0 Replies Latest reply on Aug 18, 2010 11:23 AM by John Wolfsteiner
    This panel is only available in Design Mode
    John Wolfsteiner
      I was really at a loss on why my perfectly working mxml module failed to load in design mode.
      After spending hours on isolating this error I found the following and hope it will benefit anyone having similar problems.
      If you have an item renderer inside for example a spark Tile, and this itemrenderer extends the spark itemrender class, then this particular code will result in the above error message in the design view property panel:
      <code>
      <s:states>
              <!-- disable for now
              <s:State name="normal"/>
              <s:State name="hovered"/>
              <s:State name="selected" />
      </s:states>
      </code>
      Apparently you cannot have a state declaration without defining actual states.
      Kind Regards,
      John
