22 Replies Latest reply on Sep 13, 2010 11:40 PM by hidarikani
    TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
    hidarikani Level 2
      I get this message printed in the CONSOLE when I debug the app.
      When I run the 'set return type wizard' valueObjects.Item gets created but when I run the app I get this Error in the console:
        • 2. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
          hidarikani Level 2
          Hi, Flex HarUI, I've created an example project that reproduces the error that I'm facing.
          After running the "Connect to php" and "Configure return type" wizards I get this:
          Then I select bInA() and run "generate service call" and call the service after application creationComplete.
          When running in debug mode I get this in the console:
          [SWF] /flexTR/VO-test-debug/Main.swf - 259,501 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/1 - 370,463 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/2 - 2,311,734 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/3 - 650,777 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/4 - 441,362 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/5 - 1,432,382 bytes after decompression
          [SWF] /flexTR/VO-test-debug/Main.swf/[[DYNAMIC]]/6 - 323,354 bytes after decompression
          TypeError: Error #1034: Type Coercion failed: cannot convert Object@73f4b51 to valueObjects.B.
          The problem:
          var a:A = bInAResult.lastResult;
          if (null == a.child)
               trace('failed to get B'); //prints this
          I have no trace() functions in my code but the error is printed in the console. I've spent two days trying to figure this one out
          Flex:
                            xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:service="services.service.*"
                            creationComplete="application1_creationCompleteHandler(event)">
               <fx:Script>
                    <![CDATA[
                         import mx.controls.Alert;
                         import mx.events.FlexEvent;
                         protected function bInA():void {
                              bInAResult.token = service.bInA();
                         protected function application1_creationCompleteHandler(event:FlexEvent):void {
                              bInA();
               </fx:Script>
               <fx:Declarations>
                    <s:CallResponder id="bInAResult"/>
                    <service:Service id="service" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
               </fx:Declarations>
          </s:Application>
          PHP:
          <?php
               class A {
                    public $title = 'A';
                    public $child;
          <?php
               class B {
                    public $title = 'B';
          <?php
               require_once 'A.php';
               require_once 'B.php';
               class Service {
                    public function bInA() {
                         $a = new A();
                         $a->child = new B();
                         return $a;
          • 3. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
            Flex harUI Adobe Employee
            Is that error really the last line in the console?  I would expect more
            lines to follow.
            • 4. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
              hidarikani Level 2
              Yes, it's the last one
              Didn't have time to reply earlier
              • 6. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                I think more analysis is warranted.  It looks like you are using a custom
                service.  There may be issues there.
                • 7. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                  hidarikani Level 2
                  Flex harUI wrote:
                  It looks like you are using a custom service.
                  The service was created by 'connect to PHP' wizard
                  The value objects were created by 'configure return type' wizard
                  I didn't modify them in any way.
                  The PHP code is OK because when I 'Test Operation...' I get this:
                  If it's a bug my guess it's somewhere in CallResponder
                  • 8. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                    Is valueObject.item one of the classes in the response?  Where is it used in
                    your code?
                    • 9. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                      hidarikani Level 2
                      valueObjects.Item is from a real app but it's too advanced to talk about it in a thread.
                      That's why I've created a very simple example that reproduces the error
                      and posted all of its source code in post #3.
                      The example has two value objects: A and B.
                      • 10. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                        I don't know what Test Operation is supposed to return, but it would seem
                        like the results you posted are suspicious.  I would expect the titles to
                        show a string and 'a' to show Instance of A.  You might try a example
                        project and see.
                        • 11. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                          hidarikani Level 2
                          First of all thanks for not abandoning this thread and trying to help.
                          Secondly
                          You got that right. I modified the PHP objects to contain human friendlier strings:
                          <?php
                               class A {
                                    public $title = 'Instance of A';
                                    public $child;
                          <?php
                               class B {
                                    public $title = 'Instance of B';
                          I didn't change anythig else and the error remains:
                          • 12. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                            What does Test Operation show now?  If you use Test Operation on some other
                            working sample, what does it show?
                            • 14. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                              You must have an A.as and B.as somewhere.  What do they look like?
                              • 15. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                hidarikani Level 2
                                A.as and B.as are in the valueObjects package.
                                I didn't modify files in the package in any way.
                                A.as:
                                 * This is a generated sub-class of _A.as and is intended for behavior
                                 * customization.  This class is only generated when there is no file already present
                                 * at its target location.  Thus custom behavior that you add here will survive regeneration
                                 * of the super-class.
