1 Reply Latest reply on Aug 22, 2010 10:52 PM by Balakrishnan V
    HTTPS and SSL Certificates?
    UnfinishedDream
      I was hoping someone might be able to point me in the right direction for the following request:
      One important issue for security is that we will want to support HTTPS but not to be required to pay a certification authority (CA) for the SSL certificate.  It is easy enough to generate our own certificate for the server, but I wanted to know how Flex/Actionscript can work with such a setup (an untrusted certificate chain).  Which of the following applies:
      -        There is an easy API that allows us to permit requests to be made to the server which uses an untrusted certificate
      -        There is no way to allow requests to be made to a server which has an untrusted certificate
      -        Requests can be made to the server with an untrusted certificate, but the UI will require a warning be shown
      Thank you.
