11 Replies Latest reply on Aug 23, 2010 6:09 AM by jimsvideo
    video preview/playback not working
    jimsvideo
      I am a new premier elements 8 user.
      I've captured some video from my camera using a firewire connection.
      When I try to play back the video, I get a frozen image in the preview.  Every once in a while I might get a different image, but it's mostly frozen.
      I've updated quicktime to the latest.  I've updated my nvidia drivers to the latest.  I've run windows update.  Premier elements has been updated.  Everything (that I can tell) is up to date.
      My PC is running Windows 7 64-bit, 6 GB RAM, AMD Athlon II X4 630.
      The video file noted above can be played back in windows media player, windows movie maker, cyberlink power director (free version, came with the new PC), all without issues.
      In fact, any video I try to load (all captured using a slightly older PC, using Pinnacle) has the same problem, so I'm thinking it's not related to one codec or the other, because it seems different types of capture encoding show the same problem when played back.
      I've tried disabling and re-enabling the GPU usage setting under preferences; no diff.
      I've tried contacting Adobe support, read through several KB articles, I'm running out of patience.
      Any ideas?
      --JS
        • 1. Re: video preview/playback not working
          nealeh Level 5
          Is there a redline across the top of the timeline? If so then the clip needs rendering for good previews - Press [Enter] and wait until it is finished.
          If your footage is Standard Definition and you have a redline, then you have not chosen the correct project preset
          In addition to the items you have already updated:
          • Install the most recent sound drivers from the manufacturers web site
          • Run Disk Cleanup
          • Run Defragmenter
          • Post back here with the necessary information described here: Got a Problem? How to Get   Started (especially information about your project preset, the clip (via GSpot) and your camera).
          Cheers,
          Neale
          • 2. Re: video preview/playback not working
            jimsvideo Level 1
            When I import SD footage from my DV camera via firewire, there is a red  line just below the time line.
            When I import footage from file  (previously captured video clips, using pinnacle on an older XP machine)  I don't recall whether or not there was a red line.  I don't think  there was.
            I tried the render feature yesterday when I was troubleshooting, I  forgot to mention that originally.  The line turns green, and I have the  same result... the first frame or two displays then the preview display  just freezes.  The time line (is that what it's called?) advances, but  not the video preview itself.
            I am able to render and preview the clip in question, as well as any  others I've tested, using g-spot.  I don't recall the specific codecs  that were found in the clip, but I do recall that I have the matching  codec on my system.
            I'll update the audio drivers, run disk cleanup and defrag then post  the requested info, later tonight.
            • 3. Re: video preview/playback not working
              If you are capturing your video from a tape-based camcorder over FireWire, there should NOT  be a red line above the clips on the timeline until you add an effect ot transition to it. If so, you have a mismatch between your source video and your project.
              My tutorial series Basic Training with Premiere Elements will show you how to properly set up a project. Just go to Premiere Elements support site http://Muvipix.com and type "Basic Training" in the productg search box. My books will fill in the details with lots of how-tos if you're interested.
              Also, go to Help/Check for Updates to ensure you have the 8.01 patch for the software.
              • 4. Re: video preview/playback not working
                nealeh Level 5
                Depending on whether you are in the NTSC or PAL world and Standard or Wide you should be using one of the highlighted project presets:
                Cheers,
                Neale
                • 5. Re: video preview/playback not working
                  jimsvideo Level 1
                  When I create a new project, I have NTSC / DV / Standard-48khz selected, and I have the problem.
                  Later tonight I should be able to post the info requested originally.
                  • 6. Re: video preview/playback not working
                    nealeh Level 5
                    Try the other three possibilities and see if any of them accept the clip without redlines.
                    Cheers,
                    Neale
                    • 7. Re: video preview/playback not working
                      jimsvideo Level 1
                      My audio drivers have been updated.
