5 Replies Latest reply on Aug 19, 2010 1:39 AM by Muppet Mark-QAl63s
    Selecting a Graphic Layer with Apple Script
    chris Harges Level 1
      I'm trying to build on a very helpful post by sstanleyau showing how to choose different layers in a placed PSD or PDF. Unfortunately, I'm stuck in my test script. It seems so simple …
      Here's what the script should do after an image is placed in a text frame:
      1. "Read" the names of each of the graphic layers in the placed graphic.
      2. If one of the names contains a string, then
      3. Turn current visibility of that layer on
      4. Turn the visibility of every other layer off.
      However, my script seems to come up with a different result each time I run it and often fails to "find" a layer that I know is there. Is it possible that my script can't access the name of a graphic layer if its visibility is set to off?
      Here's why I've got
      --before running, user selects a test frame containing a placed PDF with multiple layers named blue, red and green.
      tell application "Adobe InDesign CS4"
      set theFrame to item 1 of selection
      set glOptions to graphic layer options of graphic 1 of theFrame
      set theName to text of "blue"
      repeat with z from 1 to count of graphic layers in glOptions
      if name of graphic layer z of glOptions contains theName then
      repeat with d from 1 to count of graphic layers in glOptions
      if current visibility of graphic layer d of glOptionsfalse then
      set current visibility of graphic layer d of glOptions to false
      end if
      end repeat
      if current visibility of graphic layer d of glOptions = false then
      set current visibility of graphic layer z of glOptions to true
      end if
      end if
      end repeat
      end tell
        • 1. Re: Selecting a Graphic Layer with Apple Script
          sstanleyau Level 4
          I think you're probably after something more like this:
          tell application "Adobe InDesign CS5"
          set theName to "blue"
          end if
          end repeat
          else
          if current visibility of graphic layer d of glOptionstrue then
          set current visibility of graphic layer d of glOptions to true
          end if
          end repeat
          end if
          end repeat
          end tell
          • 2. Re: Selecting a Graphic Layer with Apple Script
            Hmm. I'm still getting the same problem. It will toggle off one layer and then throw this error:
            error "Adobe InDesign CS4 got an error: Can’t get current visibility of graphic layer 2 of graphic layer options of PDF id 209 of rectangle id 206 of page id 190 of spread id 185 of document \"Untitled-1\"." number -1728 from current visibility of graphic layer 2 of graphic layer options of PDF id 209 of rectangle id 206 of page id 190 of spread id 185 of document "Untitled-1"
            • 3. Re: Selecting a Graphic Layer with Apple Script
              Muppet Mark-QAl63s Level 4
              Im NOT sure if you have just made this a little over complicated… This works just fine for me. Tested with about a dozen psd layers…
              tell application "Adobe InDesign CS2"
              tell active document
              tell rectangle 1
              tell graphic 1
              tell graphic layer options
              set GLC to count of graphic layers
              repeat with i from 1 to GLC
              if name of graphic layer i ≠ "Blue" then
              set current visibility of graphic layer i to false
              else
              set current visibility of graphic layer i to true
              end if
              end repeat
              end tell
              end tell
              end tell
              end tell
              end tell
              This variant also works as I would have expected too… Retaining visibility from a list…
              tell rectangle 1
              tell graphic 1
              set On_List to {"Red", "Aqua", "Orange"}
              if name of graphic layer i is not in On_List then
              else
              end if
              end repeat
              end tell
              end tell
              end tell
              end tell
              end tell
              • 4. Re: Selecting a Graphic Layer with Apple Script
                Thanks Muppet Mark and Shane,
                Muppet Mark's first variant works for me perfectly. So why does both my initial script and Shane's version throw an error? The only difference I can see is that we set graphic layer options to a variable and you nested it in a tell block. Either way, we're both working the hierarchy right so the script should be able to find the graphic layers either way. I'm happy for a script that works by confused by why one works and the other doesn't.
                • 5. Re: Selecting a Graphic Layer with Apple Script
                  I got the same error as you when I tested the posted code. Did not have the time to try work out why but It contains 3 loops and I suspect some element is out of range in this, where the logic to me required only the 1 loop… Happy that it works 4U anyhow…
