5 Replies Latest reply on Aug 23, 2010 8:32 AM by preditorj40153117
    Newbie Needs html Export for Module
    preditorj40153117 Level 1
      Ok I am new so please bare with me.
      i have a project that i have created. Its a simple 4 button project that should link to other pages on my site.
      I am using dnn so i have a text/html module that i need to put it in. i can put text on a page with it or some html code.
      I sometimes put the embed code from YouTube in these same modules to show video. I was thinking that this catalyst project would allow for the same thing. Just copy a line of code and bam it works.
      Do i have to put this project in a particular form on my server to allow it to work?
      How can i use this project in my modules?
        • 1. Re: Newbie Needs html Export for Module
          I thought i might need to expand what i am asking.
          when i export my deploy-to-web file. It will not upload to my root folder on my aspx site. It gives me 3 errors and then the folder is not uploaded.
          i can run the Main.html in dreamweaver and it works as expected. I just cant get it to the site.
          so i was wondering if there was a way to upload to my godaddy account and then embed it into my html module via url.
          My platform is DNN 5.4 which is much like dupril or Joombla. And there isn't much out there dealing with this type of implementation.
          PLEASE Help me. I have learned a lot about catalyst in the last week and i really want to add this new capability to my designs.
          • 2. Re: Newbie Needs html Export for Module
            here is the zip containing the file i exported. Its on Godaddy
            DOWNLOAD
            Here is what i see when i try to up load it to my other server here is what filezilla tells me.
            Status: Resolving address of www.creekcitytv.net
            Status: Connecting to 72.167.183.17:21...
            Status: Connection established, waiting for welcome message...
            Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
            Response: 220-You are user number 4 of 75 allowed.
            Response: 220-Local time is now 18:48. Server port: 21.
            Response: 220-This is a private system - No anonymous login
            Response: 220 You will be disconnected after 3 minutes of inactivity.
            Command: USER creekcitytv
            Response: 331 User creekcitytv OK. Password required
            Command: PASS ********
            Response: 230-User creekcitytv has group access to:  450
            Response: 230 OK. Current directory is /
            Command: SYST
            Response: 215 UNIX Type: L8
            Command: FEAT
            Response: 211-Extensions supported:
            Response: EPRT
            Response: IDLE
            Response: MDTM
            Response: SIZE
            Response: REST STREAM
            Response: MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
            Response: MLSD
            Response: ESTP
            Response: PASV
            Response: EPSV
            Response: SPSV
            Response: ESTA
            Response: AUTH TLS
            Response: PBSZ
            Response: PROT
            Response: 211 End.
            Status: Connected
            Status: Retrieving directory listing...
            Command: PWD
            Response: 257 "/" is your current location
            Command: TYPE I
            Response: 200 TYPE is now 8-bit binary
            Command: PASV
            Response: 227 Entering Passive Mode (72,167,183,17,253,65)
            Command: MLSD
            Response: 150 Accepted data connection
            Response: 226-ASCII
            Response: 226-Options: -a -l
            Response: 226 44 matches total
            Status: Directory listing successful
            Status: Creating directory '/allflash'...
            Command: MKD allflash
            Response: 257 "allflash" : The directory was successfully created
            Command: CWD allflash
            Response: 250 OK. Current directory is /allflash
            Command: PWD
            Response: 257 "/allflash" is your current location
            Command: PASV
            Response: 227 Entering Passive Mode (72,167,183,17,171,142)
            Command: MLSD
            Response: 226-ASCII
            Response: 226 2 matches total
            Response: 220-You are user number 5 of 75 allowed.
            Response: 220-Local time is now 18:49. Server port: 21.
            Status: Connected
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata.zip
            Command: CWD /allflash
            Command: PWD
            Command: TYPE I
            Command: PASV
            Response: 227 Entering Passive Mode (72,167,183,17,23,127)
            Command: STOR Gregorys_Paint_links_flcata.zip
            Response: 226-File successfully transferred
            Response: 226 9.346 seconds (measured here), 176.00 Kbytes per second
            Status: File transfer successful, transferred 1,684,361 bytes in 10 seconds
            Command: PASV
            Response: 227 Entering Passive Mode (72,167,183,17,145,45)
            Command: MLSD
            Response: 226-ASCII
            Response: 226 3 matches total
            Status: Disconnected from server
            Error: Connection closed by server
            Status: Resolving address of ftp.webfeed.tv
            Status: Connecting to 72.249.5.10:21...
            Response: 220 Gene6 FTP Server v3.10.0 (Build 2) ready...
            Command: USER 26016
            Response: 331 Password required for 26016.
            Response: 230 User 26016 logged in.
            Command: SYST
            Command: FEAT
            Response: AUTH TLS
            Response: CCC
            Response: CLNT
            Response: CPSV
            Response: EPRT
            Response: EPSV
            Response: MDTM
            Response: MFCT
            Response: MFMT
            Response: MLST type*;size*;create;modify*;
            Response: MODE Z
            Response: PASV
            Response: PBSZ
            Response: PROT
            Response: SIZE
            Response: SSCN
            Response: TVFS
            Response: UTF8
            Response: XCRC "filename" SP EP
            Response: XMD5 "filename" SP EP
            Response: XSHA1 "filename" SP EP
            Response: 211 End.
            Command: CLNT FileZilla
            Response: 200 Noted.
            Command: OPTS UTF8 ON
            Response: 200 UTF8 OPTS ON
            Status: Connected
            Command: PWD
            Response: 257 "/" is current directory.