                      I've tried capturing using all 4 dv project presets.  When I select DV PAL Std 48khz (which is not the default nor is it the type of camera I have since I live in the US), I get an error message stating something about a potental quality issue because the method doesnt match the source, however after capturing via that method, the video plays back.
                      g-spot states that I have the proper codecs.  The video clips I was capturing previously show that I have the proper codecs installed and play without issue (including the audio) in g-spot.  When I capture using the NTSC project settings, the video codec in use shows as codec "dvsd" and name "DVC/DV/Video" and format NTSC.  The audio codec is "PCM Audio".  If I capture using the PAL project settings, the video codec does not change however the format still shows NTSC.
                      I've noticed that when I capture using the NTSC method, I have an error message at the bottom of the premeir elements screen.  There's a little red X and next to it reads "Display performance will be poort due to incorrectly oeprating graphics card or driver!".  Note that I previously updated the drivers for the nvidia chipset on my system, I've run an HP diagnostic for the video chipset which passes with no trouble reports, and multiple video codecs/containers play back without issue using windows media player, quicktime, pinnacle studio, and windows movie maker.
                      So... I'm still having the same problem.  When I set up a project using the proper method and the proper formats, the captured video does not play back in premier elements 8.
                      At this point I have two problems....
                      1) I cannot view captured video, or any other video, unless there's a hack in place by capturing via the PAL project pre-settings; using premier elements on my pc.
                      2) Why does this workflow and asset work in 3 other editors on my system, and why does the asset play back in at least 3 other viewers on my system, but with premeir elements I cannot simply preview captured video?
                      Any help or additional guidance is appreciated.  I feel like I'm spending way to much time trying to get a simple process to work properly.
                      Heres the dxdiag info...
                      System Information
                      Time of this report: 8/20/2010, 07:39:33
                             Machine name: HOME
                         Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
                                 Language: English (Regional Setting: English)
                      System Manufacturer: HP-Pavilion
                             System Model: AY018AA-ABA p6310f
                                     BIOS: BIOS Date: 01/19/10 09:46:01 Ver: 5.14
                                Processor: AMD Athlon(tm) II X4 630 Processor (4 CPUs), ~2.8GHz
                                   Memory: 6144MB RAM
                      Available OS Memory: 5888MB RAM
                                Page File: 2315MB used, 9456MB available
                              Windows Dir: C:\Windows
                          DirectX Version: DirectX 11
                      DX Setup Parameters: Not found
                         User DPI Setting: Using System DPI
                      System DPI Setting: 96 DPI (100 percent)
                          DWM DPI Scaling: Disabled
                           DxDiag Version: 6.01.7600.16385 64bit Unicode
                      DxDiag Notes
                            Display Tab 1: No problems found.
                              Sound Tab 1: No problems found.
                              Sound Tab 2: No problems found.
                                Input Tab: No problems found.
                      DirectX Debug Levels
                      Direct3D:    0/4 (retail)
                      DirectDraw:  0/4 (retail)
                      DirectInput: 0/5 (retail)
                      DirectMusic: 0/5 (retail)
                      DirectPlay:  0/9 (retail)
                      DirectSound: 0/5 (retail)
                      DirectShow:  0/6 (retail)
                      Display Devices
                                Card name: NVIDIA GeForce 9100
                             Manufacturer: NVIDIA
                                Chip type: GeForce 9100
                                 DAC type: Integrated RAMDAC
                               Device Key: Enum\PCI\VEN_10DE&DEV_0847&SUBSYS_2A9E103C&REV_A2
                           Display Memory: 2923 MB
                         Dedicated Memory: 235 MB
                            Shared Memory: 2687 MB
                             Current Mode: 1680 x 1050 (32 bit) (59Hz)
                             Monitor Name: Dell E228WFP
                            Monitor Model: DELL E228WFP
                               Monitor Id: DELD014
                              Native Mode: 1680 x 1050(p) (59.954Hz)
                              Output Type: HD15
                              Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                      Driver File Version: 8.17.0012.5896 (English)
                           Driver Version: 8.17.12.5896
                              DDI Version: 10
                             Driver Model: WDDM 1.1
                        Driver Attributes: Final Retail
                         Driver Date/Size: 7/9/2010 18:38:00, 12471400 bytes
                              WHQL Logo'd: Yes
                          WHQL Date Stamp:
                        Device Identifier: {D7B71E3E-4B07-11CF-8464-920A1CC2C535}
                                Vendor ID: 0x10DE
                                Device ID: 0x0847
                                SubSys ID: 0x2A9E103C
                              Revision ID: 0x00A2
                      Driver Strong Name: oem45.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section020:8.17.12.5896:pci\ven_10de&dev_0847
                           Rank Of Driver: 00E62001
                              Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
                         Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                             D3D9 Overlay: Supported
                                  DXVA-HD: Supported
                             DDraw Status: Enabled
                               D3D Status: Enabled
                               AGP Status: Enabled
                      Sound Devices
                                  Description: Speakers (Logitech USB Speaker)
                      Default Sound Playback: Yes
                      Default Voice Playback: Yes
