4 Replies Latest reply on Oct 11, 2006 4:38 PM by bregent
    Problem with insert record
    cozybuilder
      I have used dreamweavers insert application object to insert a new record into my access database. The problem is: it will only insert one record, then I get an error that says the primary key is already used. It will not submit any records if the table already contains any records. So all you guru's what is the problem here?
