18 Replies Latest reply on Sep 13, 2010 4:56 AM by pasithee
    change text
    pasithee
      Hi all
      I try to change a text in a textFrame. As long as I use a Dialog it works. Switching to a
      Window('dialog', 'a')
      popup it does not work anymore. Why that?
      Here my source to change a specifiic text in a paragraph:
      for(var i = 0; i < app.selection[0].parentStory.paragraphs.length; i++) {
          var tf = app.selection[0].parentStory.paragraphs[i].parent.texts[0];
          var start = tf.parentStory.paragraphs.item(i).characters.item(0);
          var end = tf.parentStory.paragraphs.item(i).characters.item(-2);
          var line = doLine(tf.texts.itemByRange(start, end).contents.toString(), delimiter);
          tf.texts.itemByRange(start, end).contents = line;
      thanks
      pasithee
        • 1. Re: change text
          pasithee Level 1
          does someone has an idea? any hint?
          • 2. Re: change text
            Marijan Tompa [tomaxxi] Level 4
            Can you maybe post bigger part of your script? I wanna see how you use Window().
            tomaxxi
            http://indisnip.wordpress.com/
            • 3. Re: change text
              pasithee Level 1
              here the most important part of my script:
              var win = main();
              function main() {
                  var win = new Window('dialog','Reformat');
                  var spaces = Array("-- add space --", "hair", "thin", "punctuation", "figure", "sixth", "quarter", "third", "em", "en", "flush", "nonbreaking (fixed width)", "nonbreaking");
                  var codes = Array("", "^|", "^<", "^.", "^/", "^%", "^4", "^3", "^m", "^>", "^f", "^s", "^S");
                  win.orientation = "row";
                  win.spacing = 0;
                  with(win) {
                      var delimiterField = add('edittext');
                      delimiterField.preferredSize = [100,25];
                      var spacesDrop = add('dropdownlist', undefined, spaces);
                      spacesDrop.selection = 0;
                      spacesDrop.preferredSize = [20,25];
                  spacesDrop.onChange = function() { delimiterField.text += codes[spacesDrop.selection.index]; spacesDrop.selection = 0; };
                  var group = win.add("group");
                  win.okButton = group.add("button", undefined, "reformat");
                  win.okButton.onClick = function() { reFormat(delimiterField.text) };
                  win.canButton = group.add("button", undefined, "Cancel");
                  win.canButton.onClick = function() { this.window.close(2) };
                  win.center();
                  win.show();
                  return win;
              function reFormat(delimiter) {
                      var del = delimiter;
                      del = del.replace("^|", "\u200A") //hair space
                      del = del.replace("^<", "\u2009") //thin space
                      del = del.replace("^.", "\u2008") //punctuation space
                      del = del.replace("^/", "\u2007") //figure space
                      del = del.replace("^%", "\u2006") //sixth space
                      del = del.replace("^4", "\u2005") //quarter space
                      del = del.replace("^3", "\u2004") //third space
                      del = del.replace("^m", "\u2003") //em space
                      del = del.replace("^>", "\u2002") //en space
                      del = del.replace("^f", "\u2001") //flush space
                      del = del.replace("^s", "\u202F") //nonbreaking space (fixed width)
                      del = del.replace("^S", "\u00A0") //nonbreaking space
                      //" ", "\u0020" //space
                      doStory(del);
              function doStory(delimiter) {
                      var line = doLine(tf.texts.itemByRange(start, end).contents.toString(), delimiter); //do line returns a string
              thanks
              pasithee
              • 4. Re: change text
                It appears to work on CS4, Mac -- unless this isn't what you meant?
                • 5. Re: change text
                  Cool, nice menu
                  Yeah, working here also!
                  tomaxxi
                  • 6. Re: change text
                    pasithee Level 1
                    Hi all
                    it is not exactly what I meant. So ... the replacment should take place in a text frame. So that mean if you select a text frame in your document and then run this script you see the text field with the dropdown menu (picture). There you can enter a text and select spaces. Then the script calculates some thing (not posted) and returns a string. With this string I would like to replace special text section in each paragraph in the text frame.
                    So at the end I need to replace text in a paragraph. I try to do it this way:
                            //replace a specific range in paragraph with the value of the variable line
                            tf.texts.itemByRange(start, end).contents = line; //line is a variable of type string
                    In this script I loop over all paragraphs of the selected text frame and replace a specific range in this paragraph with a string.
                    does it help
                    thanks
                    pasithee
                    • 7. Re: change text
                      You said the behavior changed when you changed from a regular dialog to the ScriptUI one.
                      Could the problem be you don't get the correct text string returned from the ScriptUI dialog? Perhaps the string you were expecting disappears from memory if the dialog is closed -- remember, it only exists in the variable inside your dialog, so I think you have to save it into another variable before closing (= destroying) the window.
                      • 8. Re: change text
                        pasithee Level 1
                        Hi all
                        it does not work. What I want is to replace a existing text in a indesign document and not the text in the input box.
                        As you can see in the image I select a text frame and open the script. In the script I enter for example a comma space an click on reformat. Then the loops over each paragraph of this text frame and replaces the the text which include the value given by the script. e.g. 'Ode 6, 7, 9, 10, 11, 14' comes 'Ode 6, 9a, 14'.