                                  Hardware ID: USB\VID_046D&PID_0A04&REV_0007&MI_00
                              Manufacturer ID: 65535
                                   Product ID: 65535
                                         Type: WDM
                                  Driver Name: USBAUDIO.sys
                               Driver Version: 6.01.7600.16385 (English)
                                  WHQL Logo'd: Yes
                                Date and Size: 7/13/2009 20:06:32, 109568 bytes
                                  Other Files:
                              Driver Provider: Microsoft
                               HW Accel Level: Basic
                                    Cap Flags: 0xF1F
                          Min/Max Sample Rate: 100, 200000
                      Static/Strm HW Mix Bufs: 1, 0
                      Static/Strm HW 3D Bufs: 0, 0
                                    HW Memory: 0
                             Voice Management: No
                      EAX(tm) 2.0 Listen/Src: No, No
                         I3DL2(tm) Listen/Src: No, No
                      Sensaura(tm) ZoomFX(tm): No
                                  Description: Realtek Digital Output (Realtek High Definition Audio)
                      Default Sound Playback: No
                      Default Voice Playback: No
                                  Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A9E&REV_1002
                              Manufacturer ID: 1
                                   Product ID: 100
                                         Type: WDM
                                  Driver Name: RTKVHD64.sys
                               Driver Version: 6.00.0001.5938 (English)
                                  WHQL Logo'd: Yes
                                Date and Size: 9/15/2009 15:08:00, 2004128 bytes
                                  Other Files:
                              Driver Provider: Realtek Semiconductor Corp.
                                    Cap Flags: 0xF1F
                                    HW Memory: 0
                      Sound Capture Devices
                      DirectInput Devices
                            Device Name: Mouse
                               Attached: 1
                          Controller ID: n/a
                      Vendor/Product ID: n/a
                              FF Driver: n/a
                            Device Name: Keyboard
                               Attached: 1
                          Controller ID: n/a
                              FF Driver: n/a
                            Device Name: Logitech USB Speaker
                               Attached: 1
                          Controller ID: 0x0
                      Vendor/Product ID: 0x046D, 0x0A04
                              FF Driver: n/a
                            Device Name: HP USB Multimedia Keyboard
                               Attached: 1
                          Controller ID: 0x0
                      Vendor/Product ID: 0x04F2, 0x0841
                              FF Driver: n/a
                               Attached: 1
                          Controller ID: 0x0
                              FF Driver: n/a
                               Attached: 1
                          Controller ID: 0x0
                              FF Driver: n/a
                      Poll w/ Interrupt: No
                      USB Devices
                      + USB Root Hub
                      | Vendor/Product ID: 0x10DE, 0x077B
                      | Matching Device ID: usb\root_hub
                      | Service: usbhub
                      | Driver: usbhub.sys, 10/24/2009 00:28:24, 343040 bytes
                      | Driver: usbd.sys, 7/13/2009 20:06:23, 7936 bytes
                      +-+ USB Input Device
                      | | Vendor/Product ID: 0x046D, 0xC05A
                      | | Matching Device ID: generic_hid_device
                      | | Service: HidUsb
                      | | Driver: hidusb.sys, 7/13/2009 20:06:22, 30208 bytes
                      | | Driver: hidclass.sys, 7/13/2009 20:06:21, 76288 bytes
                      | | Driver: hidparse.sys, 7/13/2009 20:06:17, 32896 bytes
                      | +-+ HID-compliant mouse
                      | | | Matching Device ID: hid_device_system_mouse
                      | | | Service: mouhid
                      | | | Driver: mouhid.sys, 7/13/2009 20:00:20, 31232 bytes
                      | | | Driver: mouclass.sys, 7/13/2009 21:48:27, 49216 bytes
                      Gameport Devices
                      PS/2 Devices
                      + HID Keyboard Device
                      | Matching Device ID: hid_device_system_keyboard
                      | Service: kbdhid
                      | Driver: kbdhid.sys, 7/13/2009 20:00:20, 33280 bytes
                      | Driver: kbdclass.sys, 7/13/2009 21:48:04, 50768 bytes
                      + Terminal Server Keyboard Driver
                      | Matching Device ID: root\rdp_kbd
                      | Upper Filters: kbdclass
                      | Service: TermDD
                      | Driver: i8042prt.sys, 7/13/2009 19:19:57, 105472 bytes
                      + Terminal Server Mouse Driver
                      | Matching Device ID: root\rdp_mou
                      | Upper Filters: mouclass
                      | Service: TermDD
                      | Driver: termdd.sys, 7/13/2009 21:45:55, 62544 bytes
                      | Driver: sermouse.sys, 7/13/2009 20:00:20, 26624 bytes
                      Disk & DVD/CD-ROM Drives
                            Drive: C:
                      Free Space: 741.1 GB
                      Total Space: 942.6 GB
                      File System: NTFS
                            Model: WDC WD10 EADS-65M2B1 SCSI Disk Device
                            Drive: D:
                      Free Space: 1.6 GB
                      Total Space: 11.2 GB
                      File System: NTFS
                            Drive: F:
                      Free Space: 117.3 GB
                      Total Space: 305.2 GB
                      File System: NTFS
                            Model: ST332062 0AS USB Device
                            Drive: E:
                            Model: hp CDDVDW TS-H653R SCSI CdRom Device
                           Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 19:19:54, 147456 bytes
                      System Devices
                           Name: LSI 1394 OHCI Compliant Host Controller
                      Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_2A9E103C&REV_70\4&F437630&0&2840
