1. Re: How to export my vector lines at different sizes
Jacob Bugge Aug 20, 2010 6:46 AM (in response to jt77474)jt,
a) As long as you keep the original vector artwork, it is beyond resolution (infinitely scaleable). To get a 640 x 320 px JPEG, set the reolution (as Export option) to 640/W, where W is the Width in inches; or similarly for height. If you want an RGB JPEG, you may Save for Web & Devices and just set the Image Size to 640 x 360.
b) Not unless introduced in the latest version(s).
2. Re: How to export my vector lines at different sizes
Wade_Zimmerman Aug 20, 2010 7:38 AM (in response to Jacob Bugge)Jacob Bugge wrote:
jt,
I definitely do not know of this option though it would be good to have such a setting.
But what you have do if you are not using Save for Device and Web is to actually make a copy of the art turn off the visibility of the original art
then resize the copy to your desired dimension either width or height, in this case probably width.Then make a new art board, holding the shift key down allows you to make one within the bounds of another artboard.
Then double click the artboard tool to enter the dimension of you desired jpeg
then reposition the art in the artboard you just made and then export to jpeg using the Use Artboard option and selecting that artboard.
So if you set the artboard to 640x360 pixels that is what you will get.
Save for Device and Web is easier there you can enter dimensions
3. Re: How to export my vector lines at different sizes
jt77474 Aug 22, 2010 5:09 AM (in response to Wade_Zimmerman)Thank you for your helpful replies
