0 Replies Latest reply on Aug 20, 2010 4:57 AM by welcomecan
    data bind problem in txtbox?
    welcomecan Level 1
      hai friends,
      below my code
      in resdata2 inclde data
        dname->document name,
      dnum->document number
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      library://ns.adobe.com/flex/spark"
      library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Script>
      import mx.collections.ArrayCollection;
      import mx.containers.FormItem;
      import mx.controls.Alert;
      import mx.controls.Text;
      import spark.components.ComboBox;
      public function txtchange():void
      var a:String=txtarea.text;
      public function search_click()
      //var date:Date = new Date();
      //Alert.show("Date: "+date.toLocaleString());
      //Logon.fnatt("view","4563","0");
      //Logon.viewf("1","4436","","file_view","Open");
      //Logon.fneditatt("Edit","4080");
      //Logon.editattr("do_edit","B59BAA32CD9C28E5825FC281109E6228","4563"," New Text Document_20100323003136805.txt", " ","{ts '2010-07-27 00:41:20'}","New Text Document","New Text Document","txt","Testing file","TEsting file","this is test file.. asa dhan");
      //Logon.editattrfirst("Edit","4387");
      "Edit","3986");
      private function handlelogonResult(event):void
      if(event.result)
      var resdata:ArrayCollection=event.result.RES2;
      var profileid:int;
      var i:int;
      if(resdata[0].storage_profile_id==null)
      /* for(i=0;i<resdata.length;i++)
      Alert.show(
      "single","alert");
      else
      var resdata2:ArrayCollection=event.result.RES2;
      var resdata1:ArrayCollection=event.result.RES1;
      for(i=0;i<resdata1.length;i++)
      /* var tmpLbl:Label = new Label();
      /* var k:int = 30;
      /* var newlabel:Label=new Label();
      false;
      //var lbl : Label = new Label();
      var lbl:FormItem=new FormItem();
      /* lbl.width = 130;
      "horizontal";
      //lblContainer.addChild(lbl);
      var lblform:Label=new Label();
      if(resdata1[i].hasOptionsList==null)
      var newtxtbox:TextInput=new TextInput();
      "txt_"+ resdata1[i].keyvariablename;
      newtxtbox.text=resdata2  // first txtbox i need document name.second txtbo i need documentnumber
      if(resdata1[i].hasOptionsList!==null)
      var newcb:ComboBox=new ComboBox();
      /* newcb.height=27; */
      //var bindata:ArrayCollection=resdata1[i].ruleName;
      /* var n:int; */
      /* for(n=0;n<resdata1[i].ruleName.length;n++)
      /* tem=resdata1[i].ruleName.spko_value.concat(); */
      var tempdata:ArrayCollection=resdata1[i].ruleName;
      //newcb.dataProvider=bindata;
      "spko_value";
      true;
      true;
      /* var m:int=40;
      //Alert.show("Double","alert");
      //pn.visible=true;
      private function handlelogonFault(event):void
      //Alert.show("Incorrect","Alert");
      </fx:Script>
      <s:Button id="btn_search" x="220" y="20" label="Search" click="search_click();"/>
      <s:TextArea id="txtarea" change="txtchange()" />
      <!--<s:VGroup id="lblContainer" width="180" height="150" verticalAlign="middle" verticalScrollPosition="2" />-->
      <s:Panel title="Form Container Example" id="pn1"
      0" verticalCenter="0" visible="false">
      <!--<s:VGroup left="10" right="10" top="10" bottom="10">-->
      <mx:HBox>
      <mx:Form
      lblContainer" verticalGap="2" indicatorGap="14" paddingBottom="10"
      16"
      </mx:HBox>
      <!--</s:VGroup>-->
      </s:Panel>
      <!--<mx:VBox id="lblContainer" width="180" height="150" verticalGap="2" visible="false"/>-->
      <s:Panel id="pn" width="100%" visible="false">
      <s:Label id="newlabel" x="200" y="300"/>
      <s:TextInput id="newtxtbox" />
      </s:Panel>
      <fx:Declarations>
      <s:RemoteObject destination="ColdFusion" id="Logon" source="IST_Business_Applications.IST_Docstor.file_access.editattrfirst" >
      <s:method name="fneditatt" fault="handlelogonFault(event)" result="handlelogonResult(event)" />
      </s:RemoteObject>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      </s:Application>
      paddingTop="
      id="
      horizontalCenter="
      Alert.show(event.fault.message);
      pn1.title=resdata1[0].ProfileName;
      newtxtbox.text="1";
      pn.addElement(newtxtbox);
      k=250;
      m+=30;
      if (counter >=resdata1.length)
      { counter = 0; k=10; m+=30;}
      newtxtbox.x= k ;
      newtxtbox.y = m;
      counter++;
      lblContainer.visible=
      lbl.addElement(newcb);
      lblContainer.addElement(lbl);
      pn1.visible=
      newcb.dataProvider=tempdata;
      newcb.labelField=
      tem[n]=resdata1[i].ruleName[n].spko_value.concat();
      newcb.width=300;
                                                       //i am used to take length of resdata.but it shows 1
      lbl.addElement(newtxtbox);
      newtxtbox.width=300;
      newtxtbox.id=
      lblform.text=resdata1[i].spk_name;
      lblform.width=100;
      lbl.addElement(lblform);
      lbl.direction=
      lbl.height = 27;
      lbl.label = resdata1[i].spk_name; */
      pn.visible=
      newlabel.text=resdata1[i].spk_name;
      //pn.addChild(newlabel);
      pn.addElement(newlabel);
      k =125;
      j+=20;
      { counter = 0; k=10; j+=30;}
      newlabel.x= k ;
      newlabel.y = j;
      counter++; */
      var j: int = 40;
      var counter:int = 0; */
      tmpLbl.x = 10;
      tmpLbl.y = 5;
      tmpLbl.text = "Label Text"; */
      Alert.show("welcome","alert");
      Logon.fneditatt(
      <![CDATA[
      xmlns:mx="
      xmlns:s="
      <s:Application