                         Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 20:07:13, 227840 bytes
                           Name: PCI standard PCI-to-PCI bridge
                      Device ID: PCI\VEN_10DE&DEV_077A&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&98
                         Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 21:45:45, 183872 bytes
                           Name: NVIDIA nForce System Management Controller
                      Device ID: PCI\VEN_10DE&DEV_0753&SUBSYS_2A9E103C&REV_A2\3&267A616A&0&0B
                         Driver: C:\Windows\system32\DRIVERS\nvsmu.sys, 5.10.2600.0171 (English), 6/29/2009 07:36:44, 28704 bytes
                         Driver: C:\Windows\system32\NVCOSMU.DLL, 1.04.0006.0041 (English), 4/24/2009 18:43:50, 159232 bytes
                         Driver: C:\Windows\system32\nvusmu.exe, 1.05.0033.0011 (English), 7/21/2009 07:48:38, 539680 bytes
                         Driver: C:\Windows\system32\nvsmu.nvu, 7/16/2009 22:55:22, 1463 bytes
                           Name: PCI standard host CPU bridge
                      Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
                         Driver: n/a
                           Name: NVIDIA nForce Serial ATA Controller
                      Device ID: PCI\VEN_10DE&DEV_0AD4&SUBSYS_2A9E103C&REV_A2\3&267A616A&0&48
                         Driver: n/a
                      Device ID: PCI\VEN_10DE&DEV_0778&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&80
                           Name: NVIDIA nForce PCI System Management
                      Device ID: PCI\VEN_10DE&DEV_0752&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&09
                         Driver: n/a
                      Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
                         Driver: n/a
                           Name: NVIDIA GeForce 9100
                      Device ID: PCI\VEN_10DE&DEV_0847&SUBSYS_2A9E103C&REV_A2\4&E0FA224&0&0058
                         Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 189032 bytes
                         Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/9/2010 18:38:00, 261268 bytes
                         Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_e3981c6eee5931b7 \NvCplSetupEng.exe, 14.00.0000.0162 (English), 7/9/2010 18:38:00, 23969016 bytes
                         Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 11240 bytes
                         Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 13187176 bytes
                         Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 18:38:00, 65128 bytes
                         Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 7/18/2009 05:41:00, 930272 bytes
                         Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 2037864 bytes
                         Driver: C:\Windows\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 14513768 bytes
                         Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 6116968 bytes
                         Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 2761832 bytes
                         Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 3089512 bytes
                         Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 12471400 bytes
                         Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 382568 bytes
                         Driver: C:\Windows\system32\nvinfo.pb, 7/9/2010 18:38:00, 12264 bytes
                         Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 19114088 bytes
                         Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 7002216 bytes
                         Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 18:38:00, 56936 bytes
                         Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 1625192 bytes
                         Driver: C:\Windows\SysWow64\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 10267240 bytes
                         Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 4553832 bytes
                         Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 2506344 bytes
                         Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 2892904 bytes
                         Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 9818728 bytes
                         Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 314984 bytes
                         Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 14092904 bytes
                         Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.5896 (English), 7/9/2010 18:38:00, 5107816 bytes
                         Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/9/2010 18:38:00, 24011 bytes
                         Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/9/2010 18:38:00, 660072 bytes
                         Driver: C:\Windows\system32\nvcod.dll, 1.09.0022.0107 (English), 7/9/2010 18:38:00, 260712 bytes
                         Driver: C:\Windows\system32\nvcod1922.dll, 1.09.0022.0107 (English), 7/9/2010 18:38:00, 260712 bytes
                           Name: High Definition Audio Controller
                      Device ID: PCI\VEN_10DE&DEV_0774&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&38
                         Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:13, 122368 bytes
                           Name: PCI standard RAM Controller
                      Device ID: PCI\VEN_10DE&DEV_0751&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&0A
                         Driver: n/a
                           Name: Standard Enhanced PCI to USB Host Controller
                      Device ID: PCI\VEN_10DE&DEV_077E&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&21
                         Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16445 (English), 10/24/2009 00:27:33, 51712 bytes
                         Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:31, 324608 bytes
                         Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16445 (English), 10/24/2009 00:28:24, 343040 bytes
                           Name: NVIDIA nForce 10/100 Mbps Ethernet
                      Device ID: PCI\VEN_10DE&DEV_0760&SUBSYS_2A9E103C&REV_A2\3&267A616A&0&50
                         Driver: n/a
                      Device ID: PCI\VEN_10DE&DEV_0569&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&58
                           Name: Standard OpenHCD USB Host Controller
                      Device ID: PCI\VEN_10DE&DEV_077D&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&20
