0 Replies Latest reply on Aug 20, 2010 12:48 PM by cf2004cf
    set and get The same member name may not be repeated more than once
    cf2004cf
      Hi, I have a script (AS1 or 2, don't know for sure)
      When compiled says
      Line 116 The same member name may not be repeated more than once.
      Line 129 The same member name may not be repeated more than once.
      This is the snippet
      116    function set position(p)
              this.setPosition(p);
          function setPosition(p)
              this.prevPos = this._pos;
              this.obj[this.prop] = this._pos = p;
              this.broadcastMessage("onMotionChanged", this, this._pos);
              updateAfterEvent();
      129    function get position()
              return this.getPosition();
      Below is the entire script
      Any ideas of how to fix this?
      Many thanks!!
      dynamic class mx.transitions.Tween
          static var version: String = "1.1.0.52";
          static var __initBeacon = mx.transitions.OnEnterFrameBeacon.init();
          static var __initBroadcaster = mx.transitions.BroadcasterMX.initialize(mx.transitions.Tween.prototype, true);
          var _duration;
          var _fps;
          var _intervalID;
          var _listeners;
          var _pos;
          var _startTime;
          var _time;
          var addListener;
          var begin;
          var broadcastMessage;
          var change;
          var isPlaying;
          var looping;
          var obj;
          var position;
          var prevPos;
          var prevTime;
          var prop;
          var useSeconds;
          function Tween(obj, prop, func, begin, finish, duration, useSeconds)
              if (arguments.length)
                  this.obj = obj;
                  this.prop = prop;
                  this.begin = begin;
                  this.__set__position(begin);
                  this.__set__duration(duration);
                  this.useSeconds = useSeconds;
                  if (func)
                      this.func = func;
                  this.__set__finish(finish);
                  this._listeners = [];
                  this.addListener(this);
                  this.start();
          function set time(t)
              this.prevTime = this._time;
              if (t > this.__get__duration())
                  if (this.looping)
                      this.rewind(t - this._duration);
                      this.update();
                      this.broadcastMessage("onMotionLooped", this);
                  else
                      if (this.useSeconds)
                          this._time = this._duration;
                          this.update();
                      this.stop();
                      this.broadcastMessage("onMotionFinished", this);
              else
                  if (t < 0)
                      this.rewind();
                      this.update();
                  else
                      this._time = t;
                      this.update();
          function get time()
              return this._time;
          function set duration(d)
              this._duration = d == null || d <= 0 ? _global.Infinity : d;
          function get duration()
              return this._duration;
          function set FPS(fps)
              var __reg2 = this.isPlaying;
              this.stopEnterFrame();
              this._fps = fps;
              if (__reg2)
                  this.startEnterFrame();
          function get FPS()
              return this._fps;
              updateAfterEvent();
          function getPosition(t)
              if (t == undefined)
                  t = this._time;
              return this.func(t, this.begin, this.change, this._duration);
          function set finish(f)
              this.change = f - this.begin;
          function get finish()
              return this.begin + this.change;
          function continueTo(finish, duration)
              this.begin = this.position;
              if (duration != undefined)
              this.start();
          function yoyo()
              this.continueTo(this.begin, this.__get__time());
          function startEnterFrame()
              if (this._fps == undefined)
                  _global.MovieClip.addListener(this);
              else
                  this._intervalID = setInterval(this, "onEnterFrame", 1000 / this._fps);
              this.isPlaying = true;
          function stopEnterFrame()
                  _global.MovieClip.removeListener(this);
              else
                  clearInterval(this._intervalID);
              this.isPlaying = false;
          function start()
              this.rewind();
              this.broadcastMessage("onMotionStarted", this);
          function stop()
              this.broadcastMessage("onMotionStopped", this);
          function resume()
              this.fixTime();
              this.broadcastMessage("onMotionResumed", this);
          function rewind(t)
              this._time = t == undefined ? 0 : t;
              this.fixTime();
              this.update();
          function fforward()
              this.__set__time(this._duration);
              this.fixTime();
          function nextFrame()
                  this.__set__time((getTimer() - this._startTime) / 1000);
                  return;
              this.__set__time(this._time + 1);
          function onEnterFrame()
              this.nextFrame();
          function prevFrame()
                  return;
              this.__set__time(this._time - 1);
          function toString()
              return "[Tween]";
          function fixTime()
                  this._startTime = getTimer() - this._time * 1000;
          function update()
              this.__set__position(this.getPosition(this._time));
          function func(t, b, c, d)
              return c * t / d + b;