            Command: TYPE I
            Response: 200 Type set to I.
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,55)
            Command: MLSD
            Response: 150 Data connection accepted from 99.62.100.215:56842; transfer starting.
            Response: 226 Transfer ok.
            Command: USER 26016
            Command: USER 26016
            Status: Connected
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/framework_4.0.0.14159.sw z
            Command: CWD /Gregorys_Paint_links_flcata/deploy-to-web
            Status: Connected
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/Main.html
            Response: 550 CWD failed. "/Gregorys_Paint_links_flcata/deploy-to-web" : no such file or directory.
            Response: 550 CWD failed. "/Gregorys_Paint_links_flcata" : no such file or directory.
            Command: CWD /
            Response: 250 CWD command successful. "/" is current directory.
            Command: MKD Gregorys_Paint_links_flcata
            Response: 550 "Gregorys_Paint_links_flcata": can't create directory.
            Command: MKD /Gregorys_Paint_links_flcata/deploy-to-web
            Response: 550 "/Gregorys_Paint_links_flcata/deploy-to-web": can't create directory.
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/framework_4.0.0.14159.swz
            Response: 550 No such file.
            Command: TYPE I
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/Main.html
            Command: PASV
            Command: TYPE A
            Response: 227 Entering Passive Mode (72,249,5,10,117,72)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/framework_4.0.0.14159.swz
            Response: 200 Type set to A.
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,63)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/Main.html
            Error: Could not write to transfer socket: EPIPE - Local endpoint has been closed
            Response: 550 Cannot STOR.
            Error: Critical file transfer error after transferring 131,072 bytes in 1 second
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/Main.swf
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/osmf_flex.4.0.0.13495.sw z
            Command: CWD /
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/Main.swf
            Command: PASV
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/osmf_flex.4.0.0.13495.swz
            Response: 227 Entering Passive Mode (72,249,5,10,117,92)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/Main.swf
            Command: TYPE I
            Command: PASV
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/playerProductInstall.swf
            Response: 227 Entering Passive Mode (72,249,5,10,117,94)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/osmf_flex.4.0.0.13495.swz
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/rpc_4.0.0.14159.swz
            Command: CWD /
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/playerProductInstall.swf
            Command: PASV
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/rpc_4.0.0.14159.swz
            Response: 227 Entering Passive Mode (72,249,5,10,117,64)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/playerProductInstall.swf
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,74)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/rpc_4.0.0.14159.swz
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/spark_4.0.0.14159.swz
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/sparkskins_4.0.0.14159.s wz
            Command: CWD /
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/spark_4.0.0.14159.swz
            Command: PASV
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/sparkskins_4.0.0.14159.swz
            Response: 227 Entering Passive Mode (72,249,5,10,117,75)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/spark_4.0.0.14159.swz
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,67)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/sparkskins_4.0.0.14159.swz
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/swfobject.js
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/textLayout_1.0.0.595.swz
            Command: CWD /
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/swfobject.js
            Command: TYPE A
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/textLayout_1.0.0.595.swz
            Command: PASV
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,69)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/swfobject.js
            Response: 227 Entering Passive Mode (72,249,5,10,117,79)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/textLayout_1.0.0.595.swz
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/history/history.css
            Command: CWD /Gregorys_Paint_links_flcata/deploy-to-web/history
            Response: 550 CWD failed. "/Gregorys_Paint_links_flcata/deploy-to-web/history" : no such file or directory.
            Command: CWD /
            Command: CWD /
            Command: MKD /Gregorys_Paint_links_flcata/deploy-to-web/history
            Response: 550 "/Gregorys_Paint_links_flcata/deploy-to-web/history": can't create directory.
            Command: PASV
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/history/history.css
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,84)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/history/history.css
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/history/history.js
            Status: Starting upload of /Users/editpro/Desktop/Gregorys_Paint_links_flcata/deploy-to-web/history/historyFrame.htm l
            Command: CWD /
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/history/history.js
            Command: TYPE A
            Command: SIZE /Gregorys_Paint_links_flcata/deploy-to-web/history/historyFrame.html
            Command: PASV
            Command: PASV
            Response: 227 Entering Passive Mode (72,249,5,10,117,96)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/history/history.js
            Response: 227 Entering Passive Mode (72,249,5,10,117,57)
            Command: STOR /Gregorys_Paint_links_flcata/deploy-to-web/history/historyFrame.html
            • 3. Re: Newbie Needs html Embed for swf
              So what i am wondering is if the Main.swf that comes in the deploy-to-web folder is stand alone. Can it be the only element out of that folder and still function?
              • 4. Re: Newbie Needs html Embed for swf
                Tanya Heins-2I5OoU Level 3
                You'll need to upload the entire contents of the 'deploy-to-web' folder to your server.  The Main.swf needs the other resources to function.
                Tanya
                • 5. Re: Newbie Needs html Embed for swf
                  Thanks for your response.
                  I have 3 separate servers. Shared on godaddy, ihost and resellers choice. The deploy-to-web file will only load to godaddy (linux). The other 2 can not accept the deploy-to-web folder (they are asp hosting).
                  This was my first problem.... until
                  I removed the main.swf from the deploy folder and played it on another computer without the other folder content.
                  then i found a player that allows the play of swf flash files (which i am guessing replaces the folder content with everything the main.swf needs).
                  Then it worked on my clients site.
                  I am unsure why it plays without the content i did open and test it in dreamweaver but i did not save.
                  it is the paint selection links represented by benjamin moore paint cans. heres a link.
