2 Replies Latest reply on Aug 18, 2010 9:47 AM by Flex harUI
    Changing the MXML of a component at runTime
    hINTModuleState
      Hi there,
      I need, depending on runTime conditions, to update the surface of a Flex window with a combination of controls.
      For example I may need to layout this line
      THIS IS STATIC TEXT #COMBOBOX# THIS IS ANOTHER STATIC TEXT #CHEKBOX#
      Or this line :
      #EDITBOX# STATIC TEXT HERE
      A priori I can't tell the set of combination I may encounter, so I need to be able to dynamically construct the UI.
      If changing the MXML of a component is possible, then I can ofcourse solve this pbm since the solution will only have to deal with string operation.
      Please help.
      Thanks in advance.
