12 Replies Latest reply on Aug 26, 2010 8:35 AM by flexillu10
    What can i use Data/Services for?
    flexillu10 Level 1
      I have a datagrid displaying data from my database and i can get access to whichever data item i want.
      What i want to do is use data from the database without creating a data grid, how can i do that?
      e.g displaying a text field from the database in a textbox, how would i do this without calling datagrid.selecteditem...?
        • 1. Re: What can i use Data/Services for?
          Balakrishnan V Level 3
          You can store the results of a service invocation as an arraycollection of records and access items from within the arraycollection.
          Does this answer your query ?
          Balakrishnan V
          • 2. Re: What can i use Data/Services for?
            flexillu10 Level 1
            Balakrishnan V
            Yes this is what i was looking for, could you give me some example code? And where would i put this code? in the first windowed application tag?
            • 3. Re: What can i use Data/Services for?
              Prestine Level 1
              Hello,
              You can create a Singleton Class and declare one variable in this class, which will contain/hold the results of a service invocation.
              You can use this variable whereever  you want in the whole Application.
              Regards,
              • 4. Re: What can i use Data/Services for?
                flexillu10 Level 1
                Prestine wrote:
                Hello,
                Regards,
                what type of variable? an array? or arrayCollection? can you give me some example code
                • 5. Re: What can i use Data/Services for?
                  <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                     xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="windowedapplication1_creationCompleteHandler(event)">
                  <fx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.ResultEvent;
                  [Bindable] private var resultData:ArrayCollection=new ArrayCollection()
                  protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                  // TODO Auto-generated method stub
                  myHTTPService.send()
                  protected function myHTTPService_resultHandler(event:ResultEvent):void
                  resultData=event.result as ArrayCollection;
                  // resultData=myHTTPService.lastResult as ArrayCollection
                  </fx:Script>
                  <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
                  <s:HTTPService id="myHTTPService" result="myHTTPService_resultHandler(event)"
                     url=""/>
                  </fx:Declarations>
                  </s:WindowedApplication>
                  Hope this helps,
                  Balakrishnan V
                  • 6. Re: What can i use Data/Services for?
                    And .. why should there be a singleton class and not a simple ArrayCollection ?
                    • 7. Re: What can i use Data/Services for?
                      flexillu10 Level 1
                      ok thanks a lot that does help. But can i just check
                      My applicaiton needs to be as follows
                      i have images stored at a http web address, i have a database storing the url's of the images. I want my air app to go to to the url, grab the image and open it with windows picture and fax viewer.
                      I have acheived this so far using a datagrid, i used flash builder data connect wizard to connect to the database, and it generated some services. I used the get all service and dragged it onto a datagrid. I then used whichever field i needed and was successful. However now i want to display the jpegs as clickable images so the user can click the image to open it instead of selecting one from the data grid.
                      Therefore i jsut need this get all service stored as an array collection don't i?
                      So thanks for the code, but it seems to use a http service, which i'm now not sure if i need
                      • 8. Re: What can i use Data/Services for?
                        Prestine Level 1
                        Depends, what kind of data is coming from the service side
                        • 9. Re: What can i use Data/Services for?
                          Prestine Level 1
                          If It is used in a single class/component then arraycollection is ok.
                          but if the arraycollection will be used in different components , then arraycollection has to be stored in Singleton Class and used whereever required...... right or wrong?
                          Thanks and Regards,
                          • 10. Re: What can i use Data/Services for?
                            flexillu10 Level 1
                            the data coming in will be text strings, i just want to use the text fields,
                            My question is:
                            how do i bind the service to an array or something else instead of binding it to a datagrid?
                            • 11. Re: What can i use Data/Services for?
                              Prestine Level 1
                              [Bindable]
                              private var str:String;
                              in the result method, you will use this code, to get the value return from the service end.
                                                        str   = event.result as String;
                              Use  str where ever you want.
                              Regards,
                              • 12. Re: What can i use Data/Services for?
                                flexillu10 Level 1
                                Hello,
                                Sorry but i have no idea how to generate a result handler for a service that i don't know how to call.
                                Before i just dragged the php service onto a datagrid, i just want to do the same but store it in an array, Please can you give me an "idiot's guide" for how i would do this
