0 Replies Latest reply on Aug 20, 2010 2:08 PM by Deh Bontempos
    adding property/field to an item inside array collection
    Deh Bontempos Level 1
      Hi
      I'm newbie. But I'm spending a huge amout of time trying to figure out something that should be simple.
      in short:
      I wanted to add a new field/property to an item inside an arraycollection(ac).
      I thought something like:
      ac.souce[i].push(object:value)
      would do (its inside a loop, since I have ac.length) but it didnt.
      ITS IMPORTANT TO SAY THAT:
      i think addItem, or addItemAt IS NOT THE CASE.
      I want to add an new item INSIDE the array that is wrapped in ac.
      in long:
      I have a ORDERS table that comes with a client_id (int).
      I need to retrieve the client's name from a CLIENTS table.
      Ok i have to put everything on the same datagrid. So, first i've tried to ivoke a function like this that would use the getClientsByID and return a string with its name.
      It didn't worked, maybe due to the syntax.
      SO, i thought i had to put all those 2 tables into 1 array collection to use this as a 'formated' data provider for the datagrid.
      What should I do? this is a simples example.
      Thanks a lot
      Btp~
