2 Replies Latest reply on Aug 20, 2010 3:46 AM by welcomecan
    data reterive problem?
    welcomecan Level 1
      hai friends,
        i reterive  data from db.i sent two queries using struct. In flex i am creating dynamic form.
      var
      resdata2:ArrayCollection=event.result.RES2;
      var resdata1:ArrayCollection=event.result.RES1;
      for(i=0;i<resdata1.length;i++)
      var
      lblform:Label=new Label();
      lblform.text=resdata1[i].spk_name;
      lblform.width=100;
      lbl.addElement(lblform);
      if(resdata1[i].hasOptionsList==null)
      var newtxtbox:TextInput=new TextInput();
      newtxtbox.width=300;
      var txtres:String;
      txtres=resdata1[i].keyvariablename;// db field name
      var tmpdata:String=resdata2[0]+"."+txtres;// here issue
      newtxtbox.text=tmpdata;
      lbl.addElement(newtxtbox);
      help me
        • 1. Re: data reterive problem?
          Balakrishnan V Level 3
          Could you elaborate ? What is the issue ? Or else, just post your code here fully, if it is small enough !
          • 2. Re: data reterive problem?
            welcomecan Level 1
            in resdata2 inclde data
              dname->document name,
            dnum->document number
            <s:Application
            xmlns:fx="http://ns.adobe.com/mxml/2009"
            xmlns:s="
            library://ns.adobe.com/flex/spark"
            xmlns:mx="
            library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
            <fx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            import mx.containers.FormItem;
            import mx.controls.Alert;
            import mx.controls.Text;
            import spark.components.ComboBox;
            public function txtchange():void
            var a:String=txtarea.text;
            public function search_click()
            //var date:Date = new Date();
            //Alert.show("Date: "+date.toLocaleString());
            //Logon.fnatt("view","4563","0");
            //Logon.viewf("1","4436","","file_view","Open");
            //Logon.fneditatt("Edit","4080");
            //Logon.editattr("do_edit","B59BAA32CD9C28E5825FC281109E6228","4563","New Text Document_20100323003136805.txt", " ","{ts '2010-07-27 00:41:20'}","New Text Document","New Text Document","txt","Testing file","TEsting file","this is test file.. asa dhan");
            //Logon.editattrfirst("Edit","4387");
            Logon.fneditatt(
            "Edit","3986");
            private function handlelogonResult(event):void
            if(event.result)
            var resdata:ArrayCollection=event.result.RES2;
            var profileid:int;
            var i:int;
            if(resdata[0].storage_profile_id==null)
            /* for(i=0;i<resdata.length;i++)
            Alert.show("welcome","alert");
            Alert.show(
            "single","alert");
            else
            var resdata2:ArrayCollection=event.result.RES2;
            /* var tmpLbl:Label = new Label();
            tmpLbl.x = 10;
            tmpLbl.y = 5;
            tmpLbl.text = "Label Text"; */
            /* var k:int = 30;
            var j: int = 40;
            var counter:int = 0; */
            /* var newlabel:Label=new Label();
            newlabel.text=resdata1[i].spk_name;
            //pn.addChild(newlabel);
            pn.addElement(newlabel);
            k =125;
            j+=20;
            if (counter >=resdata1.length)
            { counter = 0; k=10; j+=30;}
            newlabel.x= k ;
            newlabel.y = j;
            counter++; */
            pn.visible=
            false;
            //var lbl : Label = new Label();
            var lbl:FormItem=new FormItem();
            /* lbl.width = 130;
            lbl.height = 27;
            lbl.label = resdata1[i].spk_name; */
            lbl.direction=
            "horizontal";
            //lblContainer.addChild(lbl);
            var lblform:Label=new Label();
            lblform.width=100;
            newtxtbox.id=
            "txt_"+ resdata1[i].keyvariablename;
            newtxtbox.text=resdata2  // first txtbox i need document name.second txtbo i need documentnumber
                                                             //i am used to take length of resdata.but it shows 1
            if(resdata1[i].hasOptionsList!==null)
            var newcb:ComboBox=new ComboBox();
            newcb.width=300;
            /* newcb.height=27; */
            //var bindata:ArrayCollection=resdata1[i].ruleName;
            /* var n:int; */
            /* for(n=0;n<resdata1[i].ruleName.length;n++)
            tem[n]=resdata1[i].ruleName[n].spko_value.concat();
            /* tem=resdata1[i].ruleName.spko_value.concat(); */
            var tempdata:ArrayCollection=resdata1[i].ruleName;
            //newcb.dataProvider=bindata;
            newcb.dataProvider=tempdata;
            newcb.labelField=
            "spko_value";
            lbl.addElement(newcb);
            lblContainer.addElement(lbl);
            pn1.visible=
            true;
            lblContainer.visible=
            true;
            /* var m:int=40;
            newtxtbox.text="1";
            pn.addElement(newtxtbox);
            k=250;
            m+=30;
            { counter = 0; k=10; m+=30;}
            newtxtbox.x= k ;
            newtxtbox.y = m;
            counter++;
            pn1.title=resdata1[0].ProfileName;
            //Alert.show("Double","alert");
            //pn.visible=true;
            private function handlelogonFault(event):void
            Alert.show(event.fault.message);
            //Alert.show("Incorrect","Alert");
            </fx:Script>
            <s:Button id="btn_search" x="220" y="20" label="Search" click="search_click();"/>
            <s:TextArea id="txtarea" change="txtchange()" />
            <!--<s:VGroup id="lblContainer" width="180" height="150" verticalAlign="middle" verticalScrollPosition="2" />-->
            <s:Panel title="Form Container Example" id="pn1"
            horizontalCenter="
            0" verticalCenter="0" visible="false">
            <!--<s:VGroup left="10" right="10" top="10" bottom="10">-->
            <mx:HBox>
            <mx:Form
            id="
            lblContainer" verticalGap="2" indicatorGap="14" paddingBottom="10"
            paddingTop="
            16"
            </mx:HBox>
            <!--</s:VGroup>-->
            </s:Panel>
            <!--<mx:VBox id="lblContainer" width="180" height="150" verticalGap="2" visible="false"/>-->
            <s:Panel id="pn" width="100%" visible="false">
            <s:Label id="newlabel" x="200" y="300"/>
            <s:TextInput id="newtxtbox" />
            </s:Panel>
            <fx:Declarations>
            <s:RemoteObject destination="ColdFusion" id="Logon" source="IST_Business_Applications.IST_Docstor.file_access.editattrfirst" >
            <s:method name="fneditatt" fault="handlelogonFault(event)" result="handlelogonResult(event)" />
            </s:RemoteObject>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
            </fx:Declarations>
            </s:Application>
