The first script doesn't even see the jpg files. Am I making sense?
                      • 8. Re: Long Shot Scripting for Server Organization - Help?
                        Yes that symbol is ok as it is a Script Alert.
                        Please could you run this on those files, it will give a Script Alert for each of the files giving you the Filename and the resolution of the file. Does any of them report undefined ?
                        #target bridge
                        main();
                        function main(){
                        alert(decodeURI(thumbs[a].name) + " resolution = " + t.core.quickMetadata.xResolution );
                        • 9. Re: Long Shot Scripting for Server Organization - Help?
                          Muppet Mark-QAl63s Level 4
                          If you are on a mac then you could try this in the ESTK with either bridge or photoshop as your target app. It passes a string to the system that just writes a list as a text file to your documents folder… If you compare the list and it looks good you can either parse it with JavaScript or pipe it to another shell like 'cp'
                          #target bridge
                          var f = Folder.selectDialog('Select a Folder to search in?');
                          var shellString = "mdfind -onlyin ";
                          shellString += "'" + f.fsName + "/'";
                          shellString += " '(kMDItemResolutionHeightDPI > 299 || kMDItemResolutionWidthDPI > 299)";
                          shellString += " && (kMDItemFSName == *.tif || kMDItemFSName == *.psd || kMDItemFSName == *.jpg)' > ";
                          shellString += "~/Documents/StdOut.txt";
                          //$.writeln(shellString); Just my test
                          var sh = app.system(shellString);
                          I only did a small amount of testing here but it looked OK…
