5 Replies Latest reply on Aug 18, 2010 9:11 AM by Subeesh Arakkan
    Pass Variable from Main.mxml to Pop.mxml
    djh88ukwb Level 1
      Hello All.
      I have a project that has two files.
      Main.mxml and Pop.mxml
      Main.mxml is obv my main application and it has a variable that contains the link to an image.  This variable changes on a regular basis.
      The Pop.mxml file is a TitleWindow that i want to display the image, but on a larger scale.
      The code for my Pop.mxml is as:
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml"
                      layout="vertical"
                      title="Tazio AudioCast"
                      showCloseButton="true"
                      width="1022"
                      height="800"
                      close="titleWindow_close(event);" move="doMove(event)">
          <mx:Script>
              <![CDATA[
                  import mx.events.CloseEvent;
                  import mx.managers.PopUpManager;
                  import mx.core.Application;
                  [Bindable] public var test:String;
                  private function titleWindow_close(evt:CloseEvent):void {
                      PopUpManager.removePopUp(this);
                  private function doMove(event:Event):void
                  {//keeps TW inside layout
                      var appW:Number=Application.application.width;
                      var appH:Number=Application.application.height;
                      if(this.x+this.width>appW)
                          this.x=appW-this.width;
                      if(this.x<0)
                          this.x=0;
                      if(this.y+this.height>appH)
                          this.y=appH-this.height;
                      if(this.y<0)
                          this.y=0;
          </mx:Script>
          <mx:SWFLoader width="100%" height="100%" source="swf/slide1.swf"/>
          <mx:Label text="{test}" color="#C00D0D" x="1200"  top="20"/>
      </mx:TitleWindow>
      What i am struggling with thou, is how do i pass the variable from Main.mxml to Pop.mxml.
      I know how to do this with components, its easy enough, but i cant see to do it between these two files.
      The vairable i am rying to pass at the momnet is called  "test".
      Any help would be great, thanks !
        • 1. Re: Pass Variable from Main.mxml to Pop.mxml
          Subeesh Arakkan Level 4
          how are you launching the popup, If you are using PopupManager, try this
          var popup:Pop = Pop(PopUpManager.createPopUp(this, Pop, true));
          popup.test = "your value";
          PopUpManager.centerPopUp(popup);
          • 2. Re: Pass Variable from Main.mxml to Pop.mxml
            djh88ukwb Level 1
            Thank you very much, that was just what  i needed
            One last question, when using the popup manager, is there a way to disable the grey fade that it puts over the whole app ?
            • 3. Re: Pass Variable from Main.mxml to Pop.mxml
              Yes,
              That grey fade is the modal transparency color. If you want you can make your popup non -modal. Just set the modal flag to false, like this
              PopUpManager.addPopUp(titleWin,this,false);
              Or if you want more control over modal color, alpha and duration, check the following blog post
              http://mprami.wordpress.com/2008/04/22/alert_popup_modal_transparancy_color_blur_changes/
              • 4. Re: Pass Variable from Main.mxml to Pop.mxml
                djh88ukwb Level 1
                Again thankyou very much, this has solved my problem.
                The one last snag that i have is the following, im not sure if you would be able to help ?
                The variable that i am passing into the popupmodule file is called imgSRC.
                This variable is updated every second, using a function that is linked to a timer.  So the contents of this variable changes often.
                Now when i pass my variable into the popupManager, it takes the value that is in the variable at that time, however when imgSRC changes it doesnt update.
                Is there anyway around this ?
                Here is my PopUpManager function.
                            private function launchFullScreen():void {
                                var win:FullScreen = PopUpManager.createPopUp(this, FullScreen, false) as FullScreen;
                                win.Image = imgSRC;
                                PopUpManager.centerPopUp(win);
                So ideally i need the win.Image = imgSRC; to run all the time.
                I cant run the overall function all the time, because if the user dosent want the window open, they wont be able to close it.
                Any help would be great !
                • 5. Re: Pass Variable from Main.mxml to Pop.mxml
                  Create your popup instance outside the function so that it can be accessed anywhere from the page.
                  private var win:FullScreen;
                                  win = PopUpManager.createPopUp(this, FullScreen, false) as FullScreen;
                                  win.Image = imgSRC;
                  Then in the timer event handler, set the image source.
                  if(win)
                        win.Image = imgSRC;