                                 * NOTE: Do not manually modify the RemoteClass mapping unless
                                 * your server representation of this class has changed and you've
                                 * updated your ActionScriptGeneration,RemoteClass annotation on the
                                 * corresponding entity
                                package valueObjects
                                import com.adobe.fiber.core.model_internal;
                                public class A extends _Super_A
                                     * DO NOT MODIFY THIS STATIC INITIALIZER - IT IS NECESSARY
                                     * FOR PROPERLY SETTING UP THE REMOTE CLASS ALIAS FOR THIS CLASS
                                     * Calling this static function will initialize RemoteClass aliases
                                     * for this value object as well as all of the value objects corresponding
                                     * to entities associated to this value object's entity.
                                    public static function _initRemoteClassAlias() : void
                                        _Super_A.model_internal::initRemoteClassAliasSingle(valueObjects.A);
                                        _Super_A.model_internal::initRemoteClassAliasAllRelated();
                                    model_internal static function initRemoteClassAliasSingleChild() : void
                                     * END OF DO NOT MODIFY SECTION
                                • 16. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                  How about Super_A and Super_B?  It may be that the classes are not
                                  registering via registerClassAlias, although sometimes the Fiber classes
                                  input ObjectProxy and convert to the classes later.
                                  You might want to try this post and see if it works for you and then
                                  compare: https://corlan.org/debugging-flex-and-php/#a3
                                  • 17. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                    hidarikani Level 2
                                    The tutorial you posted explains how to send an array of objects.
                                    I have done that and it works fine. What is more I've successfully send A inside of A. But B in A doesn't work.
                                    _Super_A.as
                                     * This is a generated class and is not intended for modification.  To customize behavior
                                     * of this value object you may modify the generated sub-class of this class - A.as.
                                    import com.adobe.fiber.services.IFiberManagingService;
                                    import com.adobe.fiber.util.FiberUtils;
                                    import com.adobe.fiber.valueobjects.IValueObject;
                                    import flash.events.Event;
                                    import flash.events.EventDispatcher;
                                    import mx.binding.utils.ChangeWatcher;
                                    import mx.events.PropertyChangeEvent;
                                    import mx.validators.ValidationResult;
                                    import valueObjects.B;
                                    import flash.net.registerClassAlias;
                                    import flash.net.getClassByAlias;
                                    import com.adobe.fiber.valueobjects.IPropertyIterator;
                                    import com.adobe.fiber.valueobjects.AvailablePropertyIterator;
                                    use namespace model_internal;
                                    [ExcludeClass]
                                    public class _Super_A extends flash.events.EventDispatcher implements com.adobe.fiber.valueobjects.IValueObject
                                        model_internal static function initRemoteClassAliasSingle(cz:Class) : void
                                            try
                                                if (flash.net.getClassByAlias("A") == null)
                                                    flash.net.registerClassAlias("A", cz);
                                            catch (e:Error)
                                        model_internal static function initRemoteClassAliasAllRelated() : void
                                            valueObjects.B.initRemoteClassAliasSingleChild();
                                        model_internal var _dminternal_model : _AEntityMetadata;
                                         * properties
                                        private var _internal_child : valueObjects.B;
                                        private var _internal_title : String;
                                        private static var emptyArray:Array = new Array();
                                         * derived property cache initialization
                                        model_internal var _cacheInitialized_isValid:Boolean = false;
                                        model_internal var _changeWatcherArray:Array = new Array();
                                        public function _Super_A()
                                            _model = new _AEntityMetadata(this);
                                            // Bind to own data properties for cache invalidation triggering
                                            model_internal::_changeWatcherArray.push(mx.binding.utils.ChangeWatcher.watch(this, "child", model_internal::setterListenerChild));
                                            model_internal::_changeWatcherArray.push(mx.binding.utils.ChangeWatcher.watch(this, "title", model_internal::setterListenerTitle));
                                         * data property getters
                                        [Bindable(event="propertyChange")]
                                        public function get child() : valueObjects.B
                                            return _internal_child;
                                        public function get title() : String
                                            return _internal_title;
                                         * data property setters
                                        public function set child(value:valueObjects.B) : void
                                            var oldValue:valueObjects.B = _internal_child;
                                            if (oldValue !== value)
                                                _internal_child = value;
                                                this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "child", oldValue, _internal_child));
                                        public function set title(value:String) : void
                                            var oldValue:String = _internal_title;
                                                _internal_title = value;
                                                this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "title", oldValue, _internal_title));
                                         * Data property setter listeners
                                         * Each data property whose value affects other properties or the validity of the entity
                                         * needs to invalidate all previously calculated artifacts. These include:
                                         *  - any derived properties or constraints that reference the given data property.
