4 Replies Latest reply on Aug 20, 2010 7:52 AM by ratnawe
    Access hostComponent property from SparkSkin (public var vs getter/setter)
    ratnawe
      Hey Flexers,
      Any ideas on that?
      I have written a custom component derived from a Spark TextInput.
      I have written a custom skin derived from SparkSkin for this custom component.
      The custom component has a property called "prompt" and from my custom skin I want to access this property via "hostComponent.prompt". Now I thought I have two equivalent options to implement this property:
      1) simple public variable:
      [Bindable] public var prompt:String;
      2) private variable with getters and setters:
      [Bindable] private var _prompt:String;
      public function get prompt():String
          return _prompt;
      public function set prompt(value:String):void
          _prompt= value;
      If I use solution 1 it works.
      If I use solution 2 it doesn't work. The compiler will warn me with "Data binding will not be able to detect assignments to 'prompt'." And this warning infact is correct so that assignments to the variable will not be recognized by the skin.
      But why?
      Shouldn't these two solutions be equivalent?
      It just cost me a lot of time to find out, that's why I'm asking, hoping to learn the answer
      Thanks for any comments and answers!
      tags: flex 4, SparkSkin, hostComponent, data binding
        • 1. Re: Access hostComponent property from SparkSkin (public var vs getter/setter)
          cjolif-Fc6gNO Level 1
          You probably have put at the wrong place for 2.
          The following should work:
              return _prompt;
              _prompt= value;
          Christophe Jolif
          ILOG Elixir Lead
          ratnawe <forums@adobe.com>
          To:
          Christophe Jolif/France/IBM@IBMFR
          Date:
          08/20/2010 03:07 PM
          Subject:
          getter/setter)
          Hey Flexers,
          Any ideas on that?
          component.
              return _prompt;
              _prompt= value;
          But why?
          to learn the answer
          • 2. Re: Access hostComponent property from SparkSkin (public var vs getter/setter)
            UbuntuPenguin Level 4
            Shouldn't these two solutions be equivalent? ...
            No , they shouldn't be equivalent because they aren't. When you are using getters and setters , you have to dispatch an event in the setter ( or any function that changes the result of the getter ) for it to be bindable.
            These two things are equivalent.
            and
            [Bindable(Event="promptChange")]
              return _prompt;
            public function set prompt(  value:String  ):void
              _prompt = value;
              dispatchEvent("promptChange");
            If this post was helpful , please mark it as such.
            • 3. Re: Access hostComponent property from SparkSkin (public var vs getter/setter)
              ratnawe Level 1
              Your post was very helpful. Helped me to better understand how data binding works. Thanks a lot!
              • 4. Re: Access hostComponent property from SparkSkin (public var vs getter/setter)
                ratnawe Level 1
                Thanks for pointing that out. It actually worked that way!