                         Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:30, 25600 bytes
                           Name: PCI standard ISA bridge
                      Device ID: PCI\VEN_10DE&DEV_075C&SUBSYS_2A9E103C&REV_A2\3&267A616A&0&08
                         Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 21:48:27, 15424 bytes
                      Device ID: PCI\VEN_10DE&DEV_0568&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&0C
                         Driver: n/a
                      Device ID: PCI\VEN_10DE&DEV_077C&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&11
                      Device ID: PCI\VEN_10DE&DEV_075B&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&90
                      Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
                         Driver: n/a
                      Device ID: PCI\VEN_10DE&DEV_077B&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&10
                      Device ID: PCI\VEN_10DE&DEV_075A&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&40
                      Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
                         Driver: n/a
                      Device ID: PCI\VEN_10DE&DEV_077A&SUBSYS_2A9E103C&REV_A1\3&267A616A&0&A0
                      Device ID: PCI\VEN_10DE&DEV_0754&SUBSYS_2A9E103C&REV_A2\3&267A616A&0&00
                         Driver: n/a
                      Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
                         Driver: n/a
                      DirectShow Filters
                      DirectShow Filters:
                      WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
                      WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
                      WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
                      MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                      Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                      WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
                      WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
                      Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                      Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                      DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
                      Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
                      WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
                      Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
                      AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
                      VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
                      StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
                      MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
                      CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
                      MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
                      SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
                      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16590
                      Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
                      SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
                      Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
                      MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
                      PlayReady DMO Wrapper,0x00600002,1,1,PRDMOW~1.DLL,1.03.2297.0000
                      DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
                      Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
                      MS PR Source Filter,0x00200000,0,2,PRSource.dll,1.03.2297.0000
                      Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
                      ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
                      Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
                      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      Line 21 Decoder,0x00600000,1,1,,
                      Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
                      Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
                      VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
                      WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
                      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
                      File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
                      iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
                      iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
                      DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
                      Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
                      Overlay Mixer2,0x00200000,1,1,,
                      RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                      Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
                      WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
                      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
                      DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
                      SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
                      Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
                      MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
                      Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
                      StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
                      Overlay Mixer,0x00200000,0,0,,
                      AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
                      NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
                      AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
                      Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
                      Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                      StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
                      AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
                      Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
                      File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
                      File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
                      Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