                        Pasithee
                        • 9. Re: change text
                          Changing text with a script is tricky, because some collections get cached -- in your case, possibly the start of paragraphs inside the app.selection object.
                          It appears to me you are changing your paragraphs from the first to the last one. Can you rewrite the main loop, so it changes paragraphs from end to start?
                          (It would not explain why it suddenly stopped working when you changed the dialog to a SciptUi window.)
                          • 10. Re: change text
                            Ah -- while you are editing, you might want to clarify this:
                            It seems to do this:
                            app.selection[0] -> any selected text
                              parentStory -> the entire story
                                paragraphs[i] -> any paragraph within that story
                                  parent -> its parent ... which is parentStory
                                    texts[0] -> ... the text itself ...
                            and you use the variable as
                            which translates back into
                            tf -> an entire story's worth of text
                              parentStory -> the story with that text
                                paragraphs.item(i) -> a paragraph in there
                            So -- unless there is lots more code which you are not showing -- it could be compacted into
                            var start = app.selection[0].parentStory.paragraphs[i].characters[0];
                            var end = app.selection[0].parentStory.paragraphs[i].characters[-2];
                            without the need to walk up, then down, then up, then down the text hierarchy again (if I'm counting right).
                            In addition, since you only need start and end as input for ItemByRange, you could replace the entire thing, including
                            with
                            var line = doLine(app.selection[0].parentStory.paragraphs[i].characters.itemByRange(0, -2).contents.toString(), delimiter);
                            (It seemed to me "toString" on the contents is unnecessary, but -- it might be, if the paragraph consists only of one SpecialCharacter. [...] Some real intensive checking later: I bet what you get in that case is worthless anyway...)
                            • 11. Re: change text
                              pasithee Level 1
                              Hi Jongware
                              thanks a lot for your answer but getting the paragraph into a variable and changing this variable works. the only thing that not work is writing the value back to the InDesign document/story.
                              so lets have a simpler example that try to write the string 'ABC' back the first paragraph:
                              app.selection[0].parentStory.paragraphs[0].contents = "ABC";
                              thanks
                              pasithee
                              • 12. Re: change text
                                pasithee Level 1
                                Hi all
                                Ok I tried to setup an example. Here to scripts.
                                This one works
                                test();
                                function test() {
                                        var start = app.selection[0].parentStory.paragraphs.item(i).characters.item(0);
                                        var end = app.selection[0].parentStory.paragraphs.item(i).characters.item(-2);
                                        app.selection[0].texts.itemByRange(start, end).contents = "A";
                                and this one doesn't work
                                var win = main();
                                function main() {
                                    var win = new Window('dialog','Reformat Index');
                                    win.spacing = 0;
                                    win.okButton = group.add("button", undefined, "start");
                                    win.okButton.onClick = function() { test() };
                                    win.center();
                                    win.show();
                                    return win;
                                function test() {
                                In both scripts I replace each paragraph of a selected text frame with 'A'. When using scriptUI it doesn't work anymore. Any idea?
                                pasithee
                                • 13. Re: change text
                                  I can tell you right away why that doesn't work ...
                                  Look: top is before, bottom is after running your one-line script.
                                  You replace the contents of paragraph #1 (well, #0), and that contents include the hard return at the end that tells InDesign where that paragraph #1 ends.
                                  If you use this instead
                                  app.selection[0].parentStory.paragraphs[0].contents = "ABC\r";
                                  it'll not be messed up.
                                  • 14. Re: change text
                                    pasithee Level 1
                                    Hi Jongware
                                    thanks for your help. I changed what you wrote but still doesn't work.
                                    here my script
                                        win.spacing = 0;
                                        win.center();
                                        win.show();
                                    function test() {
                                    Does this script works in you InDesign? Could it be a issue in CS5?
                                    pasithee
                                    • 15. Re: change text
                                      I'm afraid this has gone beyond me ... Anyone else? Please?
                                      This function 'test' does pop up an alert containing the text of the first paragraph, so that part works just fine. As you have shown, it also works when called directly -- but as soon as you put it into a dialog it shows the alert but stubbornly refused to change the text!
                                      ... It must have something to do with ScriptUI, but I'm flummoxed, stymied, and generally shut up.
                                      function test() {
                                              sel = app.selection[0].parentStory.paragraphs[i].characters.itemByRange(start, end);
                                              if (!i) alert (sel.contents);
                                              sel.contents = "A";
                                      • 16. Re: change text
                                        Well, in my case (CS5) it's not working also... But why?! It gives me error when script wants to change contents of paragraph. Error: "Cannot handle the request because a modal dialog or alert is active." So, you can't do changes while your dialog is active. So, you have two solutions. First is to close dialog, make changes and then reopen dialog, or to use 'palette' instead of 'dialog'. To use 'palette' add 'targetengine' on beginning of your script and change 'dialog' to 'palette' in window creation row.
                                        #targetengine textChange
                                        var win = new Window('palette','Reformat Index');
                                        Hope it helps.
                                        tomaxxi
                                        • 17. Re: change text
                                          pasithee Level 1
                                          once again. thanks a lot tomaxxi that was the right answer/hint.
                                          cheers
                                          pasithee
                                          • 18. Re: change text
                                            You are welcome!
                                            Glad it worked!
                                            tomaxxi
