1 Reply Latest reply on Aug 23, 2010 4:18 AM by hneelu
    Connect to XML
    hidarikani Level 2
      I run the Flex 4 Connect to XML wizard.
      Then I run the Configure return type wizard, but I can't set the return type to XML.
      How do I set the return type to XML?
      I want to use TextFlowUtil.importFromXml method
      but I can't find a way to get an XML object from the service that the wizard generates
        • 1. Re: Connect to XML
          hneelu Adobe Employee
          Using Configure Return Type wizard, return type can be set to an AS datatype or a custom datatype. XML is not an AS datatype, hence it would be treated as some custom datatype.
          You would have to write some code or function to get the XML format from this custom datatype.
          Hope this helps.