                                         *  - any availability guards (variant expressions) that reference the given data property.
                                         *  - any style validations, message tokens or guards that reference the given data property.
                                         *  - the validity of the property (and the containing entity) if the given data property has a length restriction.
                                         *  - the validity of the property (and the containing entity) if the given data property is required.
                                        model_internal function setterListenerChild(value:flash.events.Event):void
                                            _model.invalidateDependentOnChild();
                                        model_internal function setterListenerTitle(value:flash.events.Event):void
                                            _model.invalidateDependentOnTitle();
                                         * valid related derived properties
                                        model_internal var _isValid : Boolean;
                                        model_internal var _invalidConstraints:Array = new Array();
                                        model_internal var _validationFailureMessages:Array = new Array();
                                         * derived property calculators
                                         * isValid calculator
                                        model_internal function calculateIsValid():Boolean
                                            var violatedConsts:Array = new Array();
                                            var validationFailureMessages:Array = new Array();
                                            var propertyValidity:Boolean = true;
                                            if (!_model.childIsValid)
                                                propertyValidity = false;
                                                com.adobe.fiber.util.FiberUtils.arrayAdd(validationFailureMessages, _model.model_internal::_childValidationFailureMessages);
                                            if (!_model.titleIsValid)
                                                com.adobe.fiber.util.FiberUtils.arrayAdd(validationFailureMessages, _model.model_internal::_titleValidationFailureMessages);
                                            model_internal::_cacheInitialized_isValid = true;
                                            model_internal::invalidConstraints_der = violatedConsts;
                                            model_internal::validationFailureMessages_der = validationFailureMessages;
                                            return violatedConsts.length == 0 && propertyValidity;
                                         * derived property setters
                                        model_internal function set isValid_der(value:Boolean) : void
                                            var oldValue:Boolean = model_internal::_isValid;
                                                model_internal::_isValid = value;
                                                _model.model_internal::fireChangeEvent("isValid", oldValue, model_internal::_isValid);
                                         * derived property getters
                                        [Transient]
                                        public function get _model() : _AEntityMetadata
                                            return model_internal::_dminternal_model;
                                        public function set _model(value : _AEntityMetadata) : void
                                            var oldValue : _AEntityMetadata = model_internal::_dminternal_model;
                                                model_internal::_dminternal_model = value;
                                                this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "_model", oldValue, model_internal::_dminternal_model));
                                         * methods
                                         *  services
                                        private var _managingService:com.adobe.fiber.services.IFiberManagingService;
                                        public function set managingService(managingService:com.adobe.fiber.services.IFiberManagingService):void
                                            _managingService = managingService;
                                        model_internal function set invalidConstraints_der(value:Array) : void
                                            var oldValue:Array = model_internal::_invalidConstraints;
                                            // avoid firing the event when old and new value are different empty arrays
                                            if (oldValue !== value && (oldValue.length > 0 || value.length > 0))
                                                model_internal::_invalidConstraints = value;
                                                _model.model_internal::fireChangeEvent("invalidConstraints", oldValue, model_internal::_invalidConstraints);
                                        model_internal function set validationFailureMessages_der(value:Array) : void
                                            var oldValue:Array = model_internal::_validationFailureMessages;
                                                model_internal::_validationFailureMessages = value;
                                                _model.model_internal::fireChangeEvent("validationFailureMessages", oldValue, model_internal::_validationFailureMessages);
                                        model_internal var _doValidationCacheOfChild : Array = null;
                                        model_internal var _doValidationLastValOfChild : valueObjects.B;
                                        model_internal function _doValidationForChild(valueIn:Object):Array
                                            var value : valueObjects.B = valueIn as valueObjects.B;
                                            if (model_internal::_doValidationCacheOfChild != null && model_internal::_doValidationLastValOfChild == value)
                                               return model_internal::_doValidationCacheOfChild ;
                                            _model.model_internal::_childIsValidCacheInitialized = true;
                                            var validationFailures:Array = new Array();
                                            var errorMessage:String;
                                            var failure:Boolean;
                                            var valRes:ValidationResult;
                                            if (_model.isChildAvailable && _internal_child == null)
                                                validationFailures.push(new ValidationResult(true, "", "", "child is required"));
                                            model_internal::_doValidationCacheOfChild = validationFailures;
                                            model_internal::_doValidationLastValOfChild = value;
                                            return validationFailures;
                                        model_internal var _doValidationCacheOfTitle : Array = null;
                                        model_internal var _doValidationLastValOfTitle : String;
                                        model_internal function _doValidationForTitle(valueIn:Object):Array
                                            var value : String = valueIn as String;
                                            if (model_internal::_doValidationCacheOfTitle != null && model_internal::_doValidationLastValOfTitle == value)
                                               return model_internal::_doValidationCacheOfTitle ;
                                            _model.model_internal::_titleIsValidCacheInitialized = true;
                                            if (_model.isTitleAvailable && _internal_title == null)
                                                validationFailures.push(new ValidationResult(true, "", "", "title is required"));
                                            model_internal::_doValidationCacheOfTitle = validationFailures;
                                            model_internal::_doValidationLastValOfTitle = value;
                                    _Super_B.as
                                     * of this value object you may modify the generated sub-class of this class - B.as.
