1 Reply Latest reply on Jan 19, 2011 6:16 AM by gpothier
    Component with JPA
    Richard Wegier Level 1
      Hi everybody
      We just built a component that uses JPA for data access. We use the javax.persistence library. The JPA configuration file (persistence.xml) and the generated entity classes are packed within the jar-file of the component. Unfortunately the LiveCyle environment does not seem to recognize the mentioned files within the jar file. To get it running we had to deploy a web project (war-file) that only includes the mentioned files. With this work-around LiveCycle knows the the files and we can establish a connection to the Oracle database successfully.
      My question is, if there is a better way to get a component that uses JPA connected with the database? For me it would be much better if I only would have to deploy the component jar.
      Any comments are welcome
      Best wishes, Richard
        • 1. Re: Component with JPA
          gpothier
          Hi Richard,
          Unfortunately I have no answer to your question, I rather have a few questions for you actually:
          - Did you eventually manage to use JPA satisfactorily, ie. without having to create a separate war file? If so, how?
          - Do you connect to the LiveCycle database, or to another one? I you connect to the LiveCycle database, would it be possible for you to post your persistence.xml file?
          Kind regards,
          Guillaume Pothier
