4 Replies Latest reply on Sep 7, 2010 10:46 PM by Anirudh Sasikumar
    Export Release Build errors
    jsd99
      This just started happening to me in the last day or two.  Every time I try to use Export Release Build, I get an error:
      A folder named bin-release already exists with different case.
      I checked my entire workspace folder and removed every bin-release folder, but the error persists.  Is there any way I can get more info on what is annoying it?  (Or better yet, a cure...)
        • 1. Re: Export Release Build errors
          Anirudh Sasikumar Adobe Employee
          Interesting - Can you please go to the folder in Explorer/Finder and look to see if there are any bin-* folders? Delete bin-debug and bin-release if you find it.
          Now, switch back to Flash Builder/Eclipse and right click your project and choose refresh.
          Hopefully that should short things out. It would also be interesting to look at your log - can you post it here?
          (It should be in workspacedir/.metadata/.log)
          • 2. Re: Export Release Build errors
            Jamie Scanlon-Jacobs
            I've been getting the same error. Here's my log:
            !ENTRY com.adobe.flexbuilder.project 4 43 2010-09-07 15:03:56.806
            !MESSAGE Uncaught exception in compiler
            !STACK 0
            java.lang.ArrayIndexOutOfBoundsException: 1129796362
                    at flex2.compiler.PersistenceStore.readCompilationUnit(PersistenceStore.java:1568)
                    at flex2.compiler.PersistenceStore.readCompilationUnits(PersistenceStore.java:1541)
                    at flex2.compiler.PersistenceStore.read(PersistenceStore.java:958)
                    at flex2.compiler.CompilerAPI.loadCompilationUnits(CompilerAPI.java:4856)
                    at flex2.compiler.CompilerAPI.loadCompilationUnits(CompilerAPI.java:4835)
                    at flex2.tools.oem.Application.loadCompilationUnits(Application.java:706)
                    at flex2.tools.oem.Application.recompile(Application.java:1071)
                    at flex2.tools.oem.Application.compile(Application.java:819)
                    at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication.java:344)
                    at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder$MyBuilder.mybuild(A SApplicationBuilder.java:276)
                    at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.build(ASApplication Builder.java:127)
                    at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBuilder.java:190)
                    at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.build(ASItemBuilder.java:7 4)
                    at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(FlexProjectB uilder.java:480)
                    at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuild er.java:306)
                    at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncremen talBuilder.java:157)
                    at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:627)
                    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                    at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
                    at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
                    at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
                    at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
                    at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
                    at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
                    at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
                    at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
                    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
            • 3. Re: Export Release Build errors
              jsd99 Level 3
              I edited the .project file and found that there were two <link> sections under <linkedResources>.  Deleting one fixed the problem for me.
              • 4. Re: Export Release Build errors
                Hi Jamie,
                Looks like you are running into: http://bugs.adobe.com/jira/browse/SDK-26799
                Anirudh