                                    [ExcludeClass]
                                    public class _Super_B extends flash.events.EventDispatcher implements com.adobe.fiber.valueobjects.IValueObject
                                            try
                                                if (flash.net.getClassByAlias("B") == null)
                                                    flash.net.registerClassAlias("B", cz);
                                            catch (e:Error)
                                        model_internal var _dminternal_model : _BEntityMetadata;
                                         * properties
                                        public function _Super_B()
                                            _model = new _BEntityMetadata(this);
                                        [Transient]
                                        public function get _model() : _BEntityMetadata
                                        public function set _model(value : _BEntityMetadata) : void
                                            var oldValue : _BEntityMetadata = model_internal::_dminternal_model;
                                         * methods
                                         *  services
                                    • 18. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                      "A in B" or "B in A"?  I think this class is set up for B as a sub-object of
                                      A which I think is how your test operation results indicated.  You might try
                                      seeing if the registration code is running (where it calls
                                      registerClassAlias).
                                      Since you got A in A working, you might try that configuration, set a
                                      breakpoint in the Super_A constructor and see where that gets instantiated
                                      then compare that code path for B in A.
                                      I don't know anything about PHP, but is there any way you can specify the
                                      type of the child property in php class for A?
                                      • 19. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                        hidarikani Level 2
                                        B in A
                                        You might try seeing if the registration code is running (where it calls registerClassAlias).
                                        The constructor of _Super_B.as which contains a call to registerClassAlias never runs (The error is printed to the console before it has a chance to run).
                                        I've set a breakpoint on line:
                                        in Main.mxml (the service passess something to the CallResponder).
                                        I kept pressing F6 until I got this:
                                        When I reach this line in AbstactMessage.as the error is printed to the console:
                                        TypeError: Error #1034: Type Coercion failed: cannot convert Object@6f17c89 to valueObjects.B.
                                        But I don't understant how to interprit these results.
                                        Is there any way you can specify the
                                        From PHP documentation:
                                        "PHP does not require (or support) explicit type definition in variable declaration; a variable's type is determined by the context in which the variable is used. That is to say, if a string value is assigned to variable $var, $var becomes a string. If an integer value is then assigned to $var, it becomes an integer."
                                        • 20. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                          I would definitely go back to the "A in A" scenario and see if/when the
                                          registerClassAlias for A is called (if at all) and when the constructors for
                                          A/Super_A are called.  The service decoder for XML doesn't call the
                                          registration code.  Maybe the PHP decoder doesn't either.  In XML the
                                          constructors are called in a later conversion phase.
                                          Then I would set breakpoints at various places in the call stack that you
                                          saw when the classes get registered or constructed and compare the code
                                          paths taken when you switch back to "B in A".
                                          • 21. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                            mr_tijn
                                            We may have seen a similar issue. The problem was that in the generated services as file,
                                            not all _initRemoteClassAlias initializers were called.
                                            Note that this was only on my colleagues FB4.0.1 version.
                                            The code generated in my own FB4.0.0 works correctly.
                                            Can you check whether both valueObjects.A._initRemoteClassAlias() and valueObjects.B._initRemoteClassAlias()
                                            are in your generated service file ?
                                            • 22. Re: TypeError: Error #1034: Type Coercion failed: cannot convert Object@6802059 to valueObjects.Item
                                              hidarikani Level 2
                                              Will try the proposed solutions and post results next week.
