1 Reply Latest reply on Jul 27, 2007 3:57 AM by kleptomac
    Remoting error with Flex Stress testing
    kleptomac
      I am using Flex stress testing framework for testing an application that uses Remote object to connect to a java class, which in-turn connects to a MySQL database to retrieve somewhere around 20,000 records. When I run a single instance of the application, it works fine. If I try to open multiple instances of the application (for stress testing purpose), some of the instances fail to initialize and throw the following error (even before I trigger the code to retrieve the data from remote object):
      ArgumentError: Error #2082: Connect failed because the object is already connected.
      at flash.net::LocalConnection/connect()
      at mx.managers::HistoryManagerImpl$iinit()
      at mx.managers::HistoryManagerImpl$/getInstance()
      at mx.core::Singleton$/getInstance()
      at mx.managers::HistoryManager$/get ::impl()
      at mx.managers::HistoryManager$/register()
      at mx.containers::ViewStack/mx.containers:ViewStack::commitProperties()
      at mx.core::UIComponent/validateProperties()
      at mx.managers::LayoutManager/::validateProperties()
      at mx.managers::LayoutManager/::doPhasedInstantiation()
      at Function/ http://adobe.com/AS3/2006/builtin::apply()
      at mx.core::UIComponent/::callLaterDispatcher2()
      at mx.core::UIComponent/::callLaterDispatcher()
      Can anybody please help me understand what the problem could be. I have tried searching the internet for a solution but to no avail.
      Thanks in advance. Please help...