                      AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                      AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                      SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                      Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
                      Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
                      BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
                      MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
                      WDM Streaming Tee/Splitter Devices:
                      Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Video Compressors:
                      WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                      WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                      MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                      DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
                      MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
                      Audio Compressors:
                      WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                      WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                      IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
                      PBDA CP Filters:
                      PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16590
                      PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
                      PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
                      Midi Renderers:
                      Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
                      Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
                      WDM Streaming Capture Devices:
                      JVC GR-DX77,0x00200000,1,2,ksproxy.ax,6.01.7600.16385
                      Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      WDM Streaming Rendering Devices:
                      Realtek HD Audio front output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Realtek HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      Logitech USB Speaker,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
                      BDA Network Providers:
                      Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
                      Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
                      Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
                      Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
                      Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16590
                      Video Capture Sources:
                      Multi-Instance Capable VBI Codecs:
                      BDA Transport Information Renderers:
                      BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
                      MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
                      BDA CP/CA Filters:
                      Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
                      Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
                      PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
                      XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
                      External Renderers:
                      WDM Streaming Communication Transforms:
                      Audio Renderers:
                      Speakers (Logitech USB Speaker),0x00200000,1,0,quartz.dll,6.06.7600.16490
                      Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
                      Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
                      DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16490
                      DirectSound: Speakers (Logitech USB Speaker),0x00200000,1,0,quartz.dll,6.06.7600.16490
                      Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7600.16490
                      EVR Power Information
                      Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                        Quality Flags: 2576
                          Enabled:
                          Force throttling
                          Allow half deinterlace
                          Allow scaling
                          Decode Power Usage: 100
                        Balanced Flags: 1424
                          Enabled:
                          Force throttling
                          Allow batching
                          Force half deinterlace
                          Force scaling
                          Decode Power Usage: 50
                        PowerFlags: 1424
                          Enabled:
                          Force throttling
                          Allow batching
                          Force scaling
                          Decode Power Usage: 0
                      • 8. Re: video preview/playback not working
                        jimsvideo Level 1
                        Nevermind
                        I've given up, un-installed Premeire Elements 8 (along with Photoshop Elements 8) and have processed a refund.  For my relatively simple editing needs, Corel Video Studio Pro X3 seems to be working flawlessly.
                        Thanks for the support and assistance either way.
                        • 9. Re: video preview/playback not working
                          nealeh Level 5
                          Sorry to hear nothing worked for you but pleased you found a solution with Corel. Once it's released you could try the PRE9 trila (possibly September/October).
                          Cheers,
                          Neale
                          • 10. Re: video preview/playback not working
                            the_wine_snob Level 9
                            There is nothing wrong with using the software that works best for you. I've got a whole "toolbox" full of NLE's, and use the one that suits a particular need.
                            I do not hear that much about the Corel product, but use their WordPefect and Painter, plus a few of their lesser programs, and enjoy them. [Now, I came to WordPerfect at the very beginning - long before Corel, and also Painter - long before Corel.]
                            Happy editing, and sorry that we could not get PrE running smoothly for you.
                            • 11. Re: video preview/playback not working
                              jimsvideo Level 1
                              I'm looking forward to running a trial of PRE9.  I'll stick with trial versions for now, as I've done with Corel
                              Thanks again.
