0 Replies Latest reply on Aug 19, 2010 9:58 AM by leardas
    Flash Search Bar
    leardas
      Hello, I am trying to create a search bar within flash which will generate links to frames within my flash project based off of given text. I have found a flash project online which does almost exactly what I need, but it only allows for searching a single word rarther than a full term or sentence. It also gives no error message when no word match is found. I am not very good at actionscript or I would be able to midify myself. Any help would be very helpful. Here is the code given:
      stop();
      var testText0:String = "this is some test text one";
      var testText1:String = "this is some test text two";
      var testText2:String = "this is some test text three";
      var testText3:String = "this is some test text four";
      var textArr = new Array();
      textArr[0] = _level0.testText0;
      textArr[1] = _level0.testText1;
      textArr[2] = _level0.testText2;
      textArr[3] = _level0.testText3;
      function goPage(page){
      _root.gotoAndStop(page);
      var keyword = new Array();
      _root.search.onRelease = function(){
      _root.linkText = "";
      for(j = 0; j < textArr.length; j++){
      _level0["count"+j] = 0;
      var p:Number = j+1;
      keyword = textArr[j].split(" ");
      for(i = 0; i < keyword.length; i++){
      if(keyword[i].charAt(keyword[i].length-1) == ","){
      l = keyword[i].lastIndexOf(",")-1;
      wordmatch = keyword[i].substring(0,(l+1));
      }else if(keyword[i].charAt(keyword[i].length-1) == "."){
      l = keyword[i].lastIndexOf(".")-1;
      }else if(keyword[i].charAt(keyword[i].length-1) == "?"){
      l = keyword[i].lastIndexOf("?")-1;
      }else{
      wordmatch = keyword[i];
      if(_root.searchTxt.toLowerCase() == wordmatch.toLowerCase()){
      _level0["count"+j]+=1;
      if(_level0["count"+j] <= 1){
      _root.linkText += ("<a href=\"asfunction:goPage,"+p+"\">page "+p+" contains the word <font color=\"#FF0000\"><B><I>"+wordmatch+"</I></B></font></a><br />");
      The original .fla file can be dowloaded here:
      http://www.flashkit.com/movies/Scripting/flash_si-Andrew_B-10884/index .php
