8 Replies Latest reply on Aug 24, 2010 11:22 PM by DikHendriks
    Adding Soap Header to a Soap webservice
    DikHendriks Level 1
      I have generated a Soap Webservice in Flashbuilder and need to add A Soap Header with 3 variables.
      Can anyone tell me how this is done?
        • 1. Re: Adding Soap Header to a Soap webservice
          Balakrishnan V Level 3
          http://livedocs.adobe.com/flex/3/langref/mx/rpc/soap/AbstractWebService.html#addHeader()
          addHeader(header:Object):void
          This adds to the headers:Array member of the WebService Class.
          The header object is to be queued as header[headerName]=headerValue.
          It is preferable however that you create a SoapHeader object, whose constructor takes a qname:QName and content:Object as arguments and constructs the header
          You may also use the addSimpleHeader(qnameLocal:String,qnameNamespace:String,headerName:String,headerValue:Str ing):void method.
          This creates a SoapHeader object, whose QName is constructed from the Local and Namespace Strings and a content object with the headerValue keyed on the headerName property.
          Hope this helps,
          Balakrishnan V
          • 2. Re: Adding Soap Header to a Soap webservice
            DikHendriks Level 1
            Hello,
            Thanx for yor response...
            However i am a newbee in this matter.
            Here is my code, can you look at it fill in the blancs, correct it?
            * This is a generated class and is not intended for modification.  To customize behavior
            * of this service wrapper you may modify the generated sub-class of this class - Ticketunie.as.
            package server.services.ticketunie
            import com.adobe.fiber.core.model_internal;
            import com.adobe.fiber.services.wrapper.WebServiceWrapper;
            import com.adobe.serializers.utility.TypeUtility;
            import mx.rpc.AbstractOperation;
            import mx.rpc.AsyncToken;
            import mx.rpc.soap.mxml.Operation;
            import mx.rpc.soap.mxml.WebService;
            import mx.rpc.soap.SOAPHeader;
            [ExcludeClass]
            internal class _Super_Ticketunie extends com.adobe.fiber.services.wrapper.WebServiceWrapper
                // Constructor
                public function _Super_Ticketunie()
                    // initialize service control
                    _serviceControl = new mx.rpc.soap.mxml.WebService();
                    var operations:Object = new Object();
                    var operation:mx.rpc.soap.mxml.Operation;
                    operation = new mx.rpc.soap.mxml.Operation(null, "HelloWorldAuth");
                    operation.resultType = String;
                    operations["HelloWorldAuth"] = operation;
                    _serviceControl.operations = operations;
                    try
                        _serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
                    catch (e: Error)
                    { /* Flex 3.4 and eralier does not support the convertResultHandler functionality. */ }
                    _serviceControl.service = "Service";
                    _serviceControl.port = "ServiceSoap";
                    wsdl = "http://secure.ticketunie.com/iresWs/service.asmx?WSDL";
                    model_internal::loadWSDLIfNecessary();
                    model_internal::initialize();
                            public var header1:SOAPHeader;
                            public var header2:SOAPHeader;
                            public var header3:SOAPHeader;
                            public function headers():void {
                                // Create QName and SOAPHeader objects.
                                var q1:QName=new QName("http://soapinterop.org/xsd", "Header1");
                                header1=new SOAPHeader(q1, {string:"Trsid",int:"value1"});
                                header2=new SOAPHeader(q1, {string:"Coho",int:"value2"});
                                header3=new SOAPHeader(q1, {string:"Key",string:"value3"});
                                // Add the header1 SOAP Header to all web service request.
                                ???.addHeader(header1);
                                ???.addHeader(header2);
                                ???.addHeader(header3);
                  * This method is a generated wrapper used to call the 'HelloWorldAuth' operation. It returns an mx.rpc.AsyncToken whose
                  * result property will be populated with the result of the operation when the server response is received.
                  * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
                  * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
                  * @see mx.rpc.AsyncToken
                  * @see mx.rpc.CallResponder
                  * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
                public function HelloWorldAuth() : mx.rpc.AsyncToken
                    var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("HelloWorldAuth");
                    var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
                    return _internal_token;
            • 3. Re: Adding Soap Header to a Soap webservice
              http://livedocs.adobe.com/flex/3/langref/mx/rpc/soap/Operation.html#addHeader()
              The operation can also add an header.
              Use the appropriate operation to which you want to add the header.
              Here, "operation" or "operations["HelloWorldAuth"] can be used
              operations["HelloWorldAuth"].addHeader();
              This should work !(I have not tried it out though !)
              Try it and tell me if it works
              balakrishnan v
              • 4. Re: Adding Soap Header to a Soap webservice
                DikHendriks Level 1
                I've tried this, but it did not work. I get a response value
                of -4, should be 1.
                Hre is my code again (tried operations["HelloWorldAuth"].addHeader(); also).
                import mx.rpc.soap.Operation;
                [ExcludeClass]
                    // Constructor
                        try
                        catch (e: Error)
                        var q1:QName=new QName("http://secure.ticketunie.com/", "Header1");
                        header1=new SOAPHeader(q1, {string:"Trsid",int:"299"});
                        header2=new SOAPHeader(q1, {string:"Coho",int:"1"});
                        header3=new SOAPHeader(q1, {string:"Key",string:"70db3164e4421b33bd9f170db3164e4421b33bd9f1"});
                        operations.addHeader(header1);
                        operations.addHeader(header2);
                        operations.addHeader(header3);
                • 5. Re: Adding Soap Header to a Soap webservice
                  DikHendriks Level 1
                  Solved the problem...
                  • 6. Re: Adding Soap Header to a Soap webservice
                    Could I know what you did to solve the issue ? It might be helpful for the forum to have a record of the solution as well !
                    Balakrishnan V
                    • 7. Re: Adding Soap Header to a Soap webservice
                      DikHendriks Level 1
                      Hello,
                      The key was putting the soapheader variables in an object...
                                var obj:Object=new Object();
                                obj.headerName1 = value1;
                                obj.headerName2 = value2;
                                obj.headerName3 = "value3";
                                var qname:QName=new QName("http://secure.website.com/",
                      "AuthenticationHeader");
                                var header1:SOAPHeader = new SOAPHeader(qname, obj);
                                operations["certainCall"].addHeader(header1);
                      I shall post the solution in the forum...
                      Met vriendelijke groeten, Dik Hendriks
                      Hendriks grafische vormgeving / webdesign
                      (038) 332 49 79
                      Dit e-mail-bericht is alleen bestemd voor de geadresseerde(n). Indien
                      dit bericht niet voor u is bedoeld, wordt u verzocht de afzender
                      hiervan op de hoogte te stellen door het bericht te retourneren en
                      de inhoud niet te gebruiken. Aan dit bericht kunnen geen rechten
                      worden ontleend.
                      Op 25 aug 2010, om 05:16 heeft Balakrishnan V het volgende geschreven:
                      Balakrishnan V
                      • 8. Re: Adding Soap Header to a Soap webservice
                        DikHendriks Level 1
                                var qname:QName=new QName("http://secure.website.com/", "AuthenticationHeader");
