6 Replies Latest reply on Aug 19, 2010 2:36 AM by Lior Bruder
    Release build not working after Flash Builder 4.0.1 install
    Lior Bruder
      Hi All,
      I have installed Flash Builder 4.0.1 and Flex 4.1 SDK (I hope this is not a mistake...), and it seems that everything is working fine, but when i am trying to make a release version (Export release build) i get nothing (The button does not react).
      Any ideas how to solve this?
      Thanks in advance,
      Lior
        • 1. Re: Release build not working after Flash Builder 4.0.1 install
          Anirudh Sasikumar Adobe Employee
          Can you please post your log?
          It should be in workspacedir/.metadata./.log
          • 2. Re: Release build not working after Flash Builder 4.0.1 install
            Lior Bruder Level 1
            Yap,
            This is the log created when i try to create the release build:
            !ENTRY org.eclipse.ui 4 0 2010-08-19 09:34:28.070
            !MESSAGE Unhandled event loop exception
            !STACK 0
            java.lang.NoClassDefFoundError: com/adobe/flexbuilder/exportimport/releaseversion/ui/ExportSigningPage$1
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportSigningPage.createControl(Expo rtSigningPage.java:117)
                at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.createPag eControls(ExportReleaseVersionWizard.java:310)
                at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:675)
                at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:549)
                at org.eclipse.jface.window.Window.create(Window.java:431)
                at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:93)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
                at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
                at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
                at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java :452)
                at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
                at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
                at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
                at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :109)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                at java.lang.reflect.Method.invoke(Unknown Source)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
            • 3. Re: Release build not working after Flash Builder 4.0.1 install
              Looks like the class files are missing in your installed copy. Possibly the update didn't go smoothly.
              A clean install should help.
              Anirudh
              • 4. Re: Release build not working after Flash Builder 4.0.1 install
                Lior Bruder Level 1
                Can you please send me the link to download the 4.01 full version
                • 5. Re: Release build not working after Flash Builder 4.0.1 install
                  https://www.adobe.com/cfusion/tdrc/index.cfm?product=flash_builder
                  That should give you 4.0.1 (the product name is still Adobe Flash Builder 4).
