2 Replies Latest reply on Aug 23, 2010 12:04 AM by betheflexcoder
    chart with a data tip used as a custom tooltip
    betheflexcoder Level 2
      Is it possible to have a chart component with datatip as a tooltip for a label?
        • 1. Re: chart with a data tip used as a custom tooltip
          thebouv Level 2
          Yes, you can put pretty much anything you want to in a custom tool tip, including charts.
          Here is a Pie Graph, with it's datatips showing, in a tool tip that's on a label that I just made for you as an example.  You can right-click and view the source:
          http://thebouv.com/flex/tooltip/
          • 2. Re: chart with a data tip used as a custom tooltip
            I looked at the code sent by you.  I got till that step previously but could not hover on the custom tool tip in order to view the data tip of the chart. The custom tooltip disappears when I try to hover on it to see the data tip. I tried to hover on it by disabling the tooltip manager, this worked fine. But could not make the custom tool tip disappear after mouse out from it. COuld not catch the exact point to remove the tooltip using the ToolTip manager.
            I am adding my code below which is a item renderer for a label with the custom tooltip. In my case, the hover is on a datagrid cell.
            package
            import flash.display.DisplayObject;
            import flash.events.FocusEvent;
            import flash.events.MouseEvent;
            import mx.collections.ArrayCollection;
            import mx.controls.Alert;
            import mx.controls.DateField;
            import mx.controls.Label;
            import mx.controls.ToolTip;
            import mx.core.FlexGlobals;
            import mx.core.IToolTip;
            import mx.core.IUIComponent;
            import mx.events.DynamicEvent;
            import mx.events.ToolTipEvent;
            import mx.managers.ISystemManager;
            import mx.managers.ToolTipManager;
            import mx.utils.ObjectUtil;
            public class MyHoverRenderer extends ItemRenderer
              private var lastOrderedLbl:Label;
              private var customToolTip:ItemHistoryHoverToolTip;
              private var sm:ISystemManager;
              private var previousTarget:DisplayObject;
              [Bindable] private var graphData:ArrayCollection;
              [Bindable] private var avgCaseQuantity:String;
              [Bindable] private var avgSplitQuantity:String;
              [Bindable] private var _lastOrdered:String;
              public function MyHoverRenderer()
               super();
               lastOrderedLbl = new Label();
               lastOrderedLbl.addEventListener(ToolTipEvent.TOOL_TIP_CREATE, lastOrderedToolTipHandler);
               lastOrderedLbl.addEventListener(MouseEvent.MOUSE_OVER, mouseOverEventHandler);
              override public function set data(value:Object):void
               //for data from the grid
               super.data = value;
               if(data!=null)
                if (data.lastOrderedDate)
                 //_lastOrdered=rtn.itemLastRequestedDate.toString();
                 _lastOrdered= DateField.dateToString(data.lastOrderedDate, "MM/DD");
               setStyle("rowColor",0xFFFFFF);
              override protected function updateDisplayList(unscaledWidth:Number,   unscaledHeight:Number):void
               super.updateDisplayList(unscaledWidth, unscaledHeight);
               if(data!=null)
                lastOrderedLbl.toolTip = " ";
               this.addElement(lastOrderedLbl);
              private function lastOrderedToolTipHandler(event:ToolTipEvent):void
               if(data!=null)
                if(graphData)
                 customToolTip = new ItemHistoryHoverToolTip();
                 event.toolTip = customToolTip;
                 ToolTipManager.enabled = false;
                 ToolTipManager.hideDelay = Infinity;
                 trace("graph data"+ObjectUtil.toString(graphData));
                 //event.toolTip.addEventListener(MouseEvent.MOUSE_OUT, focusOutEndHandler);
                } else
                 event.toolTip = null;
              private function mouseOverEventHandler(event:MouseEvent):void
               ToolTipManager.enabled = true;
              private function focusOutEndHandler(event:MouseEvent):void
               /*Alert.show("focus out tooltip");
               if(ToolTipManager.currentToolTip)
               var sm:ISystemManager = (ToolTipManager.currentToolTip).systemManager as ISystemManager;
               /*sm.topLevelSystemManager.toolTipChildren.removeChild(currentToolTip as DisplayObject);*/
               //var toolTipObject:DisplayObject =
                //Alert.show("present"+String(sm.topLevelSystemManager.toolTipChildren.getChildIndex(Tool TipManager.currentToolTip as DisplayObject)));
               //sm.topLevelSystemManager.toolTipChildren.removeChild(ToolTipManager.currentToolTip as DisplayObject);
