1 Reply Latest reply on Dec 7, 2010 8:22 PM by Saurabh.Agrawal
    PDFG IPP Printer install in 64-bit Server
    alexr@protech
      I have an issue trying to install the PDFG IPP printer driver on a Win2008 server (Jboss turn-key). We even tried to save the install.jnlp and run javaws on a command line.
      When we use the "click here" link in adminui/Home > Services >LiveCycle PDF Generator ES2 > PDF Generator Network Printer
      we get the following error:
      Could not find the main class:
      com.adobe.livecycle.pdfg.ipp.gui.IPPGui. Program will exit.
      The printer installation works fine on 32-bit server and on (XP) workstations.
      Has anybody seen this behaviour?
      Could it be a 64-bit issue?
        • 1. Re: PDFG IPP Printer install in 64-bit Server
          Saurabh.Agrawal Level 1
          This is a known issue with Windows 64-bit.
          As a workaround, you can install PDFG IPP Printer by following these steps:
          1. Go to Control Panel > Hardware > Devices and Printers
          2. Click on Add a printer to start the "Add Printer Wizard".
          3. Choose the second option - Add a network, wireless or Bluetooth printer
          4. Click on The printer I want isn't installed
          5. Select a shared printer by name. Type in the following URL : http://localhost:8080/pdfg-ipp/printer
          6. You'll be asked for PDFG credentials (username / password) to access the printer
          7. On the next screen, select any PostScript printer driver.
          8. Done! You should see a dialog confirming that you've successfully installed the printer.
